Old Dec 20, 2012, 07:09 PM
MassiveOverkill is online now
Find More Posts by MassiveOverkill
MassiveOverkill's Avatar
United States, SD, Custer
Joined Feb 2011
V202 Review UPDATE: Recalibrating your accelerometers and Deviation Hack
IMPORTANT UPDATE
Recalibrating your V202\V212\V222:
http://www.rcgroups.com/forums/showthread.php?t=1916485
http://www.rcgroups.com/forums/showthread.php?t=1916478
The V2x2 series can now be controlled using any Devo transmitter that's capable of running the Deviation hack:
http://www.rcgroups.com/forums/showpost.php?p=24998249
Reserved.............but right now I can tell you it's REALLY stable. Let me tell you, WL Toys never disappoints me. The supplied 25C lipos seem to have some decent punch, unlike the former V939 batteries which were some of the worst I've seen on any RC flyer I've tried. They actually seem to have more punch than the Mini Pet batteries, but I need to do more testing. We didn't get many extras as we didn't know how good the lipos were going to be.
If I can describe it........take the X4, give it some decaff to calm its nerves, and you have the personality of the V202. It's still very aggressive and nimble, just not as epileptic.
Flips: Flip after flip after flip after flip. Need to go to 100% to do flips and you simply move cyclic to extreme to do a flip, so you can do an accidental flip, but unlike most of the other quads at 100% rates you're guaranteed to do a flip instead of crashing if you accidently go too far. 80% can be flown inside but most will probably use 60%.
Couple more flight tests. The problem with the X4\6044 are that the cyclic isn't linear so you get the gerbil\bee\dragonfly effect. The cyclic on the v202 is smoooooth and linear. One thing that the V202 carries on from it's brother the V939 is nice smooth banked turns. Something I've come to miss since retiring my V939.
The scorpion canopy is a fat pig at 2.2 grams vs the beetle canopy which is 1.4 grams. We have both in stock (beetle comes in red, yellow and purple)
The quad sans canopy and battery is 28.4 grams.
RX board top:
That extra plug turns on\off with the LEDs via the former flip button. I can now run my 808 cam without having to solder a lead onto the board.
Bottom:
And the question you've all been asking............NO, it's not Turnigy 9X \ FlySky compatible
The V202 comes with the same dual lipo charger the V939 came with and while it comes with black and green blades mounted, the spares are black and orange.
The LEDS seem to be pretty bright, still not as good as the Mini Pet's, but decent enough to see for night time flying.
Tommorrow is the outdoor test, and I'll try to get some videos done as well.
Thanks to Syntex for the following:
Originally Posted by Synthex View Post
V202 hardware :
TOREX : XC6206P332MR : 662K : Voltage regulator LDO 3.3V
TOREX : E50N : Voltage booster step-up 5V
Inductor : 47uH : 470 : Inductor for voltage booster
Schottky Barrier Diode : S4 : Diode for voltage booster
MOSFET Transistor : A22T : Motor PWM control driver
Quartz for CPU : 16.000 : 16 MHz Crystal
NUVOTON : NuMicro MINI54ZAN ARM Cortex-M0 : MINI54ZAN 228AC : CPU 32bits ARM - ROM:16KB RAM:2KB - (32pin QFN)
BEKEN : BK2423 : Wireless RF 2.4GHz Transceiver Modules - (20pin QFN)
INVENSENSE : MPU-6050C : 6 Axis Accelerometer & Gyroscope - (24pin QFN)
CPU datasheet : http://www.keil.com/dd/docs/datashts..._datasheet.pdf
MassiveOverkill is online now Find More Posts by MassiveOverkill
Site Sponsor
Old Dec 20, 2012, 09:22 PM
siriusflier is online now
Find More Posts by siriusflier
GOT WINGS
siriusflier's Avatar
United States, TX, Wilbarger
Joined Apr 2012
Looking forward to a more in depth review
siriusflier is online now Find More Posts by siriusflier
Old Dec 21, 2012, 12:03 AM
Joined Feb 2011
Updated 1st post
Site Sponsor
Latest blog entry: MassiveRC ZMR PDB
Old Dec 21, 2012, 07:31 AM
jlcamp7 is online now
Find More Posts by jlcamp7
RC Logger Support
jlcamp7's Avatar
United States, WV, Hurricane
Joined Jan 2010
Sounds like a great new option MO. Looking forward to more info.
jlcamp7 is online now Find More Posts by jlcamp7
Old Dec 21, 2012, 07:49 AM
Flyingfool is offline
Find More Posts by Flyingfool
Flyingfool's Avatar
Belle Chasse Southern, Louisiana, United States
Joined Apr 2002
Not Turnigy 9X \ FlySky compatible Is a deal breaker for me as I would love to have a 939 type with 6 axis control but only if I could use my 9X with it.
