Old Jan 08, 2013, 09:03 PM
variantman is offline
Find More Posts by variantman
United States, TN, Knoxville
Joined Jun 2012
Thanks, Jim. Using some of that stuff would give me a mad scientist feeling. I think I like it.
variantman is offline Find More Posts by variantman
Old Jan 08, 2013, 10:58 PM
cyberbillp is offline
Find More Posts by cyberbillp
cyberbillp's Avatar
United States, FL, Melbourne
Joined Mar 2012
Lamp
Originally Posted by variantman View Post
MO, where's the best place to cut the wires to the old motor? It looks like it will be a pain fitting in soldered wires near the bottom with that cap.
I'm going to have to invest in a good Magnifying lamp. My eyes aren't what they used to be and my house lighting is terrible.
Articulated floor standing magnifier lamp: $35 Lowes.
Got one. Love it.
cyberbillp is offline Find More Posts by cyberbillp
Old Jan 09, 2013, 02:39 AM
John_Edward is offline
Find More Posts by John_Edward
Darwin of quadcopter canopies
John_Edward's Avatar
Finland, Espoo
Joined Jun 2011
Coffee is the enemy of good soldering work.
I had a friend in school who was a caffeine addict, and one year we had our electronics classes at 15:00.
Poor guy probably spent more time poking the board than the point he was supposed to solder.
John_Edward is offline Find More Posts by John_Edward
Old Jan 09, 2013, 08:00 AM
gentle ben is offline
Find More Posts by gentle ben
semper mitis
gentle ben's Avatar
Paducah, Kentucky
Joined Nov 2004
In a different life I taught microsurgery. The most shaking was caused by too much and by to little caffeine. The brain was used to seeing a certain level. To maintain steady hands we recommended maintaining constant levels of caffeine intake.
gentle ben is offline Find More Posts by gentle ben
Old Jan 09, 2013, 09:15 AM
BD Murdock is offline
Find More Posts by BD Murdock
Quad guys are 4x the fun :)
BD Murdock's Avatar
United States, CO, Longmont
Joined Mar 2012
One of the things I'm known for among family and friends is not leaving well enough alone...fixing something that's not broken as it were.
With that in mind I removed the LED's intent on replacing with NAV colors.
I'm here now to tell you this was not a good idea. After de-soldering the LED you're left with about 1/8" to 3/16" of 32 or 34 gauge magnet wire. With the motor mount and LED mount in place, soldering is possible but far less than ideal. The really strange thing though is that I was able to get two red's on port side working but then when I went with green on the front starboard side...nothing. I tried one of the weakest least demanding LED's I have and it barely lit up. Same result with rear starboard side. There's not enough juice and I can't figure out why. If anything there should've been a difference between the two red's on port side, back and front because that's obviously where the color difference happens with the stock LED's. There shouldn't be any difference between front left and right as far as resistance goes but there is.
I'm no electrical engineer mind you but this set up is odd to say the least.
BD Murdock is offline Find More Posts by BD Murdock
Old Jan 09, 2013, 09:30 AM
MassiveOverkill is offline
Find More Posts by MassiveOverkill
MassiveOverkill's Avatar
United States, SD, Custer
Joined Feb 2011
BD, are you sure you got enough of the varnish off when you resoldered? Can you try plugging into the other auxilliary port on the RX board? Polarity on the LEDs correct?
MassiveOverkill is offline Find More Posts by MassiveOverkill
Site Sponsor
Latest blog entry: MassiveRC ZMR PDB
Old Jan 09, 2013, 09:52 AM
Urufu_Shinjiro is offline
Find More Posts by Urufu_Shinjiro
Joined Sep 2008
MO, sorry to bug you but any word on those batteries yet? I plan on ordering the V202 today and I can order extra batteries at a later date but I would hate to place my V202 order this morning and see the new batteries on the site this afternoon, lol.
Urufu_Shinjiro is offline Find More Posts by Urufu_Shinjiro
Old Jan 09, 2013, 10:05 AM
Joined Feb 2011
Hey Urufu, do you mean the Turnigys or the stock 25C?
Speak of the Devil............Turnigys just arrived!
Site Sponsor
Old Jan 09, 2013, 10:19 AM
BD Murdock's Avatar
Joined Mar 2012
Originally Posted by MassiveOverkill View Post
BD, are you sure you got enough of the varnish off when you resoldered? Yep Can you try plugging into the other auxilliary port on the RX board? Could but haven't yet Polarity on the LEDs correct?Yes
After more thought I don't know if there are differeing resistance values for the stock blue & greens, my guess is there are but without de-wiring everything I can't tell if that's handled in the wiring, on the board, or both. I think there's X amount of juice allocated to the LED's, the two red's I soldered on came close to that amount, leaving only a tiny amount for the others. I'm experimenting now with different reds. You guys that know what you're doing with this stuff should be ROTFLYAO...I would be too.......reason being I don't own a voltage meter. Guess I'm off to Radio Shack lol. Checking with a meter should tell me everything I need to know.
Old Jan 09, 2013, 10:59 AM
Finland, Espoo
Joined Jun 2011
If you try to put different leds parallel to each other, sometimes one of them takes all the current and others don't light up at all. You pretty much always have to make sure that different leds are behind their own resistors.
Because the v202 normally has two same at front and two other at the back, chances are they are wired parallel like that.
So, switch both of the reds so that they are plugged to where the front leds were, and then the green ones to the back.
Old Jan 09, 2013, 11:03 AM
Joined Sep 2008
Well, I meant the stock 25C but if the Turnigys work in the V202 then I'll grab one or two of those as well.
Old Jan 09, 2013, 11:09 AM
Joined Feb 2011
They're all wired to the same power port by default
Turnigy's will work but you'll need to insert some foam strips in the batteryholder to take up the slack as they are thinner and longer than stock.
Site Sponsor
Old Jan 09, 2013, 12:07 PM
Joined Sep 2008
Would it be a better idea to just go with the batteries it comes with until the spare 25C's are in and then order extras?
Old Jan 09, 2013, 12:09 PM
semper mitis
gentle ben's Avatar
Paducah, Kentucky
Joined Nov 2004
I used the corners of Styrofoam home delivery boxes from Outback ribs. Their barbecue sauce will allow the dog to find the quad in high grass.
I like the Nano-techsbecause you can shift the placement and lock them in with foam.
Old Jan 09, 2013, 12:28 PM
stonecutter is offline
Find More Posts by stonecutter
Sir Crashalot
stonecutter's Avatar
Joined Oct 2011
Don't have an answer for the apparent voltage difference. But I think swapping one pair of booms diagonally would accomplish what you want, wouldn't it? (Assuming swapping booms is easier than soldering led's.)
stonecutter is offline Find More Posts by stonecutter
Discussion WL Toys V959/V202/ SH 6047 Scorpion dankar04 Mini Multirotors 10 Apr 25, 2015 02:22 AM
Discussion Micro Quad V202 RTF for 26.68$ ratonxi Hot Online Deals 57 Jan 24, 2013 12:23 PM
Discussion WL Toys V202 "50% off" ??? stifa Mini Multirotors 3 Dec 08, 2012 10:50 AM
Discussion V202, which canopy do you prefer? MassiveOverkill Mini Multirotors 16 Dec 07, 2012 02:29 PM
Discussion Soodohobby 2.4G Mini 6 aixs Gyro Scorpion Quadcopter WL V202 Quadcopter MQ80 Multirotor Talk 0 Nov 26, 2012 11:01 PM
