Old Dec 24, 2012, 07:10 PM
RogueAce is offline
Find More Posts by RogueAce
Air Assassin
RogueAce's Avatar
United States, FL, Pompano Beach
Joined Oct 2012
No more work for today.Will be back at bench on Wednesday. Merry Christmas everyone!!
RogueAce is offline Find More Posts by RogueAce
Old Dec 24, 2012, 07:26 PM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
you too. hope you and yoru family have a great one.
Rich
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Dec 25, 2012, 05:45 AM
space 1 is offline
Find More Posts by space 1
USA
Joined Apr 2007
LuvEvolution7 sorry i disagree well see
space 1 is offline Find More Posts by space 1
Old Dec 25, 2012, 07:20 PM
Joined Jan 2009
of course you would, cause that's what you do. LOL.
bottom line is, it works and is used ALL the time. obviously, you've never run a multi, or you would know this.
Old Dec 26, 2012, 06:06 AM
space 1 is offline
USA
Joined Apr 2007
SO you got 3 2200ma = 6600ma 3 motor's drawing 20amp=60amp cool. one motor fries & suck's all three batteries.
Old Dec 26, 2012, 11:08 AM
Joined Jan 2009
ok, so you REALLY don't understand what's going on. that's painfully obvious. maybe you should go read up on it, so that you do understand. your last sentence can't possibly happen. if you think it can, you need to seriously read up on how all this stuff works. just sayin.
Old Dec 26, 2012, 11:21 AM
Stuart A is offline
Find More Posts by Stuart A
You know nothing....
Stuart A's Avatar
Joined Sep 2011
Ok enough with the WXYZ leads/battery shmattery motor fries goodbyes
We need some build!
Stuart
Stuart A is offline Find More Posts by Stuart A
Old Dec 27, 2012, 08:53 PM
RogueAce is offline
Air Assassin
RogueAce's Avatar
Joined Oct 2012
Haven't been able to get back to the bench yet , but have had to re-think some design elements. Mixing the two different plane styles ,in certain areas, will not be feesable as the changes will add too much more weight. So I will be going with the basic F15 layout but will tilt out the Vert Stabs like the F18 and F22. This will also give the necessary room for the 3rd unit exhaust.
Old Jan 01, 2013, 07:33 PM
RogueAce is offline
Air Assassin
RogueAce's Avatar
Joined Oct 2012
Sorry that I haven't been showing too much guys ,had family in after Christmas and have been getting house un-decorated, however there has been progress. Forward fuse is assembled ,nosecone and canopy are rough shaped and mount has been cut. Many concerns and questions that I had have been figured out now that I have begun construction.
Old Jan 05, 2013, 05:20 PM
RogueAce is offline
Air Assassin
RogueAce's Avatar
Joined Oct 2012
Got more shaping done on nose section of fuse and secured fans to their mount as well. Need more shrink tubing to finish motor leads , but I did get motor side done. What a lovely tangled web of wires!LOL....All too soon will be zip tied and insulated,routed and tidy. Anyone got some input on their best way to insulate? I was gonna go good old tin foil wrap. Alot of wires in complete harness.Peeled back the shrink on ESCs...every little bit helps disperse that heat. Tonight and tomorrow will be center fuse ,mount motors in fuse and other goodness.
Old Jan 06, 2013, 01:11 AM
Joined Jan 2009
don't use tinfoil. the heat won't be as bad as you think it will be. LOL.
the best way to take care of wires in an electrical system, is to twist each separate system of wires together, then tape them together with electrical tape. this will cut down on any interference that may be caused by the magnetic field formed by electricity passing through the wires. otherwise, I wouldn't worry about it too much.
Old Jan 06, 2013, 08:40 AM
D_FAST is offline
Find More Posts by D_FAST
D_FAST's Avatar
Denver CO
Joined Apr 2008
If it was me, i would remove all those bullet on the motor side.
you have tripled your chances for a cold soldier joint. not to mention the weight saving in brass and soldier alone would be a lot.
great build so far. great to see guys thinking outside the box.
D_FAST is offline Find More Posts by D_FAST
Old Jan 06, 2013, 11:52 AM
unclecrash is offline
Find More Posts by unclecrash
unclecrash's Avatar
white lake michigan
I hope you don't run into a problem with the fans starving each other for air. This happened to them on the big 144 inch T38 they had to put a splitter between the fans.
unclecrash is offline Find More Posts by unclecrash
Old Jan 06, 2013, 11:55 AM
D_FAST is offline
D_FAST's Avatar
Denver CO
Joined Apr 2008
nice call!
Might want to do some power test with and without splitters, unless the design calls for separate intake for each fan.
Old Jan 06, 2013, 12:26 PM
unclecrash's Avatar
white lake michigan
Yep I couldn't tell if he is going to duct each separately, then he will be OK. It looks like there is an intake on top the turtle deck and maybe below the wing on each side. So I thought I would give him a heads up
Discussion The Tri Fighter RogueAce Scratchbuilt EDFs 82 Dec 17, 2012 11:01 AM
For Sale Vintage Tamiya Mad Bull/Fighter/Mad Fighter Chassis Blind Onez Cars - Cars and Parts (FS/W) 1 Oct 20, 2008 10:06 PM
Sold Micro All EPP twin park fighter Japanese Navy Night Fighter J1N1 Gekko shschon Aircraft - Electric - Airplanes (FS/W) 2 Nov 29, 2006 10:55 PM
Flat Fighter - anyone tried this? Ben_E Foamies (Kits) 4 Dec 10, 2003 03:32 PM
