Old Jan 06, 2013, 05:39 PM
samc99us is offline
Find More Posts by samc99us
Aurora Builder
United States, MD, Lusby
Joined Nov 2003
The Stream fuselage looks great as is, I'm pumped to see one in person!
I guess I need to build my ship with integrated stab mount, I'm not so sure it completely solves the alignment problem?
Options are great, I don't like being forced into a mounting arrangement even though top mount push-pull or pull-spring seems to be the norm.
samc99us is offline Find More Posts by samc99us
Old Jan 07, 2013, 12:51 AM
RubSon is offline
Find More Posts by RubSon
Aeromodeller by heart!
RubSon's Avatar
Herning, Denmark
Joined Dec 2002
Hi.
Buttom mounted elevator isnīt really an option.
The pylon is preformed to fit the buttomsection of the elevator and will not fit on top. In addition the holes for mounting screws are countersunk on the top surface.
I donīt think itīs to bad though. There isnīt much work in making the pylon fit the boom.
Got some more progress done last night, but hasnīt had the time to show the pictures.
Ruben
RubSon is offline Find More Posts by RubSon
Old Jan 07, 2013, 10:46 PM
NCDLG is offline
Find More Posts by NCDLG
NCDLG's Avatar
United States, NC, Raleigh
Joined Sep 2010
Ruben, the pylon... no, not a bad one at all. Then I wonder and wish that it was integrated, then I think who gives a rats crack... the airplane is knockers man!
I don't know what Scribner is talking about..... LOL
Post some more when you can Rubin, I need a fix bro!!! planeporn please!!!
NCDLG is offline Find More Posts by NCDLG
Old Jan 08, 2013, 06:02 AM
Scrib is online now
Find More Posts by Scrib
DLG Addict
Scrib's Avatar
United States, NC, Southern Pines
Joined Aug 2011
[QUOTE=NCDLG;23746734]... caressing her boon so sweetly. .... ahhhhhhahaaahaa. The Stram makes me a bit randy...
QUOTE]
Looks like someone started typing one handed...
Scrib is online now Find More Posts by Scrib
Old Jan 08, 2013, 09:08 AM
RubSon is offline
RubSon's Avatar
Herning, Denmark
Joined Dec 2002
Scrip, now I have to erase the pictures in my internal memorystorage.........
How could you
Ruben
Old Jan 16, 2013, 08:37 AM
RubSon is offline
RubSon's Avatar
Herning, Denmark
Joined Dec 2002
Delay, delay, delay....
Sorry guys
I should have had this plane airborne at this moment, but as a human, husbond and father, one is not allways in charge...
And........
With or indoor- freeflight nationals coming up this weekend, my son told my to go make something different to F3K.
So here we are:
My son building a P40- stick&tissue model.
This is a specific danish class with a span of 40 cm and a standart SIG plastic propellerdrive. They are good for around 2:30 min in a 9m gym..
On top of that we have prepared 7 chuckies, 2 A6īes, 2 EZB and 2 P15 (Danish again)
Weīll have a great day sunday. Just the 3 kids - daughter, son and dad.
After that itīs back to the Stream.........
Old Feb 03, 2013, 11:44 AM
RubSon is offline
RubSon's Avatar
Herning, Denmark
Joined Dec 2002
Hi Guys.
So Iīm back in the shop. Need to get this plane airworthy as 2 Karismas has landed in the meantime...
Just short update on the Indoor Freeflight Nationals:
Father didnīt do that good, he was bussy helping the kids out. Tobias placed first in the A6 junior category. He had 6 really great flights the best being just under 4min. Amanda, my daughter, won the junior chuckcontest. Times where not impressing, but good enough.
We had a great day, and we are going back next year
On with the Stream.
Servos in the wing has been swapped to D60. I had to otherwise JensDK would have been all over me. (And Iīll need the D47īs for the Karismas!)
Topdrive has been completed and servos glued in place...
