Old Jan 18, 2013, 01:12 PM
D_FAST is offline
Find More Posts by D_FAST
D_FAST's Avatar
Denver CO
Joined Apr 2008
Roque, did you test each unit individually? Amps,watts? then combined I have a ship that uses 2x50 and its a heavy weight at 42oz. But flies quite respectfully
D_FAST is offline Find More Posts by D_FAST
Old Jan 18, 2013, 01:30 PM
RogueAce is offline
Find More Posts by RogueAce
Air Assassin
RogueAce's Avatar
United States, FL, Pompano Beach
Joined Oct 2012
Thanx D. Yes I did test seperately and together early on ,but have lost sheet. I am going to give batts a fresh charge, and re-do tests. I did try something that did work, ....I unplugged the 3 -11.2v and plugged in 1-14.8 v. She wanted to go then!!
RogueAce is offline Find More Posts by RogueAce
Old Jan 18, 2013, 03:55 PM
RogueAce is offline
Air Assassin
RogueAce's Avatar
Joined Oct 2012
Re-tests done and the build goes on!! Here is the data from tests. On a 11.5v charge each unit pulled 225w and 22.2a individually. Together on a total charge of 11.38v the 3 combined pulled 67a and 672w. A seperate test done w/a14.8v got these results. On a charge of 15.4v the 3 combined pulled 970w and 82a. I am more confident now that,after sculpting and sanding ...she'll be a flier!! Thanx again D for the reminder about positive thinking!!
Old Jan 22, 2013, 05:58 PM
RogueAce is offline
Air Assassin
RogueAce's Avatar
Joined Oct 2012
Was away from bench this weekend..so had to get to it today. I got thrust tubes made , carbon rod for flying stabs cut, servo for stabs set, control horn modified for stabs, spacers cut, center exhaust support designed and temp fitted and exhaust tips made. Should be able to button up the aft fuse by this evening or tomorrow. Then on to the wing and V-tails.
Old Jan 22, 2013, 06:54 PM
Jon Snow is offline
Find More Posts by Jon Snow
You know nothing....
Jon Snow's Avatar
Joined Sep 2011
That looks good!Nice exhausts- how did you make them?
Jon Snow is offline Find More Posts by Jon Snow
Old Jan 22, 2013, 08:03 PM
RogueAce is offline
Air Assassin
RogueAce's Avatar
Joined Oct 2012
Thanx Stuart. The tubes are 6 plastic spoon holders and the tips are the lids off of Krylon primer with the end cut out.
Old Jan 23, 2013, 01:32 AM
Jon Snow is offline
Jon Snow's Avatar
Joined Sep 2011
Now that's scratch building!
Old Jan 23, 2013, 05:11 PM
RogueAce is offline
Air Assassin
RogueAce's Avatar
Joined Oct 2012
New addition to build !! Was using the P.O.S. 2.4ghz Dynam 4 ch that came w/the Meteor....until it started moving servos on its own. (will show vid later). When I'd move Elev and release gimbal, the servo wouldn't recenter and would actually start moving . That is impending death! Couldn't even use it to set Elev control .
Old Jan 23, 2013, 06:58 PM
RogueAce is offline
Air Assassin
RogueAce's Avatar
Joined Oct 2012
Will not let me upload vid...sorry. You know the drill though, give up Elev and it goes ..then goes opposite way. NOT GOOD !! New set-up is just fine.
Old Jan 24, 2013, 04:58 PM
RogueAce is offline
Air Assassin
RogueAce's Avatar
Joined Oct 2012
Another day overcoming obstacles !! I got the aft fuse section installed. All 3 exhaust tubes installed,flying Elevs all connected, and rear-end re-worked. I didn't like the boxy way the back looked....so...I cut it off!! With the exhaust tips and back bulkhead I'm using, it looks much more scale, PLUS it gives me a nice place to put my fingers for hand launching.
Old Jan 24, 2013, 05:06 PM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
RogueAce Coming along very nicely! Will be interested in seeing how you go about installing the flying stabs.
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Jan 24, 2013, 10:25 PM
RogueAce is offline
Air Assassin
RogueAce's Avatar
Joined Oct 2012
Wing glued together , spar installed and hidden. Cut balsa for leading edges of flying stabs,will have those pics tomorrow.
Old Jan 25, 2013, 01:48 AM
Jon Snow is offline
Jon Snow's Avatar
Joined Sep 2011
Nice neat job.I like the staggered joint!
Old Jan 25, 2013, 11:58 AM
RogueAce is offline
Air Assassin
RogueAce's Avatar
Joined Oct 2012
Elev leading edges installed and balsa inlet sleeve for control rod installed as well.
Old Jan 25, 2013, 08:57 PM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
your jet
your jet looks like an F-15 did the nasty with the Shockwave truck. totally awesome.
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Discussion The Tri Fighter RogueAce Scratchbuilt EDFs 82 Dec 17, 2012 12:01 PM
For Sale Vintage Tamiya Mad Bull/Fighter/Mad Fighter Chassis Blind Onez Cars - Cars and Parts (FS/W) 1 Oct 20, 2008 11:06 PM
Sold Micro All EPP twin park fighter Japanese Navy Night Fighter J1N1 Gekko shschon Aircraft - Electric - Airplanes (FS/W) 2 Nov 29, 2006 11:55 PM
Flat Fighter - anyone tried this? Ben_E Foamies (Kits) 4 Dec 10, 2003 04:32 PM
