guillows kit 505 me109 rc
i'd like to share this build info.sorry for the poor pics.i chose the 16 1/2 inch 109 kit as i figured it would be a light weight air frame to transplant the running gear from a park zone ultra micro p-51 into.the flying weight is right at 2 1/8 oz. and that is with a 1/4 oz. nose weight.i used hangar9 park lite covering on this build and really liked it that alone saved nearly 1/4 oz. i used all of the kit wood and in this one i think some of the balsa was mixed up with oak
.but it was mainly for parts which were higher strass that i would have used thin ca to beef up anyhow.i used the same basic operation for the ailerons as the pz p-51 uses.
There isn't much to be gained by running a micro brushless motor on a single cell.
These conversions are at the upper end of the weight range already, and I feel a 2 cell battery along with the additional weight of the esc would push them to the point of not flying well. Did you see the video of my FW 190? It flies in a scale manner and you really cant tell how small the model is until I pick it up at the end. http://www.rcgroups.com/forums/showt...1544230&page=9 Glenn |
This big thing to do with any of these Rubber conversions is bust out the dremel tool or Xacto blade and remove all of the excess balsa aft of the CG.
The Keels and Fuselage formers are so thick because they have to withstand the crushing forces of a Rubber band. At least of a third of the balsa in the formers and keels behind the CG is dead weight. Forward of the CG, the extra material can help with crash resistance, but aft of the CG, dead weight. |
Latest blog entry: AR6400 guillows Space Shuttle
glenn your prediction is spot on.it flys well but under powered. so i adapted it with a gws 5043 prop.i havnt flown it but i can really feel the difference static testing it.i found that a small rubber electrical groment and a piece of the straw from a can of carb cleaner worked great for an adapter.the small red straw/tube threaded on nicely.i'm working on a spinner.
now the wait .it may be weeks before we see any weather near freezing or warm enough to fly it.
| Thread Tools | |
| Discussion About Converting Guillows Kits to Electric RC | E-Challenged | Scale Electric Planes | 12 | Dec 17, 2012 09:22 AM |
| Discussion How to Hand Launch RC Foamie Plane Mustang GWS Me109 Skyfun Delta Beaver | TheLeabres | Parkflyers | 0 | Jun 10, 2012 05:03 AM |
| Discussion Guillows Bf-109 Kit 505 Conversion | admiral_adonis | Indoor and Micro Models | 28 | Sep 28, 2011 05:32 AM |
| Build Log Messerschmitt BF-109 Guillows Kit 505 | Tuctronics | Indoor and Micro Models | 18 | Sep 27, 2011 09:28 AM |
| For Sale Me109 Image CD of 109G-2 black six 505 pics | 109Mechanik | Aircraft - General - Miscellaneous (FS/W) | 5 | Jul 14, 2006 02:06 PM |
