This thread is privately moderated by Steveis, who may elect to delete unwanted replies.
Old Dec 17, 2012, 12:11 PM
Steveis is offline
Find More Posts by Steveis
AVR Dude
United Kingdom, England, Cnwll
Joined Jul 2011
KK2 Software for faulty receiver input
If you have a receiver input on your KK2 that doesn't work (i.e. it is invalid on the Receiver Test screen) then you can try the attached software where I have swaped each input with the Aux input. It means you sacrifice the Aux switch on your transmitter but you can still use the stick setting to enable self level.
For example, if your Yaw signal is not working, flash your KK2 with the KK2_1V4_Swap_Yaw_Aux file and connect your Yaw output from your receiver to the Aux input (which is now programmed as the Yaw input).
The base code is V1.4
I have also added a file where the Yaw input has been moved to Motor8 and another file where the Aux input has been moved to Motor8.
Enjoy
Steveis is offline Find More Posts by Steveis
Discussion OpenAero2 open-source stabilisation software for KK2 boards HappySundays FPV Talk 3814 Jun 20, 2016 03:28 PM
Help! I received a faulty V929 quad from Banggood... Sleep Micro Helis 5 Jan 02, 2013 05:54 PM
Help! brand new kk2, tricopter setup; error no yaw input Brian Courtice Multirotor Talk 2 Oct 27, 2012 08:29 PM
Sold AR6210 DSMx Receiver with Data input $50 shipped powerlines Aircraft - General - Radio Equipment (FS/W) 5 Mar 23, 2012 11:57 PM
