Old Dec 19, 2012, 06:48 PM
TPD86 is offline
Find More Posts by TPD86
Joined Aug 2012
Help!
hisky FBL100 ht8 radio adapter setting for futaba 12fg
hi guys
just wondering i any can help me with setting up the fbl 100 ht8 adapter on my 12fg
I have managed to bind the heil to the module but the the conrtols are all messed up.
I'm using swash type HR3, is this right?
If some one has some setting parameter
Thanks Tim
TPD86 is offline Find More Posts by TPD86
Old Dec 19, 2012, 10:26 PM
mono is offline
Find More Posts by mono
mono's Avatar
Joined Aug 2008
Hi Tim
Well, I must say the HiSky manual is of no use except for the parts breakdown diagram.
I don't have one of these but I would expect the swash to be set at 1 servo, i.e. no cyclic mixing in the radio. That's how the other micro flybarless helis are done as the mixing is in the control board firmware.
When you say the controls are messed up are you referring to the channel allocation order being incorrect or just the servo response?
mono is offline Find More Posts by mono
Old Dec 20, 2012, 02:17 AM
TPD86 is offline
Joined Aug 2012
Thanks mono
The servo channel allocation should be right( i have original transmitter for it and it flys fine), and just the servo response seems wrong on the 12fg.
I changed the swash plate setting to single servo. and it seems to be working better.
The main problem i have now is that when u throttle up the heli wants go full forwards and role to the right a little... instead of increasing the pitch.
and when u use the the ailerons in stead of role the heli to the left or right it acts as the elevator.
Not sure which servo to reverse.
Thanks Tim
Old Dec 20, 2012, 03:31 AM
mono is offline
mono's Avatar
Joined Aug 2008
ok, if that's how it's responding with 1 servo setting, it could well be that the HiSky/FBL 100 does not have cyclic mixing on board. It might just be a case of one or more servos running in wrong direction.
With ccpm mixing set up, if one servo is working the wrong way, then you reverse the servo, if two or more are the wrong way, it's reversed in the cyclic mixing, e.g. a 60% on aileron and elevator is changed to -60%, you may already know this but best mentioned anyway.
I came across a settings sheet for this heli being used with a HT8 module. The fellow was using it with 9x radio so some of it may not apply, but the info on the servo directions etc may be useful for you.
FBL100 tx setup
Also, here is a vid I came across quite a while back and the explanation of how to determine which servos are wrong direction and how to cure it, is very good indeed. Different radio but that doesn't matter, if you watch it, you will see it's the method that's the relevant bit. Once again, you may already know these things, but it could also help others who may read the thread.
http://omhc.co.uk/index.php/helicopt...-a-dx6i-part-2
Hope some of this may help to solve your issues with the heli.
For Sale Set of FY-606 data radios and remote adapter Protocrash FPV Equipment (FS/W) 2 Sep 16, 2014 08:57 PM
Sold FS: 2500mah LIPO w/voltage adapter, set up for Futaba TX seattlebuoy Aircraft - General - Radio Equipment (FS/W) 1 Oct 23, 2012 09:31 AM
Discussion hisky FBL100 brushless hawk01 Micro Helis 5 Oct 15, 2012 07:32 AM
New Product HiSky FBL100 erdnuckel2 Micro Helis 3 May 08, 2012 10:06 AM
Discussion Setting the Futaba 12FG for the Glider's motor acurusaragon Electric Sailplanes 3 Apr 18, 2009 12:44 AM
