Old Aug 08, 2013, 03:35 PM
hifinsword is offline
Find More Posts by hifinsword
Blue Skies
hifinsword's Avatar
United States, VA, Williamsburg
Joined May 2012
I did hear back from JamesChen072 about the email I sent him asking if he would convey our concerns about the V913 to WL Toys. He did forward my email to them.
The areas I covered were
1) a screw package
2) Swashplate
3) Right turning problem
4) I went into detail about the soldering vs spot-welding on the motors as a possible problem area. Also included were nemmie's link to his not-so-mini-review and his post 1009.
5) And I included the following 2 paragraphs:
"NEW IDEAS, RECOMMENDATIONS & DISCUSSIONS: , , V913 and the Double Horse 9117. Both these helos are from a similar design, and both used the prior smaller sized helicopter's main electronics board (PCB) of the V912 & DH9116, and other parts, instead of upsizing or scaling up the design. , , , Are both the DH9117 & the V913 destined to fail with the hobbyists? Or will WL Toys do what they did with the V911, or what MJX did with the F45 model to make them the successes they have become?
Will WL Toys offer upgraded parts for the swash, PCB, tail and main motors? Or will they come out with a version (V2) that incorporates the fixes and improvements? Will they offer a BRUSHLESS kit for the motors like MJX did with the F45? Or will they ignore the owners of the V913 and hope we will buy a new larger V914? It would be a shame to not continue the success they had with the V911 and the V912. I hope they will offer upgrades or new versions of the V913 and maybe a Brushless kit to replace the V913 main and tail motors."
I don't know if any of this will make any difference but maybe someone at WL Toys will be willing to look at some of these issues and make the necessaray changes.
hifinsword is offline Find More Posts by hifinsword
Old Aug 09, 2013, 12:31 PM
SeByDocKy is online now
Find More Posts by SeByDocKy
SeByDocKy's Avatar
France, PACA, La Valette-du-Var
Joined Dec 2012
1) a screw package
2) Swashplate
maybe to add a stronger main motor less warming ...
SeByDocKy is online now Find More Posts by SeByDocKy
Old Aug 09, 2013, 02:55 PM
Blue Skies
hifinsword's Avatar
Joined May 2012
Main motor and right turn problem discussion
This is part of the text of my email concerning motors that JamesChen072 forwarded to WL Toys.
"RIGHT TURN PROBLEM: The right turn problem is possibly a mix of more than 1 problem. It is definitely due to motor problems but maybe also the PCB overheating. They may interact to cause the problem of the motors failing early. Most of us have the problem after only about 10 or so flights on the heli. After another 10 or so flights the motors fail completely. The problem occurs after about 3 or 4 mins of flight time once the motors have heated up. Left turns are easy since it lessens the load on the tail motor. Right turns increase the load and the tail motor (or PCB) is not able to handle it.
The most knowledgeable member of our forum has written a review of the V913 delineating some of the issues of the V913. Under the section "TailRotor Fail & No Right Turn issues:" HERE:
http://www.rcgroups.com/forums/showp...5&postcount=17
He describes problems with parts of the tail motor being soldered versus spot-welded. These solder connections seem to melt during normal flight and may be why the motors fail after only a few flights instead of the 50 or so most of us are used to for these brushed motors. His post 1009 on this link describes it somewhat.
http://www.rcgroups.com/forums/showt...791676&page=68 "
I think if they go to the links, they may be able to see more clearly what we are discussing, hopefully.
Old Aug 10, 2013, 10:44 PM
stubro is offline
Find More Posts by stubro
Joined Aug 2013
Hi, I'm new to RC toys and heli's and wondering if someone can help me out here. I crashed my V913 into a tree and it got stuck in the branches. While stuck I was pushing up and down on the throttle to try get it unstuck but no luck so I climbed the tree and got it down. Now when I turn it on the rotor spins but doesn't lift off the ground anymore. I re-charged battery fully and even changed the main rotor blades (even though they didn't look damaged) but still no luck in getting it off the ground.
Any suggestions would be greatly appreciated!
stubro is offline Find More Posts by stubro
Old Aug 11, 2013, 10:57 AM
Lokiamir is online now
Find More Posts by Lokiamir
Joined Mar 2013
Well you can buy it RTF from myrcmart.com for 54.99
Lokiamir is online now Find More Posts by Lokiamir
Old Aug 11, 2013, 01:23 PM
Fuzzyguy is offline
Find More Posts by Fuzzyguy
United States, IL
Joined Jun 2012
Lokiamir
Joined Mar 2013
Why do that when you could probably fix the problem for much less money. If you have a battery voltage meter, did you check that and make sure the battery has a full charge?