Pic: (Sorry, they arenīt that good this time)
Old Feb 03, 2013, 12:07 PM
DLGjunkyard is online now
Find More Posts by DLGjunkyard
DLGjunkyard's Avatar
Canada, ON, Morriston
Joined Apr 2010
Just wanted to point out something here. If you get you hobby knife in behind the small tab on your servo connection and give the wire a slight pull it will slide of of the plastic jacket. It would have allowed you to slide the heat shrink over the entire crimped on end over your solder joint and then slip them all back into the plastic servo plug.
DLGjunkyard is online now Find More Posts by DLGjunkyard
Old Feb 04, 2013, 11:18 AM
RubSon is offline
RubSon's Avatar
Herning, Denmark
Joined Dec 2002
Nice trick you pointet out there...
Guess Iīm just to lazy to dismantle the plug. This job takes about 6min to do and every thing gets hidden inside the fuse ;-)
Ruben
Old Feb 04, 2013, 11:23 AM
Fly2High is offline
Find More Posts by Fly2High
Chuck 'Em and Chase 'Em
Fly2High's Avatar
United States, NY, Plainview
Joined Aug 2005
I would have just crimped on new servo plugs onto the ribbon cable....
Fly2High is offline Find More Posts by Fly2High
Old Feb 04, 2013, 11:48 AM
Mr. Wiz is offline
Find More Posts by Mr. Wiz
Time for me to Fly...
Mr. Wiz's Avatar
United States, MI, Fenton
Joined Jan 2000
Don't count on that working every time. Sometimes the crimped fittings themselves don't fit different connector housings that for all outward appearances look the same. The tabs themselves have to be the right length. If they are not, the crimp fitting will just slide out of the connector. Sometimes they are a tight fit but not locked in. This is a potential disaster waiting to happen. Give a tug on the wire to be sure the crimped fitting is properly seated. Do this even on the ones that are the right size. You don't want to think you have a proper connection only to find out you don't when the plane is 100' or so in the air.
Mr. Wiz is offline Find More Posts by Mr. Wiz
Old Feb 04, 2013, 01:03 PM
Joined Apr 2010
Fair enough. I use a crimped fitting with matching plastic piece. What I meant was when the OP realized he had soldered the connector on but forgot the shrink wrap he could have fixed it without resoldering the joints. Soldered joints are terrible because they stiffen the wire back under the insulation and with enough flexing they break with intermittent shorts .The wire appears fine but only running with half the original contact area.
Old Feb 04, 2013, 01:15 PM
Mr. Wiz is offline
Mr. Wiz's Avatar
Joined Jan 2000
Yep. I don't like soldering wire either. I should look into getting some better crimpers and connector supplies from Hansen. That's som much easier and better.
Old Feb 09, 2013, 02:08 PM
RubSon is offline
RubSon's Avatar
Herning, Denmark
Joined Dec 2002
Near finished
Here comes a little more pictures.
All thatīs left is balancing and final arangement of radio-gear..
Old Feb 09, 2013, 07:55 PM
NCDLG is offline
NCDLG's Avatar
Joined Sep 2010
Hey Ruben, nice to see it's about complete!
It looks like you cut the spar on the vertical... ?... not sure that's what I'm seeing. I regularly use a patch and leave the spar full length, use a couple of wraps of Kevlar thread in front of the notch on the boom and call it a day.
Looking forward to more reports!
E
Gallery Warmed by the Gulf Stream sparklet Aerial Photography 8 Dec 26, 2010 10:16 AM
Sold HPI 456 MB Gulf-Stream Jet-Stream Type G regional jet RTF package only $99! shschon Aircraft - Electric - Jets (FS/W) 5 Oct 25, 2008 10:57 PM
Sold Jet-Stream B7 Airliner by 456, NIB with Feigao Brushless Motors MinneFlyer Aircraft - Electric - Jets (FS/W) 3 Sep 01, 2008 01:16 PM
