Old Dec 20, 2012, 08:02 PM
Esprit Model is online now
Find More Posts by Esprit Model
espritmodel.com
United States, FL, Melbourne
Joined May 2010
New Jeti Spin Pro 80/100/160 SHED Slim ESCís w/5A BEC
After talking for last 3 month with Jeti engineers, we just finally received, brand new Jeti Spin Pro 80A, 100A, 160A ESCs SHED (Slim/Hotliner/Electric Ducted fan). They are all good up to 8S with 5A/5.5V switching BEC, fully programmable with built in data logger and very narrow, 27mm wide architecture. Also price is very competitive and as you know all Jeti products have 2 years warranty and 50% replacement policy.
Check out the size of the capacitor on the 160A ESC.
Zb/Esprit Model
Jeti Spin 80 $120.00
Jeti Spin 100 $135.00
Jeti Spin 160 $175.00
Esprit Model is online now Find More Posts by Esprit Model
Site Sponsor
Old Dec 21, 2012, 07:52 AM
sebbe is offline
Find More Posts by sebbe
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
What is the burst rates ?
they look nice,
About the capacitor on the 160A, WHY? it is MUCH better to have smaller ones the ONE big,, is this only for saving space?
sebbe is offline Find More Posts by sebbe
Old Dec 21, 2012, 06:35 PM
Desert Fox is offline
Find More Posts by Desert Fox
"In Thrust I Trust"
Desert Fox's Avatar
United States, GA, College Park
Joined Nov 2011
Jeti Spin Pro 160 Amp SHED Brushless ESC
Hello All,
Data taken from Esprit Model website.
ESC
Jeti Spin 160
Manufacturer Jeti
Applications
Heli/Airplanes/Sailplanes
Special Features
Data Logger w/Spin BOX
Cont/Max Amp 160/176A
Cells NiMH/NiCD 6-24 cells
Cells Li-poly 2-8 cells
Voltage 5-34V
Programming
Fully Programmable
Type/Max BEC (A) Switching/5A
Max #Servos/V 8/5.5V
Dimensions: 85mm x 27mm x 23mm
Weight: 95g
Looking for the manual for this model.
Desert Fox Heli
Desert Fox is offline Find More Posts by Desert Fox
Old Feb 10, 2013, 09:50 AM
goryc is offline
Find More Posts by goryc
Italy, Sicilia, Messina
Joined Apr 2011
I wanted to know if the brake is programmable as the 99 and the 125.
Are programmable with JetiBox?
Is there a manual that I can see to appreciate its characteristics?
thanks
Gory
goryc is offline Find More Posts by goryc
Old Jun 27, 2013, 04:07 PM
fariasda is offline
Find More Posts by fariasda
Joined Sep 2012
this esc (160) supports phasor jeti 2026 1D ,3s and 16x17 prop?? for F5f, only 3-4sec of run
fariasda is offline Find More Posts by fariasda
Old Jun 27, 2013, 08:40 PM
espritmodel.com
Joined May 2010
Yes it will.
Site Sponsor
Old Jul 22, 2013, 02:35 PM
GT2000 is online now
Find More Posts by GT2000
UK
Joined Mar 2005
Can I use the 160 pro with a separate receiver battery? If yes how do I do it?
Thank you
GT2000 is online now Find More Posts by GT2000
Old Jul 23, 2013, 10:55 AM
fariasda is offline
Joined Sep 2012
Thank you
disconect de red wire the esc to receiver
Old Jul 24, 2013, 03:57 PM
UK
Joined Mar 2005
Thanks for your reply which is exactly what I thought but the response that I got from Jeti
it is possible to use puffer battery with S160 BEC.
Use Schottky diode to separate both power sources.
did nothing but confuse me, clearly something got lost in the translation so I am still wondering if it is just a simple case of removing the red wire or is there more to it.
Old Aug 05, 2013, 05:30 PM
fariasda is offline
Joined Sep 2012
I bought the spin pro 160 and the jeti box , today I see with horror that DOES NOT MEASURE THE CURRENT MAX, very bad people of Jeti
Old Aug 05, 2013, 09:25 PM
mustflynow2 is offline
Find More Posts by mustflynow2
The Sequel
mustflynow2's Avatar
Australia, VIC
Joined Sep 2011
Danial I just hope your backfire is ok? I hear some positive response from people and Jeti service. Sorry you have bad situation. Brendan
mustflynow2 is offline Find More Posts by mustflynow2
Old Aug 06, 2013, 06:49 AM
Mark Haigh is offline
Find More Posts by Mark Haigh
Mark Haigh's Avatar
Barnsley, Great Britain (UK)
Joined Dec 2000
Thanks for your reply which is exactly what I thought but the response that I got from Jeti did nothing but confuse me, clearly something got lost in the translation so I am still wondering if it is just a simple case of removing the red wire or is there more to it.
Stu,
Removing the red wire should be OK. It sounds like Jeti are talking about having a buffer battery and the BEC connected together by 2 forward biased diodes which will prevent current flow from BEC to battery and vice-versa.
Mark.
Mark Haigh is offline Find More Posts by Mark Haigh
Old Aug 06, 2013, 08:21 AM
fariasda is offline
Joined Sep 2012
hello Brendan, si my backfire is perfect,I am disillusioned that not measure amps the jeti box
Old Aug 06, 2013, 11:58 AM
UK
Joined Mar 2005
Thanks for your reply Mark. Having had a further drawing from Jeti it seems that you are right as it shows the connection to the rx as still having all wires connected and still using a separate rx battery. I'm getting pretty close to testing this thing so we'll soon find out for sure.
Thanks again
Stu
Old Aug 06, 2013, 03:34 PM
The Sequel
Australia, VIC
Joined Sep 2011
It is good news, you have no inflight problem. You are not happy with your esc?
I buy my first phasor race, but I have not used yet. I will use cc phoenix when my backfire arrives, good luck with your issue
Is this the device you use to read log from esc?
http://www.espritmodel.com/jeti-tele...rogrammer.aspx
For Sale NIP Hobbywing 60& 80 AMP ESC'S W/Bec Deans Attached Forrest Gump 23 Aircraft - Electric - Power Systems (FS/W) 4 Jan 02, 2013 02:51 PM
Discussion New Jeti Spin Pro 80/100/160 SHED Slim ESCís w/5A BEC Esprit Model Electric Ducted Fan Jet Talk 0 Dec 20, 2012 07:56 PM
For Sale NIP Hobbywing 60& 80 AMP ESC'S W/Bec Deans Attached Forrest Gump 23 Aircraft - Electric - Jets (FS/W) 3 Dec 14, 2012 08:52 AM
For Sale NIP Hobbywing 60& 80 AMP ESC'S W/Bec Deans Attached Forrest Gump 23 Aircraft - General - Miscellaneous (FS/W) 3 Dec 11, 2012 08:37 AM
Sold TopFire 45A Brushless ESC w/ 5A BEC NEW IntheTubeDeep Aircraft - Electric - Jets (FS/W) 0 Nov 26, 2012 02:11 PM
