Espritmodel.com Heli Air
Old Dec 19, 2012, 06:37 PM
Addicted to 3DHS.
3Daddict's Avatar
ohio
Joined Oct 2010
How to hook up BEC to a optima 6 lite?
I just bought an external caslte 10 amp bec and can not figure out how to hook it up to my optima 6 lite? where do I plug it into?
3Daddict is offline Find More Posts by 3Daddict
Old Dec 19, 2012, 06:46 PM
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
Battery plug/ch 6...
If you are using that any open channel will work. If you are using all - then a Y cable will work.
Old Dec 19, 2012, 08:36 PM
Addicted to 3DHS.
3Daddict's Avatar
ohio
Joined Oct 2010
So I can just plug the bec into the battery port? Is there anything I would have to setup on my radio.
Old Dec 19, 2012, 10:44 PM
Joined Aug 2002
Minima Receivers - UBEC aka SBEC or Switchmode Regulator
Originally Posted by 3Daddict View Post
So I can just plug the bec into the battery port? Is there anything I would have to setup on my radio. Thanks
1. Yes, or "Y" with any servo as in post #2
2. No. As there is no telemetry, you do not have to adjust LBW warnings.
Schematic for Minima and other simple receivers is attached this post.
Photo of a quick adapter is attached:
. Optima Transceiver (RX) - SPC connection & Lead FAQ for EP & GP models
- Adapter to be read/made without the SPC fly lead when used only with non SPC receivers.
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
A.T. is offline Find More Posts by A.T.
Found Hitec Optima 6 or 6 Lite Timewarp Aircraft - General - Radio Equipment (FS/W) 1 Apr 04, 2012 06:49 PM
Wanted optima 6 RX ...lite or standard sparrow1717 Aircraft - General - Radio Equipment (FS/W) 0 Mar 11, 2012 09:46 AM
Discussion How many servos can you hook up to a 6 pin multiplex connecter? flyboy320 Electric Sailplanes 9 Mar 05, 2012 02:07 AM
Sold Optima 9, Optima 7, Optima 6, Optima 6 Lite stickybeatz Aircraft - General - Radio Equipment (FS/W) 2 Apr 13, 2011 02:38 PM
Discussion Proper hook up for ESC / BEC & 6 servos Garyss Power Systems 7 Jun 23, 2009 09:17 AM