Fuzzy guy
Fuzzyguy is offline Find More Posts by Fuzzyguy
Old Aug 11, 2013, 02:44 PM
Switchy is offline
Find More Posts by Switchy
Zipties and Velcro
Switchy's Avatar
United States, NE, Omaha
Joined Mar 2013
Sounds like you need a new main motor.
Switchy is offline Find More Posts by Switchy
Old Aug 11, 2013, 06:23 PM
fantasy1988 is offline
Find More Posts by fantasy1988
Joined Oct 2012
hello guys
v913 can bind TX flysky 9ch ?
fantasy1988 is offline Find More Posts by fantasy1988
Old Aug 12, 2013, 06:35 AM
stubro is offline
Joined Aug 2013
Cheers guys will check the motor and battery!
Old Aug 12, 2013, 02:54 PM
dbranch2480 is offline
Find More Posts by dbranch2480
Joined Feb 2013
is it possible to achieve nice bank turns with the v913. I have the f45 but cyclic is canceled when apply rudder. Is this the same for the v913? IS there a heli this size that does not do this? FX052????
dbranch2480 is offline Find More Posts by dbranch2480
Old Aug 13, 2013, 02:37 PM
Blue Skies
hifinsword's Avatar
Joined May 2012
FlytSky
Originally Posted by fantasy1988 View Post
hello guys
Don't have a FlySky Tx but WL Toys does use FlySky protocol with their V91x helos & V9x9 quad series. I haven't heard of anyone using a FlySky 9X with their V913 but I have with the V911 and V912.
Have you been here: http://openrcforums.com/forum/index....00256096898247
or here:
http://deviationtx.com/
Old Aug 13, 2013, 03:27 PM
Dennis S is offline
Find More Posts by Dennis S
Orlando FL
Dennis S's Avatar
United States, FL, Ocoee
Joined Jul 2013
Motor
Hi all,
had my V913 out today and after only about 2 min, it lost altitude, after landing I check all the connection and tried to take off again, this time I could only get a few feet off the ground at full throttle, flew great last time and this time was not up long enough for the motor to even get warm. Is this what happens when the main motor fails?
Dennis from Orlando
Best stick with quads
Dennis S is offline Find More Posts by Dennis S
Old Aug 13, 2013, 05:06 PM
Blue Skies
hifinsword's Avatar
Joined May 2012
Main motor failing
Originally Posted by Dennis S View Post
Hi all,
Dennis from Orlando
Sounds just like what mine did when my main motor died. Put in a new one and flew just fine.
Old Aug 13, 2013, 10:07 PM
Dennis S is offline
Orlando FL
Dennis S's Avatar
Joined Jul 2013
Motor failed
I must say I am disappointed in the V913 , Main motor dies after just 13 flights. But there are some positives. The big one is I bought this thing on a one day sale for 65 bucks delivered, had I paid 100+ like many did I would have had some strong words for our friends at WL Toys,
2. I like the transmitter, works great for my V911 and V949
3. The V913 was too big for my back yard so had to go to the park with it were I had the space to really enjoy the before mention V911 & V949 these are awesome machines that should not be limited to indoors or a small back yard.
I already purchased the new main and tail motors so I will get it up and flying again but if I get no more then 13 flights out of these new motors then I just may have to retire this bird. There are some exciting new quads coming out and I would rather put my money in one of them.
Dennis from Orlando
Keep them flying, but know when to cut your losses
Old Aug 14, 2013, 07:30 AM
do thien is offline
Find More Posts by do thien
Joined Jul 2013
anyone interested in full brushless for v913? I do this easily with F45, use two esc Brushless flash firmware. So v913 is similar.We'll have outdoor flight with the power of mt brusless
do thien is offline Find More Posts by do thien
Discussion WL Toys V911 Short Motor Life?? Brushless Conversion ? scharlach Micro Helis 16 Apr 12, 2014 04:09 AM
New Product $40 MQX / Ladybird by WL Toys (Turnigy Compatible) zadaw Multirotor Talk 19 Jun 27, 2012 04:20 PM
For Sale WL TOYS 3.5-Channel iPhone/ iPad/ iPod / iTouch RC Helicopter with 0.3 MP Camera! Santoyo Aircraft - Electric - Airplanes (FS/W) 3 Jun 13, 2012 11:36 AM
New Product Swift WL Toys S929 - Micro Helicopter with Turbo control Hawai Coaxial Helicopters 39 Mar 08, 2012 05:57 PM
