Old Dec 21, 2012, 12:05 PM
jpconard is offline
Find More Posts by jpconard
Joined Feb 2007
How is it holding up to crashes? Fairly durable? Comparable to V911?
jpconard is offline Find More Posts by jpconard
Old Dec 22, 2012, 06:36 AM
jameschen072 is offline
Find More Posts by jameschen072
The flightless bird
jameschen072's Avatar
Joined Aug 2004
@jpconard, it's very durable, but I wouldn't say that it's more durable than the V911...the higher head speed of CP helis make broken blades , among other things, far more likely (in fact I've broken one already). That said, I crashed it into a tree at full speed...No damage to the V922 even though the branch was completely shredded and stuck in the swashplate and all..
I would say that it's much more durable than my Mini CP, which is already very durable in its' own right.
jameschen072 is offline Find More Posts by jameschen072
Latest blog entry: The Fei-Lun FT011 Review
Old Dec 22, 2012, 02:19 PM
gordonzo is offline
Find More Posts by gordonzo
Different fly 4 different guy
gordonzo's Avatar
Joined Jan 2011
@jameschen072
Am I correct in assuming that you do not have a TH9X?
The compatibility is one answer I have been waiting for.
regards . . . g
gordonzo is offline Find More Posts by gordonzo
Old Dec 22, 2012, 06:52 PM
FyreSG is offline
Find More Posts by FyreSG
Vids: YouTube.com/FyreSG
FyreSG's Avatar
Singapore, Singapore
Joined Apr 2012
James, Aaron and KKDDMM have confirmed 9X incompatibility when the helicopter just made known to the public. When more details of the helicopter was revealed, we know it is actually a HiSKY FBL100, that uses the HiSKY protocol. The only way for 9X compatibiltiy is via the HT8 adapter.
If you're asking about HT8 compatibility, we'll have to wait for sometime as the news about the new version of HT8 was "just" released a couple of days. The old one may not work as well due to the exclusion of power supply.
FyreSG is offline Find More Posts by FyreSG
Old Dec 23, 2012, 08:02 AM
The flightless bird
Joined Aug 2004
yup, BG wants to let me test my 922 with the new version of the module. FyreSG is correct when he said that the 9X is incompatible unless you use the hisky module
Old Dec 23, 2012, 12:51 PM
variantman is offline
Find More Posts by variantman
United States, TN, Knoxville
Joined Jun 2012
What kind of flight times? How does this compare to the quadcopters?
variantman is offline Find More Posts by variantman
Old Dec 23, 2012, 02:13 PM
gordonzo is offline
gordonzo's Avatar
Joined Jan 2011
Thanks for the info. I somehow missed that.
Anyone know which tx's the HT8 will hookup with? Blade? Walkera? Turnigy? . . . . or did I also miss that info . . . I am gettin' old.
regards . . . g
Old Dec 24, 2012, 07:38 AM
mono is offline
Find More Posts by mono
mono's Avatar
Joined Aug 2008
Gordonzo
There isn't much info around on the HT8, other than it connects to Futaba/JR/Walkera/Others, but they don't say if it functions with an assortment of models from each brand or if it's just pot luck.
Chances are it might be okay with most as it's only tapping the signal from the sim port. I can verify it works with the 9x as I found this document on the 9x forums...
FBL100 HT8 9x setup
mono is offline Find More Posts by mono
Old Dec 24, 2012, 07:41 AM
erdnuckel2 is offline
Find More Posts by erdnuckel2
erdnuckel2's Avatar
Joined Mar 2009
very curious how that one is gonna develop into the future ...
Old Dec 24, 2012, 08:49 AM
The flightless bird
Joined Aug 2004
@variantman, I am getting 2 minutes in the -15 degrees C weather we're having here :P so I guess I'll leave it for those in warmer climates to give us a more accurate flight time.
I've found that the tail doesn't hold as well (partly due to the cold weather I guess) as the Mini CP under demanding circumstances... and it does get affected by wind a bit more than my mini CP as well... so I guess that calls for more testing...
Merry Christmas to all!
Old Dec 24, 2012, 09:56 AM
FyreSG is offline
FyreSG's Avatar
Joined Apr 2012
From what I've been reading, the tail holding issue is a big concern right now. And James experienced it as well. Sounds bad.
Old Dec 24, 2012, 11:27 AM
zadaw is offline
Find More Posts by zadaw
Hong Kong
Joined Jan 2010
I am actually getting to really like this heli.The heli was definitely quite affected by the wind and the tail did not hold that well in demanding circumstances e.g. pitch pumps. It can definitely do all the mild 3D moves I can do on a larger heli. Its durability is just amazing. It is completely unscathed after nearly 30 crashes, most of them inverted.
However, I can definitely it causing problems with beginners. The transmitter does not have dual rates let alone expo. The heli is quite twitchy at times and i would have liked to have some expo. Also, its "normal curve" seems to be quite aggressive. The heli does not jump when you switch to advance 3D mode while in the air. This suggests that the upper half of the throttle and pitch curves are identical between normal and 3D mode. So I think this heli that is more suitable for experienced fliers rather than beginners.
zadaw is offline Find More Posts by zadaw
Old Dec 24, 2012, 07:06 PM
FyreSG is offline
FyreSG's Avatar
Joined Apr 2012
This is a very good observation.
Old Dec 25, 2012, 02:48 AM
macem is offline
Find More Posts by macem
Joined Sep 2012
However, I can definitely it causing problems with beginners. The transmitter does not have dual rates let alone expo. .... So I think this heli that is more suitable for experienced fliers rather than beginners.
... I flew the turnigy fbl100 - which is exactly the same as the hisky fbl100 and v922 - for some months and some 100 flights now and i get more and more used to the throttle and pitch-curves of the non-programmable tx. and iŽd agree with zadaw - its a very durable little bird and if you like to do 3d, its better you are a experienced 3d-pilot already. esp sometimes some unremarkable damages like lightly splitted mainshafts or tail shafts or servo-wear cause double-twitchy-effects in flight behavior...
but as long as you dont touch the sticks to hard its also very stable doing some basic movements like fast forward, eights, circles, hovering
macem
macem is offline Find More Posts by macem
Old Dec 25, 2012, 08:45 PM
TFMeouch is offline
Find More Posts by TFMeouch
Joined Dec 2007
Speaking as a beginner to CP helicopters, I must say this is not as bad as it was made out to be. My experience after the twitchy Solo Pro 100D taught me to fly a CP carefully. Indeed, this heli might be difficult for someone without any experience with FBL setup. The heli feels jumpy at certain throttle points. This is the part where a programmable transmitter may help. However, a person with sufficient flight times with a FBL heli might not find this to be a great deal.
I have yet to try out inverted flight. I have never had any experience with 3d modes, so I must be mentally prepared to crash my heli during the trial. At my current skill level, I can only manage to hover it properly and move it around the room gently. Its quite different from flying a flybarred heli.
TFMeouch is offline Find More Posts by TFMeouch
Mini-Review WLToys V911 review (Solo Pro/Trex 100 clone) jameschen072 Micro Helis 24738 Jun 22, 2016 01:11 PM
Mini-Review WLtoys V929 Beetle Ladybird Quad Mini-Review FyreSG Mini Multirotors 3824 Jan 10, 2016 08:05 AM
Mini-Review WLToys Beetle quad review jameschen072 Mini Multirotors 5149 Oct 29, 2014 01:57 AM
