Old Dec 21, 2012, 08:39 AM
Outrunner195 is offline
Find More Posts by Outrunner195
Still Learning
Outrunner195's Avatar
Joined Nov 2012
Aurora 9 & FY 30A
I hesitate to start a thread but.... I have a new Aurora 9 and I cannot get it to recognize the FY-30A on a 3 position switch. I have spent 2 days playing with the Tx and researching the web but to no avail, so apparently it's so easy nobody else has had the issue.
From what I can gather:
it needs 1800-2100 uS (whatever uS is) for manual mode.
1200-1800 uS for 3D mode.
and 900-1200 for auto stabilization mode.
I am out of ideas.
Any help out there. (If so use small words )
Thanks in advance.
Outrunner195 is offline Find More Posts by Outrunner195
Old Dec 21, 2012, 03:59 PM
A.T. is offline
Find More Posts by A.T.
Joined Aug 2002
I am out of ideas.
Thanks in advance.
"1800-2100 uS (whatever uS is) for manual mode.
and 900-1200 for auto stabilization mode. "
are the steps usually set for servo and do not show as such on any Tx screen.
<snip refer post #4 below<snip
Not heard of FoxTech previously and there is no downloadable .pdf of manual or wiring schematic.
If FY30A also relies on a connection via the trainer port, then it may not work, please refer to recent
post #23034 regarding FPV and trainer ports.
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
A.T. is offline Find More Posts by A.T.
Last edited by A.T.; Dec 22, 2012 at 04:14 AM. Reason: suggestion replaced with post#4.
Old Dec 22, 2012, 12:46 AM
cat72xx is offline
Find More Posts by cat72xx
cat72xx's Avatar
USA, IL, Antioch
Joined Nov 2008
Not sure if this will help?
http://www.foxtechfpv.com/product/FY...ual%208.17.pdf
Or This with how to update.
http://shop.fyetech.com/dl/fy30aver3.pdf
cat72xx is offline Find More Posts by cat72xx
Last edited by cat72xx; Dec 22, 2012 at 12:52 AM. Reason: Add : http://shop.fyetech.com/dl/fy30aver3.pdf
Old Dec 22, 2012, 04:05 AM
A.T. is offline
Joined Aug 2002
Originally Posted by cat72xx View Post
Thank you, makes a big difference, especially to view page 7 as attached.
Given 900<2100us(ms) is a variance of 1200 us.
thus should be able to set switch 900<1200 = 25%, 1200<1800 = 75% & 1800 < 2100 = 100%
Use of a D/R type function mentioned post #2 is not possible with this set up.
Start new model memory and set up aircraft with aileron (x 1 see ,jpg), tail type etc then go to
"Channel" screen and assign Ch5 to Gyro & switch "E",positions are oddly numbered 0,1 & 2..
(If Ch:5 had been auto assigned to Gear, then either can be re-assigned to another port
- not essential Ch:5 be used provided fly lead is into new port)
Enter Gyro menu and set switch E position 0 as 25%, position 1 as 75% and position 2 as 100%.
As mentioned, have not heard of this unit previously, so as always when setting up any new model,
try suggested settings without any rod attached to any servo.
In the event above does not assist, please contact the designer direct in terms their manual page 1, copy attached.
Alan T.
For Sale Slightly used FY-20A and NIB FY-30A i3dm FPV Equipment (FS/W) 1 Dec 20, 2012 09:56 AM
Sold FY-20a and FY-30a Metal Case Adidas4275 FPV Equipment (FS/W) 3 Apr 25, 2012 10:51 PM
For Sale FY-20a and FY-30a Metal Case Adidas4275 Aircraft - General - Miscellaneous (FS/W) 0 Apr 25, 2012 08:47 PM
For Sale FY-20a and FY-30a Metal Case Adidas4275 Aircraft - General - Miscellaneous (FS/W) 0 Apr 25, 2012 08:46 PM
