Old Jan 08, 2013, 01:43 PM
stonecutter is offline
Find More Posts by stonecutter
Sir Crashalot
stonecutter's Avatar
Joined Oct 2011
Originally Posted by variantman View Post
1/100th of a penny of material probably would of saved me. I was getting too cocky with that upside down flip thing. Those MP props set up pretty high on the motor pin. Beware.
MO, you should sell those slices of capri straws 10 for a dollar or something. Easy money.
I do all the damage to my quads flying in my house. I almost wish I had carpet now.
Don't give him any crazy ideas, lazy dudes like myself might just go for that.
stonecutter is offline Find More Posts by stonecutter
Old Jan 08, 2013, 02:55 PM
John_Edward is offline
Find More Posts by John_Edward
Darwin of quadcopter canopies
John_Edward's Avatar
Finland, Espoo
Joined Jun 2011
Could someone crack open one of the controllers and check if there is a separate transmitter board, and compare the layout of the main PCB to other WLtoys transmitters ? Preferably taking a few high res photos too.
I have a feeling that most of these radios use the same protocol to talk to these TX modules, and if we could get one of them to work with a 9X, we could get all of them.
I've had no luck yet, but I should get access to an oscilloscope later this week so I'm going to have a go with the Vitality H36 one.
John_Edward is offline Find More Posts by John_Edward
Old Jan 08, 2013, 03:03 PM
Sir Crashalot
Joined Oct 2011
The H36 we know already is 9x compatible, it's the v202 that isn't.
Old Jan 08, 2013, 03:10 PM
Finland, Espoo
Joined Jun 2011
I know.
But if I get the TX module from the H36 radio (which I own) to work with my 9X, then I should get any other module to work as well.
Old Jan 08, 2013, 04:06 PM
MassiveOverkill is offline
Find More Posts by MassiveOverkill
MassiveOverkill's Avatar
United States, SD, Custer
Joined Feb 2011
I did push the bottom back up. Still doesn't work.
I just looked and I don't think MO sells complete motor arms. Oh noesssss. Soldering.
Unfortunately the only thing the motor plugs are good for on the V939\V202 are for replacing the RX board. You have to solder to swap out the motors due to the thin channel for the wires.
http://www.massiverc.com/PrestaShop/...ard-stock.html
MassiveOverkill is offline Find More Posts by MassiveOverkill
Site Sponsor
Old Jan 08, 2013, 04:13 PM
Joined Feb 2011
I know.
Left is V202, Right (background) is V939 and the H36 uses the exact same TX module:
Site Sponsor
Old Jan 08, 2013, 04:20 PM
Stevez1kart is offline
Find More Posts by Stevez1kart
Trees are bad
Stevez1kart's Avatar
United States, NE, Omaha
Joined Sep 2012
Originally Posted by MassiveOverkill View Post
Now that's funny! BTW for that price you need to cut them up for me.
Stevez1kart is offline Find More Posts by Stevez1kart
Old Jan 08, 2013, 04:50 PM
Finland, Espoo
Joined Jun 2011
I see that the 4 first pins are 3.3V, SI, SCLN and SO, but what after that ?
Are the 4 pins after that all GND, and then the last one is CSN ?
Old Jan 08, 2013, 05:12 PM
variantman is offline
Find More Posts by variantman
United States, TN, Knoxville
Joined Jun 2012
I wonder if one of the motors on my U816 would work? I'd still want to order a replacement for the Udi though. That and some more MP props and those rubber feet for the X4.
I'll probably skip MO's prop guards. A bit pricey.
variantman is offline Find More Posts by variantman
Old Jan 08, 2013, 05:19 PM
Joined Feb 2011
Your UDI motor should work Variant. We'll hopefully have the rubber feet in on Friday.
I updated the original Prop Motor Guard post, but if you want to make a bunch of these and have consistent size:
Site Sponsor
Old Jan 08, 2013, 05:39 PM
Trees are bad
Joined Sep 2012
I had to google Warts Gniknird, still laughing.
Old Jan 08, 2013, 06:03 PM
Joined Jun 2012
MO, where's the best place to cut the wires to the old motor? It looks like it will be a pain fitting in soldered wires near the bottom with that cap.
I'm going to have to invest in a good Magnifying lamp. My eyes aren't what they used to be and my house lighting is terrible.
Old Jan 08, 2013, 06:49 PM
Joined Feb 2011
Hey bud,
You'll see that they soldered on the plugs to the end of the motor leads, which is covered by heat shrink. Peel the heat shrink back and cut at the solder joint.
Don't pull the old motor wires out. Cut them at the can and use one of the old wires to pull the two new motor leads through (may have to initially solder the ends as tape will take up too much space). Once they're through the boom, solder back on the motor plug.
Site Sponsor
Old Jan 08, 2013, 06:56 PM
Joined Jun 2012
Ok, thanks. I'll try it tomorrow when a get a mag lite. Seems like it's a must for this hobby.
Old Jan 08, 2013, 07:36 PM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
V,
Yep. Soldering requirements at "this life's stage": Bright light. Higher power readers. Magnifying lens hood. Magnifying jewelers glasses.
And also a good night's sleep and no morning coffee
Cheers,
Jim
Quadrocopter and Tricopter Info Mega Link Index
jesolins is offline Find More Posts by jesolins
Discussion WL Toys V959/V202/ SH 6047 Scorpion dankar04 Mini Multirotors 10 Apr 25, 2015 01:22 AM
Discussion Micro Quad V202 RTF for 26.68$ ratonxi Hot Online Deals 57 Jan 24, 2013 11:23 AM
Discussion WL Toys V202 "50% off" ??? stifa Mini Multirotors 3 Dec 08, 2012 09:50 AM
Discussion V202, which canopy do you prefer? MassiveOverkill Mini Multirotors 16 Dec 07, 2012 01:29 PM
Discussion Soodohobby 2.4G Mini 6 aixs Gyro Scorpion Quadcopter WL V202 Quadcopter MQ80 Multirotor Talk 0 Nov 26, 2012 10:01 PM