Randy
Flyingfool is offline Find More Posts by Flyingfool
Old Dec 21, 2012, 08:05 AM
variantman is offline
Find More Posts by variantman
United States, TN, Knoxville
Joined Jun 2012
How does the V202 compare to the 6044? It's a shame neither one is compatible with the 9x. I was thinking of getting one as my first hobby grade tx. But there doesn't seem to be much support for it, aside from the V949/V929, the Vitality, and crappy V939. And the DIY or ARF kits, of course.
variantman is offline Find More Posts by variantman
Old Dec 21, 2012, 08:24 AM
XFM is offline
XFM
Find More Posts by XFM
XFM
eXperimental Flying Machines
Joined Aug 2010
... and does the V202 have the yo-yo effect of it's predecessor , the V939 ?
XFM is offline Find More Posts by XFM
Old Dec 21, 2012, 08:59 AM
Joined Feb 2011
Variant, I'm meeting up with Cyber Bill to do more extensive testing. Winds are a steady 18-19 mph so I'm bringing the fleet out to test them all (H36, V202, 6044\MP Hybrid, MP original, and X4). Also I'm showing your package scheduled to be delivered on the 24th.
The V939's yo-yo ing was mostly due to its impotent stock battery. The few flight tests I've done on the V202 exhibited no yo-yo ing with the MP batteries and is even better with its stock batteries.
The V202 battery has the same part number as the MP which is 752030, but has a 25C stamp instead of the usual 15C. WL Toys listened to the complaints about the V939 batteries.
Site Sponsor
Old Dec 21, 2012, 04:05 PM
Joined Feb 2011
Well the flight tests went great and it was great to meet Bill. I'll upload videos soon. Bill btw, wouldn't previously bother coming outside to fly in 18-20mph winds, but I think that's about to change.
The sport of micro quads is going to take over where the V911 left off due to it's limitations. How extreme of conditions can we fly them in?
Is the V202 better than the Hubsan? You'll have to wait for Bill's reply but I think the sub $70 king has been dethroned.
The overall theme of today's testing: Get out of the kitchen and living room and get into the wind!!
Site Sponsor
Old Dec 21, 2012, 04:20 PM
Joined Feb 2011
Videos as promised:
WL Toys V202 micro quadcopter UFO in 18- 19mph winds (0 min 0 sec)
And although this is the V202 thread, here's the H36:
Vitality H36 micro quadcopter UFO in 18-19mph winds (1 min 46 sec)
Site Sponsor
Old Dec 21, 2012, 04:27 PM
Joined Jun 2012
I flew my V949 out in the wind today. It was very windy for this area and my quad took it very well. No complaints. I'm sure my U816 will handle it even better when I get my new props. I think cold and moisture are bigger problems, however. And the sun, which I hate having in my eyes. Give me a moderately warm, cloudy day for optimum flying. The wind only makes it funner.
Old Dec 21, 2012, 04:41 PM
Joined Jun 2012
When do you think you'll have the V202's (or 6044's) and it's props in stock?
Old Dec 21, 2012, 05:50 PM
Joined Feb 2011
Hey Variant, the V202\H36 shipment arrived last night. I just have to update the website. It may not be untl after Christmas that we start shipping them though.
Site Sponsor
Old Dec 21, 2012, 06:05 PM
Joined Jun 2012
Now you tell me. I may cancel my X4 from Banggood and get a V202 when its ready. I know this is a dumb question, but how do you cancel a Banggood order? I'm still new to the whole paypal thing.
Old Dec 21, 2012, 06:09 PM
mystman is offline
Find More Posts by mystman
Joined Jan 2012
Send an email to cservice@banggood.com with the ordernumber you want to cancel.
Just as simple as that. They will cancel it and do a full refund.
No need to open a case at paypal.
mystman is offline Find More Posts by mystman
Discussion WL Toys V959/V202/ SH 6047 Scorpion dankar04 Mini Multirotors 10 Apr 25, 2015 02:22 AM
Discussion Micro Quad V202 RTF for 26.68$ ratonxi Hot Online Deals 57 Jan 24, 2013 12:23 PM
Discussion WL Toys V202 "50% off" ??? stifa Mini Multirotors 3 Dec 08, 2012 10:50 AM
Discussion V202, which canopy do you prefer? MassiveOverkill Mini Multirotors 16 Dec 07, 2012 02:29 PM
Discussion Soodohobby 2.4G Mini 6 aixs Gyro Scorpion Quadcopter WL V202 Quadcopter MQ80 Multirotor Talk 0 Nov 26, 2012 11:01 PM
