Old Feb 05, 2013, 05:52 PM
saabguyspg is online now
Find More Posts by saabguyspg
saabguyspg's Avatar
Calgary Canada
Joined Jun 2006
thanks for the info on the GPS very useful
Steve
saabguyspg is online now Find More Posts by saabguyspg
Site Sponsor
Old Feb 07, 2013, 05:03 PM
wippo76 is offline
Find More Posts by wippo76
Netherlands
Joined Dec 2010
I have the 3v version
No problem only I has to be careful with not plugging it to the uart
wippo76 is offline Find More Posts by wippo76
Old Feb 08, 2013, 01:47 PM
Gamani is offline
Find More Posts by Gamani
Joined Mar 2012
Hey guys,
Just tried to read all but no data comes in the software ??
Any idea ?
Gamani is offline Find More Posts by Gamani
Old Feb 08, 2013, 01:55 PM
hendrnk is offline
Find More Posts by hendrnk
An Aussie in Chicago
Joined Apr 2012
Originally Posted by Gamani View Post
Hey guys,
Any idea ?
Just a few ideas toget you going:
Have you downloaded the the USB device driver from the vendors site and install it.
Do you see the "com" port in Windows Device manager, when you plug the included USB cable into the computer?.
Have you sent the baud rate to 19200 for the coms port, through the Windows device manager
Have you pressed the connect button in the DOS configuration software with the correct com port and baud rate.
Have you press the READ parameters button to download the data from the DOS device
hendrnk is offline Find More Posts by hendrnk
Old Feb 08, 2013, 02:13 PM
rclab1 is online now
Find More Posts by rclab1
USA
Joined May 2010
Anyone use this DoS with EzOSD?
(wiring?).
rclab1 is online now Find More Posts by rclab1
Reply With Quote  (Disabled)
Old Feb 09, 2013, 02:21 PM
wippo76 is offline
Netherlands
Joined Dec 2010
(wiring?).
I did before
But since the fy dos has nothing to do with your video
Is there no wiring between them
Only fy dos to rx and servos
Ezosd to cam and vtx
Old Feb 09, 2013, 10:50 PM
ronmen is online now
Find More Posts by ronmen
ronmen's Avatar
Israel, Tel Aviv
Joined Feb 2010
Originally Posted by julie32 View Post
I did buy the DOS without GPS. If you look on Feiyus site under the news heading they made a change to the GPS voltage output, it is now 5 volts. It is my understanding that the GPS that comes with the Hornet can not take 5 volts. I contacted Readymaderc about this,(tried emailing Feiyu, came back as non delv) and Feiyu said that yes you will need a 5v GPS. I solved the problem by putting 2 diodes in the pos feed wire, seems to work fine.
[/url]
Thanks for the info and the great diodes solution, can you detail where you bought the 5v output DOS version? Since Readymaderc seems to sell the 3v version according to their website pictures
ronmen is online now Find More Posts by ronmen
Old Feb 10, 2013, 09:51 AM
kristaps_r is offline
Find More Posts by kristaps_r
kristaps_r's Avatar
Latvia, Riga
Joined May 2010
I am ready to buy DOS now but seems cheapest place to buy GoodLuckBuy are on vacations. looks I will have to wait a week.
Does anyone know if GoodLuckBuy has FY-DOS (model without GPS) with 5V voltage on GPS connector?
kristaps_r is offline Find More Posts by kristaps_r
Old Feb 11, 2013, 06:49 AM
ronmen's Avatar
Israel, Tel Aviv
Joined Feb 2010
FY store replay
I was communicating with FY shop and they confirmed they sell the 5v DOS and 5v GPS -
Answer:
Dear Ron M.,
We only sell the latest DOS modules (with 5 volt output), firmware and GPS modules (5 Volt).
We'll update the shop information a soon as we can (long Lunar New Year holidays at the moment).
Sincerely,
Alexander
FYETECH
My inquiry
Hello,
I am considering buying DOS BASIC AFSS sytem
http://shop.fyetech.com/product_info...products_id=66
According to the following FeiYu notice the DOS module is supply 5v to the GPS module.
http://www.feiyu-tech.com/news-en.php?id=31&nav_num=4
1. Please confirm that the DOS you sell is the 5v supply version (the product picture is display the 3v version)
2. In case that in the future I would like to buy additional GPS, do you sell the 5v GPS as stand alone module?
Ron
Old Feb 11, 2013, 10:02 AM
blueprint is offline
Find More Posts by blueprint
FPV Pilot
blueprint's Avatar
Joined Sep 2007
How is the FY-DOS compared to the FY30? In terms of Stability. I have my DragonOSD for return to home and waypoints etc.
The heading hold feature has me intrigued.
blueprint is offline Find More Posts by blueprint
Old Feb 14, 2013, 09:19 AM
Gamani is offline
Joined Mar 2012
Got it worked by setting baud rates in driver setup.
Old Feb 17, 2013, 04:18 AM
Gamani is offline
Joined Mar 2012
Hey Guys,
I've tried fy dos today. My plane is an axn floater jet.
When I activate the rth sometimes I feel that the GPS loses the way.
For example, when I'm over 500 meters the plane rotates in the opposite direction and doesn't lock to home.
However if I'm in the 200 meters sometimes i get better positioning.
Did you have this experience too ?
Old Feb 17, 2013, 10:09 AM
epedemi is offline
Find More Posts by epedemi
Im the eye In the sky
epedemi's Avatar
Denmark, Region Zealand, Jyderup
Joined Mar 2012
Hey Guys..
Installed my FY DOS with gps in my new skywalker 2013 with carbon rod.
I installed it only with double adhensive tape, and tried all levels of throttle for half a battery pack, 4s 5000mah to see any vibration to the fy dos. NO no problems at all, didnt even balance my graupner prop 12x6 or the motor. Fy dos is alot less sensitive to vibration then Fy 31ap.
Now I dont have to worry about one of the wires pulling the autopilot in any direction and making "false" direction
epedemi is offline Find More Posts by epedemi
Old Feb 17, 2013, 08:06 PM
borneobear is offline
Find More Posts by borneobear
Oopss. Oh well.
borneobear's Avatar
In the tropics
Joined Jan 2006
Hey Guys,
First off, does it stabilize well? If it does, than the unit is working.
If it seems not able to find its way 'home', then maybe there's not enough throw on your aileron servos. Just extend the length of your servo arm so that the ailerons move more when RTH is activated.
Worked for me.
Cheers,
BB
borneobear is offline Find More Posts by borneobear
Old Feb 18, 2013, 01:51 AM
Gamani is offline
Joined Mar 2012
Gain was set to 70 for ailerons. It's maybe the contrary... I'll try default setup next time and keep you updated.
Sold FY - 31AP Autopilot Path Navigation & Hornet OSD Combo GPS For RC Airplane mamut FPV Equipment (FS/W) 1 Sep 08, 2012 05:34 AM
Sold FY-31 autopilot with Hornet OSD willi_m FPV Equipment (FS/W) 2 Jun 26, 2012 12:31 AM
Sold FY-21AP II Autopilot with AP117 OSD (latest version!) Mr.RC-CAM FPV Equipment (FS/W) 0 Oct 29, 2010 11:14 PM
