Old Dec 18, 2012, 07:14 AM
vini_itu is offline
Find More Posts by vini_itu
Joined Jan 2012
What model to buy? On Road - Basic
Hello everybody,
This is the first of a series of topics I intend to do, mainly aimed at beginners, this topic will appoint three (3) options automodelos basic for beginners who ask the question "Which Model to Buy?".
I'll be clarifying questions, like, passing tips and showing how much will the total investment.
Below is photo of three (3) models chosen:
Tamiya TT01E Brushed:
HSP Brushless RTR Xeme:
HSP Xeme Brushed RTR:
vini_itu is offline Find More Posts by vini_itu
Old Dec 18, 2012, 07:29 AM
vini_itu is offline
Joined Jan 2012
Below is the first option RC Car basics to start with simple equipment, but with quality.
The model chosen was TT01E with bubble Subaru Impreza STI WRC, a beautiful bubble, which can be replaced, as there are numerous options of this model with other bubbles.
Let the pictures:
(Remember that the photos are for illustrative purposes and may be changes, such as the wheel, picked up on the wheels are white)
Chassis:
Body:
Box:
Specification:
Length: 434 mm (43.4 inch)
Width: 188 mm (18.8 cm)
Height: 141 mm (14.1 inch)
Wheelbase: 257 mm (25.7 cm)
Ratio: 8.35:1
Included:
RC Car: TT-01E Subaru Impreza WRX STI)
Motor: 540 Brushed
ESC: TEU-105BK
Adhesives
Manual
Tires: 4pcs
Wheels: 4pcs
Requires:
Battery
Radio
Servant
Charger
Painting Bubble
Features:
Chassis 1/10 scale, versatile scale, vast amount of bubbles (bodies) and wheels for this model;
RC car known worldwide for its price and quality, brand consecrated in the market;
Chassis with some adjustments, including between axle gear ratio, etc;
Bubble case already with (support) for LEDs, LEDs are sold separately;
R Carl 4X4, traction on all wheels, serves both Grip (Race), and for Drift;
Independent suspension, differential gears;
Chassis in plastic, common in models of this type;
Model with Esc and Brushed Motor (Brushed) included.
Electronics:
Brushed Motor 540 (included)
Brushed ESC TEU-105BK (included)
Parties to complement rc car:
Blue Bird Servo BMS-410 - USD $ 8.90:
http://www.rcmart.com/blue-bird-stan...?cPath=1099_50
Lipo Battery 3200mAh 04.07 - USD $ 32.90:
http://www.rcmart.com/yeah-racing-lp...?cPath=52_1285
Charger with source G.T. Power - USD $ 45.90:
http://www.rcmart.com/power-gtpa607-...?cPath=52_1271
Radio 2.4 Xtra 3 channels - USD $ 25.90 (already with battery and charger):
http://www.rcmart.com/xtra-speed-uni...ml?cPath=36_47
Values:
RC Car - $ 108.90
Servo - $ 8.90
Battery - $ 32.90
Radio - $ 25.90
Charger - $ 45.90
Additional items (Radio + Servo + Battery + Charger) - $ 113.60
Old Dec 18, 2012, 08:30 AM
vini_itu is offline
Joined Jan 2012
Second model:
[U] RC Car HSP 1/10 Brushless Xeme: [/ u]
http://www.helipal.com/hsp-xeme-on-r...o-edition.html
Images:
(Bubble available in 9 different colors and models)
Chassis:
Dampers:
Technical data:
Length: 360 mm (36 cm)
Height: 112 mm (11.20 cm)
Width: 200 mm (20 cm)
Ratio: 6.52: 1
Wheel Diameter: 65 mm (6.5 in.)
Wheel width: 26 mm (2.6 in.)
Wheelbase: 260 mm (26 cm)
Weight: 1900kg
Included:
RC Car Xeme mounted Brushless
2.4 Ghz 2 Channel Radio (Same as GT2)
Battery 2000mAh NiMH 7.2Volts
NiMH battery charger (220V)
Electronics:
Brushless Motor 3300KV
Brushless ESC 45A with D
7.2V 2000mAh NiMH Battery
High Torque Servo
Important Features:
- Model RTR, Ready to Run, requiring only 8 AA batteries for the radio and battery charge;
- Parts Aluminum as shock absorbers with height adjustment, Upper Deck, Carda;
- Combo (Motor and ESC) Brushless, with optimal performance, ensuring the model more than 40Km / h with the NiMH battery;
- Radio 2.4 Ghz, great radio, presents virtually no interference, can be used in other Automodelos;
- Crown and Pinion with protection, thus preventing the entry of stones that always end up wearing the gears;
-Model with bearings already included factory;
- Versatile Model, 1/10 scale, thus having a variety of wheels and Bodies;
- Automodel marketed by various brands, with many parts available in the market, both in online stores and in international stores;
- Parts with a great price, vast amount of upgrades available in the market;
- Low maintenance, basic chassis with several adjustments, including, front wheel Toe, Camber front and rear;
Price:
* RC Car RTR (Full): $ 174.90
Old Dec 18, 2012, 08:35 AM
vini_itu is offline
Joined Jan 2012
Brushed RTR HSP Xeme
http://www.helipal.com/hsp-xeme-on-r...-blue-red.html
Images:
(Bubble available in 8 different designs and colors)
Chassis:
Dampers:
Technical data:
Ratio: 6.52: 1
Weight: 1900kg
Included:
Brushed mounted automodel Xeme
Battery 1800mAh NiMH 7.2Volts
Electronics:
540 Brushed Motor
Brushed ESC with reverse HSP
7.2V 1800mAh NiMH Battery
High Torque Servo
In this model will not be pointing the features like the Brushless Xeme, since it is virtually the same model, only with this combo Brushed, which greatly decreases the speed in relation to Brushless.
