Old Dec 20, 2012, 08:37 AM
hersch54 is offline
Find More Posts by hersch54
United States, WA, Vancouver
Joined Jun 2011
Build Log
F8 Cursader Build
Well while I wait on HobbyKing to send me my parts for my A7 build, I will start a F8 Cursader build
I took GGRN's plans and enlarged them so the fuse about 40". I will build this the way Hans builds his planes. I take a profile view of the plane and cut it out of pink FFF. I then tke a CF rod and imbed it in the center of that profile. I then cut the ribs (also out of pink FFF) and glue them on to the Fuse profile. Once this is completed I then cut brown paper templates of the shin to insure I get a proper fit. Once satified with the template I transfer that to $tree foam. I use $tree foam because it eill bend easier around the ribs. I use fabric glue I get from Wal-Mart. This stuff is the best stuff I have used.
With the templates I can get very tight seems . I hope this will reduce the amount of sanding and filling.
I plan on using 3/4 oz FG and WBP like John Morgan does on his builds.
I started working on this last night and with in two hours I had gotten all the ribs cut and glued on and even added a few skin panels.
I will add pics later today.
hersch54 is offline Find More Posts by hersch54
Old Dec 20, 2012, 10:01 PM
W. X. Davis is offline
Find More Posts by W. X. Davis
W. X. Davis's Avatar
United States, OH, Reynoldsburg
Joined May 2004
Looks good.
Woody
W. X. Davis is offline Find More Posts by W. X. Davis
Old Dec 21, 2012, 04:31 PM
hersch54 is offline
Joined Jun 2011
More pic's of the build
He are some pic's of the build. Here is how I get the tight seams. I add 1/4 in. strips of foam to the rear side of each rib (Except the last rib #11)Start adding skin foam from the front ofthe plane and work your way back.
Old Dec 21, 2012, 04:49 PM
hersch54 is offline
Joined Jun 2011
Worked on the intake
The nose and intake is what gives the F8 the name "Sharks Mouth".. Makew sur eyou get this section as good as you can it will make the plane look great.
Old Dec 23, 2012, 11:31 AM
hersch54 is offline
Joined Jun 2011
fusw getting close
Well I have been working on the F8. The fuse is almose ready for the FG work.
I will start on the wing and elevators next
Old Dec 23, 2012, 11:59 AM
hersch54 is offline
Joined Jun 2011
Question
What gauge of wire do you use fr your battery wires. I have 16 gauge wire but looking at the wire on the 4C batteries this looks a little small.
Old Dec 23, 2012, 03:44 PM
hersch54 is offline
Joined Jun 2011
working on wing
here are some new pics. The wing is a KF2 Airfoil. I will put a CFR on the under side
Old Dec 23, 2012, 07:50 PM
J Morgan is offline
Find More Posts by J Morgan
EB-66C Team Member
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
If you're going 4s lipos, I would run 14 gauge Hersch. Looks like it's coming along nice.
J
J Morgan is offline Find More Posts by J Morgan
Latest blog entry: AJ-2 Savage
Old Dec 25, 2012, 09:01 PM
bosley is offline
Find More Posts by bosley
bosley's Avatar
United States, SC, Beaufort County
Joined Jun 2002
Hersch,
Where could I get a copy of the three view you posted. I have been toying with the idea of building a stick and tissue style pusher and have been unable to find decent three views. The ones you posted look to be better than anything I have found so far. I would appreciate any help you can provide.
Jeff
bosley is offline Find More Posts by bosley
Old Dec 26, 2012, 09:12 AM
hersch54 is offline
Joined Jun 2011
F8 3 Views
The 3 views were just pics I found doing a google search. Not sure where they were. I will try yo find the web site again.
Old Dec 26, 2012, 09:17 AM
hersch54 is offline
Joined Jun 2011
Jeff here it is.
Jeff Here is the site I found this drawing . Hope this helps.
http://worldweapon.ru/sam/f8.php
Old Dec 26, 2012, 10:04 AM
bosley is offline
bosley's Avatar
Joined Jun 2002
Thank you very much for your help. Your build is looking great by the way.
Jeff
Old Dec 26, 2012, 11:29 AM
hersch54 is offline
Joined Jun 2011
You are welcomed. Thanks it has been an easy build and I would tell anyone to give it a try. I saw how well John Morgan's plane flew so I am excited to get this one in the air. I hope to take it to SEFF in April.
Sold Walbro F8 carb GeetarJoe Aircraft - Fuel - Engines and Accessories (FS/W) 0 May 10, 2012 06:37 PM
Build Log When You're Out Of F8... The Crusader Build Thread GGRN Pusher Prop Jet Models 390 Nov 23, 2009 06:51 AM
Discussion Mig21 F8 Scratch Build EDF64 scratchandbash Electric Ducted Fan Jet Talk 15 Jul 27, 2006 05:24 PM
Sold F-8 Cursader larger Ducted fan. bruff Aircraft - Fuel - Jets (FS/W) 2 Jun 04, 2006 12:36 PM
For Sale F-8 Cursader large EDF bruff Aircraft - Electric - Jets (FS/W) 7 Mar 09, 2006 06:27 PM
