Old Jan 03, 2013, 05:21 PM
packardpursuit is offline
Find More Posts by packardpursuit
Joined Jan 2009
Here is my roll around. 30" x 96" flat building table. Back is 1/8" ply shear web between upper rung of platform frame and lower 1x just above the castors. Can't move as long as the glue holds. Front side of work table is doubled 1x 5 Poplar. All platform framing (KD verical Grain Pine/Poplar) machined straight on two edges prior to cutting and assembly. End frames are KD 2x4 and 5/8" ply provide shear strngth and access to lower storage box. Weakest point is the two center support frames. Uprights form lap joints with cross members at upper and lower ends, each joint 3-12" x 5" (17,5 sq.inches glued surface - four lapped joints per station). Came out within less than 1/32 surface variance tolerance (I was shooting for =/- 1/64). Straight edges place anywhere on 5/8 ply top show no dicenable deviation, rock, or sag, in any direction. Crossmembers supporting the surface are placed 16" on center. Lower crossmembers are 32" on center. Castors are 3.5" diam from Harbor Frieght, lagged into post bottoms at ends. Moves esily and remains flat despite any floor variations, although I will shim a high wheel if it rocks and has to remain there for a time.
packardpursuit is offline Find More Posts by packardpursuit
Discussion what sea/float plane would you build for 340cc? how much Waterplanes 4 Mar 03, 2012 12:38 PM
Discussion Advice: What planes would you build? Captain Bravo Foamies (Scratchbuilt) 4 Aug 03, 2011 12:39 AM
Help! I would like to build a plane... tanman44 Fuel Plane Talk 15 Jul 30, 2007 12:20 PM
Which WWII planes you would like to build in foamy? Digitalset Foamies (Kits) 151 May 14, 2007 02:22 PM
Here's The New AP Plane I'm Building...Would like Some Opinions On Wing Design Randy Due Aerial Photography 68 Feb 23, 2004 02:38 PM