Prices:
* Automodel RTR (Full): $ 114.90
Old Dec 18, 2012, 01:23 PM
Creepy1 is offline
Find More Posts by Creepy1
Mother warned you about me!
Creepy1's Avatar
Canada, ON, Kapuskasing
Joined Mar 2012
Definately the TT-01 out of all those three is the best choice.
Creepy1 is offline Find More Posts by Creepy1
Old Dec 25, 2012, 11:06 PM
FresnoJay is offline
Find More Posts by FresnoJay
To drive or to fly......BOTH!!
FresnoJay's Avatar
USA, CA, Clovis
Joined Apr 2007
The biggest questions to answer or ask.
1. What do you plan to do with it? (Racing/Bashing)
2. If racing what class? (GT1, GT2, GT3, VTA)
3. Are you planning on progressing through the ranks if racing? Chassis versatility is the name of the game if so.
I am not being a kill joy as these questions will determine what you will need or want as far as chassis and equipment based on the goals.
Jason
P.S. Check my Blog for pics of my cars.
FresnoJay is offline Find More Posts by FresnoJay
Old Jan 02, 2013, 10:09 AM
Norman2 is offline
Find More Posts by Norman2
Norman2
Norman2's Avatar
Connestee Falls, Brevard, North Carolina
Joined Mar 2006
Hi, I would definitely choose the TT-01E due to parts availability. Regarhttp://www.rcgroups.com/forums/editpost.php?do=editpost&p=23688254ds
Norman2
Norman2 is offline Find More Posts by Norman2
Old Jan 03, 2013, 08:27 PM
mredzadventure is offline
Find More Posts by mredzadventure
Kowalski !.....Options
mredzadventure's Avatar
USA, MI, Hastings
Joined Jan 2007
I would go the the Tamiya as well. They make great cars. I would add a bearing kit to it. It will really help that car out.
mredzadventure is offline Find More Posts by mredzadventure
Old Jan 07, 2013, 11:20 AM
cenracer1 is offline
Find More Posts by cenracer1
Hackettstown, New Jersey
Joined Feb 2008
I have a couple of TT01E's and for the money they are one of the best cars out there. I run a couple of 19 doubles in the racing class that these run in. no need for brushless as there are better cars out there for that class.. if bashing is your thing and you want to go fast as well, i would recommend the HPI sprint 2 flux.. very fast with the castle combo and parts are very easy to get.. As for the HSP... never heard of them and I doubt parts are easy to come by.. contrary to what their webpage says..
cenracer1 is offline Find More Posts by cenracer1
Old Jan 07, 2013, 08:50 PM
gabrielisrael is offline
Find More Posts by gabrielisrael
Got the Slickness
gabrielisrael's Avatar
Seattle, WA
Joined Jul 2010
Considering getting into the RC Car world, and would like to try drifting. Is the Tamiya TT01E the one for the biggest bang for the least (overall) buck?
gabrielisrael is offline Find More Posts by gabrielisrael
Old Jan 07, 2013, 09:05 PM
USA, MI, Hastings
Joined Jan 2007
I plan on getting one for a car this summer I have an TC3 for a parking lot basher I want to find a TT01E for my boy. I have always enjoyed building Tamiya kits.
Old Jan 08, 2013, 07:00 AM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
The TT01 is a good value if you have electronics already, or are willing to buy them from discount vendors (hobbypartz.com, hobbyking.com, etc). Their RTR packages aren't priced very attractively compared to other similar cars.
wparsons is offline Find More Posts by wparsons
Old Jan 12, 2013, 04:12 PM
Harshman63 is offline
Find More Posts by Harshman63
Joined Jan 2013
https://www.integy.com/st_prod.html?p_prodid=941 https://www.integy.com/st_prod.html?...14&p_catid=303 4&p_catid=303
This shows you all of the upgrades avialable for the tto1
However, I have yet to break anything on my bone stock tto1 with a hobbywing brushless system. Definitly get a bearing kit and lipos for it. The tt01 is DEFINITLY your best option for bashing or racing.
Harshman63 is offline Find More Posts by Harshman63
Discussion Home/ Electric RC On-Road/ 1/10 RC Electric On-Road/ HSP 1/10 Scale 2.4GHz RTR Brushl lancaster1945 Car Talk 1 Mar 24, 2013 01:47 PM
Discussion 1/10 on road kyosho car, model UNKOWN Crossfury On-road Cars 6 Dec 16, 2012 10:33 AM
Discussion Help buying a brushless on road car tom2505 On-road Cars 1 Sep 30, 2012 01:37 AM
Discussion What modell to buy ? sebbe High Performance 29 Aug 14, 2012 06:52 AM
Discussion 1/10 ON-ROAD -- What should I buy? Camelboy On-road Cars 0 Apr 12, 2011 06:38 PM
