Latest blog entry: RC Parts Suppliers - The Good and the...
I found out how to swap the HOLD and FMOD switches. It's under Model Menu/Device Select. Thanks again, thomasprevere.
When flying as in the example of my first few circuits at about 1 foot of the floor, the heli is stable in flight and does not wander around due to normal ground effects. |
Does anyone know, with the Devo 7E, why I can only get 87.5% throttle in stunt mode with the stick all the way down? I checked the throttle curves and in stunt mode the L setting is at 100%, but it still only shows the throttle in the graph going to 87.5%. Stick full up seems fine.
Thanks for the suggestion. It's set to 100/100.
The other interesting thing is that a 0 throttle curve at point L gives you -12. I noticed this when I first turned on the Tx, out of stunt mode. Even point 1 will go all the way to 100%, just not the point L. I've found a "workaround" for the moment, so I was able to do some 3D. Also needed 110% dual rates and could probably still do with a bit more, say 115%. I'd like more power, but there is enough for simple 3D flying. Flight time with the stock 240mah 25C Lipo, is around 4 to 5 minutes. |
Also, dual rates on THR?
From what I'm reading, it seems to be a bug in the 7E firmware.
Nah, dual rates on elevator and aileron (greater than 100 equals more travel).
Still no motor slow down or bog. I timer to 4 minutes on these brush motors. The MiniCP has 350mah batteries and by 4 minutes, the head speed is down and it gets boggy. Voltage is still only down to 3.8 but it appears the mini motor draws motor as it gets hot. I have some Turnigy 260mah 35C batteries coming that I want to try and see if those work better. |
Joined Jan 2013
Super CP for beginners
Hi,
I am pretty new to the hobby, and after mastering a co-axial 4 channel I decided to try something more challenging. I just got my Super CP and have to admit its alot more challenging than I expected, maybe I should have tried a fixed pitched helicopter before... Either way, my question is - Is there a certain setup for the Devo 7E to make the helicopters responses more suitable for beginners. I just tried the setup that was on the manual. Thanks alot for your help ! |
| Thread Tools | |
| New Product Walkera Super CP - Mixture of the Mini CP, Genius CP, and Super FP | zadaw | Micro Helis | 38 | May 13, 2013 04:12 AM |
| Mini-Review Walkera Mini CP Review - Pictures, Video, Flight Times, Head Speed, Brushless Upgrade | Tom Z | Micro Helis | 663 | May 02, 2013 02:54 PM |
| Sold (3) Walkera Mini CP servos BNIP HM-Mini CP-Z-16 | flint723 | Aircraft - General - Radio Equipment (FS/W) | 3 | Oct 06, 2012 10:22 AM |
| Discussion Blade Mcpx v1 v2 vs Walkera Mini Cp vs Genius Cp vs solo pro 100 3d | f.a.r.m.e.r | Micro Helis | 99 | Jul 04, 2012 09:09 PM |
| Sold Walkera Genius CP/Mini CP brushless motors | RawmadeCF | Aircraft - Electric - Helis (FS/W) | 0 | May 04, 2012 12:33 AM |
