Old Dec 19, 2012, 02:05 PM
Jonathan Ott is offline
Find More Posts by Jonathan Ott
Will fly for food.
Jonathan Ott's Avatar
United States, NC, Fayetteville
Joined Jul 2002
CHAOS 600 owners: Who has a Black Widow head on theirs?
I can't get on the Chaos Lounge from here at work, and a post similiar to this is over there.
Anyway, who has a Black Widow head on your Chaos 600?
I have a problem, that may be unique to me, but I doubt it.
This is specifically for those who 3D or sport aerobatic fly thier Chaos:
Did you have an issue getting zero pitch at center collective on your machine?
With my head in the top hole (using the stock Chaos main shaft) I have +7.5 of pitch at center collective. If I move to the center hole on the head, I get almost the opposite, -5'ish.
I think my drive tubes are too long, or maybe my head-height holes are miss-drilled.
Here's some pics:
Did anyone else have this problem?
As you can see, I have a mechanical zero on the links and servos.
Jon
Jonathan Ott is offline Find More Posts by Jonathan Ott
Old Dec 19, 2012, 02:36 PM
Dejavu*Xion is offline
Find More Posts by Dejavu*Xion
Need More PURPLE !!
Dejavu*Xion's Avatar
United States, NV, Las Vegas
Joined Aug 2012
Dont have a blackwidow. But i see you have my TX. ( Sch a weeet )
I "think" valkman has a blackwidow on his chaos 600. I dont see him here very often anymore. Try helifreak to track him down.
Dejavu*Xion is offline Find More Posts by Dejavu*Xion
Old Dec 19, 2012, 04:32 PM
ewoodcox is online now
Find More Posts by ewoodcox
Axes & Blades-Cutlery & Helis
West Monroe NY
Joined Feb 2009
I think you need to lengthen the servo to swash links.... when I upgraded one of my helis to FBL I needed to buy new threaded rods since the ones with my FB head were like yours.....anyway, that was with a 450 so it is not your heli but the same issue..... good luck, I hope you get it worked out
ewoodcox is online now Find More Posts by ewoodcox
Old Dec 20, 2012, 09:57 PM
Drev is offline
Find More Posts by Drev
Drev
Drev's Avatar
Canada, ON, Chatham-Kent
Joined Jan 2011
Description:
Description:
This is how my BW adjustment turned out to get 0* at midstick.
The jam nuts keep the adjustment from changing & removes any play in the link.
I have NOT flown this heli yet due to cold weather.
The head is mounted in the second hole on the stock 600e shaft.
Drev is offline Find More Posts by Drev
Old Dec 21, 2012, 07:40 AM
Will fly for food.
Joined Jul 2002
Thanks Drev, that's exactly how I'm going to do mine. I have to find some jam nuts, and get through the hollidays, but I can't wait to get it up and running and just fly the damn thing!
Jon
Old Dec 21, 2012, 09:07 AM
GhostFlyer1 is offline
Find More Posts by GhostFlyer1
Umm what just flew off my ship
GhostFlyer1's Avatar
Joined Jan 2010
Jonathan.
The blackwidow head will sit differently on the 600 than it does the 550.
The problem your running into is that the A-Frame arm aka the elevator is more or less a fixed length. The way the head sits on the 550 it uses the top hole of the head itself. The servo linkage rods are a bit shorter too.
On yours *which looks like the super combo kit* you will probably need to use the center hole then adjust the control rods coming off of the swash to the blade grip accordingly. I never converted my 600 to the dfc type head as I am fine with the origional FBL head.
Hope this helps
GhostFlyer1 is offline Find More Posts by GhostFlyer1
Old Dec 21, 2012, 09:15 AM
Will fly for food.
Joined Jul 2002
Thanks Ghost. Help from the community got me through this one. BTW, mine was a super combo kit, but was flybarred.
Happy Hollidays!!
Jon
Old Dec 21, 2012, 09:37 AM
Joined Jan 2010
Happy Hollidays!!
Jon
Happy Hollidays back Brother!!!
Old Dec 21, 2012, 01:28 PM
Mike_Then is online now
Find More Posts by Mike_Then
I hate waiting for parts
Mike_Then's Avatar
United States, NC, Garner
Joined Apr 2001
I've got my eye on a flybarred Chaos 600 Super Combo for a 700 scale project but they are rarely ever in stock. I'll have to act fast the next time they do!
Mike_Then is online now Find More Posts by Mike_Then
Latest blog entry: F-14 resurrection
Old Dec 22, 2012, 10:54 AM
Will fly for food.
Joined Jul 2002
Mike, give them a call. Sometimes the website doesn't get updated on some items.
ADDITION: CRModels has a Chaos for sale. http://www.rcgroups.com/forums/showthread.php?t=1791647
Old Dec 22, 2012, 01:36 PM
Drev is offline
Drev
Drev's Avatar
Joined Jan 2011
About the elevator "A"arm on the Chaos 600, if you loosen the set screw that secures it to the cross shaft there is adjustment there.
The ail. & pitch links might not be short enough to level the swash that low (with the head head mounted in the top hole).
I am going to assemble it that way just to see how it will work.
Ain't this stuff "FUN" !!!
Old Dec 22, 2012, 01:55 PM
The Valkman is offline
Find More Posts by The Valkman
The Valkman's Avatar
Joined Nov 2011
I don't have the BW anymore but I used the center hole as far as I remember and extended the link to the swash like what it looks like you are doing. At zero pitch it all aligned up perfect.
The Valkman is offline Find More Posts by The Valkman
Old Dec 22, 2012, 02:16 PM
Drev is offline
Drev
Drev's Avatar
Joined Jan 2011
Got mine set up as in the pics posted but I haven't flown it yet.
How did it fly?
What kind of head speeds were you running with the BW head?
Old Dec 22, 2012, 03:00 PM
Will fly for food.
Joined Jul 2002
Too much fun!!!
Old Dec 23, 2012, 12:42 PM
Joined Jan 2010
I run mine 10s with roughly a 2350 - 2400 HS
Off Site Black Widow Flybarless unit on Ebay nuttcaze Aircraft - Electric - Helis (FS/W) 0 Nov 13, 2012 03:02 PM
Sold FOR SALE 600 Align,Chaos, Etc. Fly bar head never used $25 plus actual shiping cost jginsandiego Aircraft - Electric - Helis (FS/W) 0 Sep 14, 2012 11:54 AM
Discussion Tee Dee carb on a Black Widow vh2q 1/2A Planes 12 Mar 03, 2012 03:52 PM
Discussion Black Widow on vacation...who else? mrbisset Aerial Photography 1 Jul 30, 2007 09:43 AM
