Old Nov 20, 2001, 12:02 PM
Jeff Goldman is offline
Find More Posts by Jeff Goldman
Santa Maria, CA USA
Joined Mar 2001
Dare F9F Panther EDF conversion update, anyone?
I just picked up the Dare F9F Panther kit, and I'm wondering how any conversions or potential conversions to EDF are going for people?
For those who are still planning or are involved in a conversion, any tips on fan placement, ducting, etc? I was planning on using a Hacker B20 on an EDF300. And while it may not be the best plane to start off with, it's my first EDF (potentially). I like the challenge and idea, although if need be I suppose I could just throw a S400 in there (but that would be rather disappointing.)
Thanks for any help!
Jeff
Jeff Goldman is offline Find More Posts by Jeff Goldman
Old Nov 20, 2001, 04:12 PM
Larry Dudeck is offline
Find More Posts by Larry Dudeck
Larry Dudeck's Avatar
Williamsville, NY, USA
Joined Sep 2000
This F9F was designed as a s400 prop job.
I love EDF's but I will bet the F9F will perform better with a lowly 6v S400, DD, with a Gunther 125x110 spoon prop.
Which is no reason not to convert it.
But $ for $, amp for amp, an EDF will not perform as well as a prop.
Spend some $$$$$ and maybe
Keep the crew posted, this'll generate a lot of interest.
Larry Dudeck is offline Find More Posts by Larry Dudeck
Old Nov 20, 2001, 04:19 PM
Dave Wenzlick / Slickraft is offline
Find More Posts by Dave Wenzlick / Slickraft
(Batteries not included.)
Dave Wenzlick / Slickraft's Avatar
Mesa AZ
Joined Jun 2001
Bob Ruff had one at the field a couple of weeks ago but it wasn't quite ready to fly. He may have flown it by now. I'm sure he has some good conversion data for us.
Bob?? Reports?
Dave Wenzlick
Mesa AZ
Dave Wenzlick / Slickraft is offline Find More Posts by Dave Wenzlick / Slickraft
Old Nov 20, 2001, 05:48 PM
bruff is offline
Find More Posts by bruff
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
Conversion
I'm leaving for vactaion in Kansas. When I get back I will put up a web page with the conversion pictures using the WeMoTec 300 EDF. I have not flown yet. Waiting for thee rotor adapters.
Bob Ruff
bruff is offline Find More Posts by bruff
Old Nov 20, 2001, 06:28 PM
Mikey-flies is offline
Find More Posts by Mikey-flies
Alberta, Canada
Joined Sep 2001
Did you use the wemotec edf 300?
Mikey-flies is offline Find More Posts by Mikey-flies
Old Nov 20, 2001, 07:57 PM
Ed Waldrep is offline
Find More Posts by Ed Waldrep
Ed Waldrep's Avatar
Las Vegas, NV
Joined Dec 1996
If he's waiting for rotor adapters then the fan is probably the Wemotec Microfan, which I see on the site that EJF is also calling the EDF300.
I was talking to Ken Williams at K&A Models about two months ago and asked about his small F9F glass fuselage airplane for speed 400. He said that they are working on a verison for the EDF300 that will come with integrated ducting. Not sure when or if that will come out, but it sounds like a better setup, albeit more expensive.
Ed Waldrep is offline Find More Posts by Ed Waldrep
Old Nov 21, 2001, 08:10 PM
Alberta, Canada
Joined Sep 2001
I wonder how the weights will compare for the built up vs glassed version. Should be very nice either way.
Old Nov 18, 2007, 06:38 AM
salat is offline
Find More Posts by salat
Trying To Takeoff
salat's Avatar
Novosibirsk, Siberia
Joined Dec 2006
Any updates on projest?
Thank you,
Kostya
salat is offline Find More Posts by salat
Old Apr 28, 2008, 03:47 PM
Sgt Dudley is offline
Find More Posts by Sgt Dudley
Cincinnati OH
Joined May 2007
DARE F9F EDF conversion?
Hi:
I am about 80% complete on a EDF coversion of this kit. I decided to go with a HAOYE 51mm ducted fan with a little screamers BL motor. I reinforced the aft portion of the fuselage considerably, but the weight is still in the pretty good range for the anticapted thrust. I am planning on using a LtWt fiberglass covering. My only dilema currently is where to put the elevator servo. I installed a light bass wood battery/servo board in the forward part just under the canopy compartment. My plan is to use a 1100 -1500mAh 3S battery (15-20C). I also used a shaped balsa wood nose cone instead of the obvious prop spinner.
Sgt Dudley is offline Find More Posts by Sgt Dudley
Old Apr 28, 2008, 04:17 PM
salat is offline
Trying To Takeoff
salat's Avatar
Joined Dec 2006
Originally Posted by Sgt Dudley
Hi:
Hi Mike!
Would you mind to share some pictures???
Kostya
Article Aeronaut F9F Panther EDF review Mark Nankivil Electric Plane Talk 7 Jun 12, 2010 10:08 AM
Dare F9F Panther kscheck Electric Ducted Fan Jet Talk 7 Aug 13, 2008 04:50 PM
Help!!! with DARE F9F panther saint152 Electric Ducted Fan Jet Talk 10 Nov 27, 2007 04:55 PM
Sold Dare F9F Panther Kit Pilot44 Aircraft - Electric - Airplanes (FS/W) 16 Oct 17, 2005 09:40 AM
Fs Dare F9f Panther Nib RCPIG Aircraft - Electric - Airplanes (FS/W) 6 Feb 07, 2005 07:06 AM
