Old Jan 03, 2013, 05:06 PM
stonecutter is offline
Find More Posts by stonecutter
Sir Crashalot
stonecutter's Avatar
Joined Oct 2011
Originally Posted by SlyKYFox View Post
The yaw rate is the same for me, a lot slower than i'm used too(still fun to fly though). How long of flight times are you guys getting? I noticed after 6 min, just hovering around, the pack comes off at 3.7v. I don't think you should take them lower than that correct?
With the stock battery, I doubt I get 6 minutes combined flight time before the quad gets noticably sluggish. I would estimate more like 5 minutes, which is more than adequate for my needs. If anything, I would wish for a battery that provides more punch, rather than more flight time.
stonecutter is offline Find More Posts by stonecutter
Old Jan 03, 2013, 05:11 PM
BD Murdock is offline
Find More Posts by BD Murdock
Quad guys are 4x the fun :)
BD Murdock's Avatar
United States, CO, Longmont
Joined Mar 2012
I've noticed the same indoors, the 202 is not a pirouetting ballerina by any stretch but by the same token I haven't had it outside yet and I've seen CyberbillP's vid on youtube where he does a full roll while in FFF. That's what I wanna do right there.
BD Murdock is offline Find More Posts by BD Murdock
Old Jan 03, 2013, 05:43 PM
RoboHeli is online now
Find More Posts by RoboHeli
Safety : practice & promote!
RoboHeli's Avatar
Joined Dec 2011
Hey MO,
When are you going to sell the V202 canopies by themselves? I wanna try it out on my H36.
RoboHeli is online now Find More Posts by RoboHeli
Old Jan 03, 2013, 07:15 PM
cyberbillp is offline
Find More Posts by cyberbillp
cyberbillp's Avatar
United States, FL, Melbourne
Joined Mar 2012
OMG - That video is awesome!
So tonight, I replaced all four props, tightened all the screws, removed the FC board and mounted it with foam, and flew, expecting it to not drift and.....
drum roll....
no change at all. *sigh*
So this is not a thumbs-off dead motionless bird. It's QUITE possible that outdoors, away from all the propwash blowing around the office/bedroom here, it may get el-perfecto. But I don't think so. It's no work at all to hold the quad still, but you have to have you thumbs on it like Massive O. said. He's so smart. lol
Oh, to extend flying time move the LED connector to the aux port and turn off the LED's with the right TX button.
cyberbillp is offline Find More Posts by cyberbillp
Old Jan 03, 2013, 07:21 PM
vermifax is offline
Find More Posts by vermifax
Joined Nov 2012
Does anyone know how quickly you have to have it level once you connect the battery?
vermifax is offline Find More Posts by vermifax
Old Jan 03, 2013, 07:22 PM
MassiveOverkill is offline
Find More Posts by MassiveOverkill
MassiveOverkill's Avatar
United States, SD, Custer
Joined Feb 2011
Originally Posted by RoboHeli View Post
Hey MO,
What, you mean this?
http://www.massiverc.com/PrestaShop/...on-canopy.html
MassiveOverkill is offline Find More Posts by MassiveOverkill
Site Sponsor
Latest blog entry: MassiveRC ZMR PDB
Old Jan 03, 2013, 07:27 PM
Joined Feb 2011
Not very long 3-4 seconds, I take that back.........you can hold the quad vertically and it won't start the calibration process until it's somewhat level. So once it's level, you have 3-4 seconds
Site Sponsor
Old Jan 03, 2013, 07:31 PM
Sir Crashalot
Joined Oct 2011
Actually, you can put it in any position, even upside down, and it will fly fine; as long as you don't move it when binding.
Old Jan 03, 2013, 07:38 PM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
Hi V,
Since the V202 has a factory pre-set accelerometer, the level it has when binding is not important. When you turn on the Tx, then power the V202, the red LED blinks continuously until you push up the throttle, then put it to minimum. That is when it binds and arms and zeroes the gyros. So you have plenty of time to put it down and leave it still before raising and lowering the throttle. You will see little if any difference even if you armed it upside down or on a 45 degree angle. It will still level as long as it was motionless when it was armed.
Edit: Yep...basically the same info as the Gents above. I type sloooooooowwwww
Cheers,
Jim
Quadrocopter and Tricopter Info Mega Link Index
jesolins is offline Find More Posts by jesolins
Old Jan 03, 2013, 07:43 PM
Joined Feb 2011
Guys check again.......there's a fast flashing LED, which then turns to a slow flashing. The slow flashing is the quad waiting for bind. The fast flashing does not go away until I have the quad level.
Site Sponsor
Old Jan 03, 2013, 07:55 PM
RoboHeli's Avatar
Joined Dec 2011
Originally Posted by MassiveOverkill View Post
Win! Thanks a lot.
Old Jan 03, 2013, 09:27 PM
dmirtygorachyov is offline
Find More Posts by dmirtygorachyov
Joined Jan 2013
Hey guys, Ive been lurking around and eventually decided to get the v202. It just arrived and im wondering if you guys know how to fix this issue I have. Whenever I set my remote control to 100% rudder setting, it always unbinds and refuses to bind with my v202.
Im using the RTF remote control so it shouldnt be acting this way should it? It works perfectly on 20, 40, 60 and 80. Can someone help me out? Thank you <3
dmirtygorachyov is offline Find More Posts by dmirtygorachyov
Old Jan 03, 2013, 10:27 PM
Sir Crashalot
Joined Oct 2011
So you mean when you click the top left button till it gets to 100%, the already bound quad becomes unbound?
Old Jan 03, 2013, 10:35 PM
Joined Jan 2013
Yes, and then when i switch to 20 percent, it binds again instantly. The red light flashes on the quad when i set it to 100 percent like its looking for a controller. Is my controller dead ish?
Old Jan 04, 2013, 05:20 AM
jesolins is offline
Joined Feb 2007
D,
How much trim and in what channels do you have when this happens? This probably has something to do with the Tx endpoints on one or more of the channels getting too far out of tolerance for the flight controller when the Tx is in the 100% setting and inducing disarming.
NOTE: I just tried setting all variations of trims to the max at 100% and could not duplicate your issue. So unless your Tx or possibly Rx is outof tolerance, that is not likley your problem. Check to see that your antenna is soldered well to the flight controller.
Cheers,
Jim
Discussion WL Toys V959/V202/ SH 6047 Scorpion dankar04 Mini Multirotors 10 Apr 25, 2015 01:22 AM
Discussion Micro Quad V202 RTF for 26.68$ ratonxi Hot Online Deals 57 Jan 24, 2013 11:23 AM
Discussion WL Toys V202 "50% off" ??? stifa Mini Multirotors 3 Dec 08, 2012 09:50 AM
Discussion V202, which canopy do you prefer? MassiveOverkill Mini Multirotors 16 Dec 07, 2012 01:29 PM
Discussion Soodohobby 2.4G Mini 6 aixs Gyro Scorpion Quadcopter WL V202 Quadcopter MQ80 Multirotor Talk 0 Nov 26, 2012 10:01 PM
