Old Dec 19, 2012, 02:16 PM
joker24458 is online now
Find More Posts by joker24458
Whatever goes up must go BOOM
joker24458's Avatar
United States, OH, Kent
Joined Mar 2012
Originally Posted by furballll View Post
pics and vids or it didnt happen
+1
-joker
joker24458 is online now Find More Posts by joker24458
Old Dec 19, 2012, 03:16 PM
Levictus is offline
Find More Posts by Levictus
Crash Test Pilot
Levictus's Avatar
United States, NC, Raleigh
Joined Jul 2012
SD ONE, are those carbon or balsa spars? What are you using for linkages? And is that 1.3# or 1.9# 9mm EPP? Where did you get all the fancy control horns snd arms? Thanks, sorry for all the questions
Levictus is offline Find More Posts by Levictus
Old Dec 19, 2012, 04:42 PM
SD One. is offline
Find More Posts by SD One.
My hovercraft is full of eels.
USA, TN, Gallatin
Joined Aug 2009
Those are 4mm carbon strips, around 1mm thick. Linkages are 2.5 mm carbon rods with Z-bends on each end attached with heat shrink tubing and CA.
I used 1.3 lb EPP and although it worked, it is VERY flimsy and needed extra bracing in the wings along with the standard foamy carbon X bracing underneath using 1.2 mm rods. A plane built from 1.9 lb EPP should not need the extra wing bracing near the aileron hinge like mine did.
The control horns and arms used to be sold by 3DHobby Shop but they don't carry them anymore. Something similar could be cut from thin ply pretty easily.
SD One. is offline Find More Posts by SD One.
Old Dec 20, 2012, 04:30 AM
EZglider is offline
Find More Posts by EZglider
It's Just Foam!!!
EZglider's Avatar
Canton,Ga
Joined Apr 2010
I'm a sucker for the Sbach, and this one looks Great! I really like how you've tweaked the design around. I think this one's next on the build list, probably go with laminated DTF for stiffness and some added mass for the winter wind Thanks for the plans.
EZglider is offline Find More Posts by EZglider
Old Dec 20, 2012, 09:23 AM
SD One. is offline
USA, TN, Gallatin
Joined Aug 2009
Sorry my build pics don't really show the details of the finished plane at all. I'll try to get some pics of the underside to show the bracing and linkage. Wamsy has the 32" EPP plane now so I don't have easy access to that one but I can get some shots of the finished depron version when I get home tonight.
Old Dec 20, 2012, 06:38 PM
wamsy55 is offline
Find More Posts by wamsy55
Fly Low
wamsy55's Avatar
Nashville , Tennessee
Joined Jan 2009
I will post some pics of mine in a bit.
wamsy55 is offline Find More Posts by wamsy55
Old Dec 23, 2012, 08:01 PM
joker24458's Avatar
Joined Mar 2012
Ummmmm, pics?
-joker
Old Dec 23, 2012, 09:08 PM
wamsy55 is offline
Fly Low
wamsy55's Avatar
Joined Jan 2009
Originally Posted by joker24458 View Post
Ummmmm, pics?
-joker
My bad, got busy. Let me go to the garage and get them.
Old Dec 23, 2012, 09:17 PM
wamsy55 is offline
Fly Low
wamsy55's Avatar
Joined Jan 2009
Description: Name: ImageUploadedByTapatalk1356318829.536651.jpg
Description: Name: ImageUploadedByTapatalk1356318935.974041.jpg
Description:
Old Dec 23, 2012, 11:00 PM
042joasva is offline
Find More Posts by 042joasva
042joasva's Avatar
Sweden, Stockholm County, Stockholm
Joined Jul 2012
How did you do the hinges? By solder or router?
Joakim
042joasva is offline Find More Posts by 042joasva
Old Dec 24, 2012, 12:40 PM
SD One. is offline
USA, TN, Gallatin
Joined Aug 2009
Ummmmm, pics?
-joker
Lol, sorry. X-mas and all that.
Yay! Thanks for the pics, Wamsy! Hah! I never realized how crooked that one aileron horn is.
See? Foam is forgiving. You don't have to be perfect, just close.
The hinges on the EPP version were cut with a soldering iron. I melted them the same way as I do round wing spars, just a little deeper into the foam. It wasn't as perfect as it could have been but it worked! I've since figured out how to do the elevator and rudder the same way but the plans will have to be completely redesigned for it to work... so I haven't bothered. It was just a neat experiment. Welders or Foam-Tac hinges will work just fine.
For the tail and all the hinges on the depron version, I use my trusty Easy Bevel 45.
Old Feb 17, 2013, 08:12 AM
pollux is offline
Find More Posts by pollux
pollux's Avatar
Joined Jun 2012
Hello Guys,
I am new in this thread, so just a few words about me. When I first saw the plan
to this Shocky, I was really keen about it. And I started to rebuild it on my CAD-
Programm. Two weeks ago at the hall flight day my UMX Sbach was shot down
by a bad boy, so I had a drive set and no plane.
Then I built up this really nice Airplane with 40 cm (15,7 inch) and a weight of
about 50 gramm (1.7637 oz). Here is a link to a video.
http://www.rcgroups.com/forums/showthread.php?t=1833672
A flight video will follow next weekend, because then I will go to the hall flight day
again. Hope you like it.
Many Greetings
pollux
pollux is offline Find More Posts by pollux
Old Feb 17, 2013, 05:19 PM
SD One. is offline
USA, TN, Gallatin
Joined Aug 2009
That is awesome! Great job with the micro gear!
Old Feb 17, 2013, 05:39 PM
kzart is offline
Find More Posts by kzart
United States, IN, Elberfeld
Joined Feb 2011
Don't know if I know exactly what I'm doing. But, I have a hexTronik 20gram Brushless Outrunner 2300kv, some 5g servos (going for 2 ail and 2 for tail) and some 6mm epp on the way.....going for a 27" stormbach build...wish me luck...
kzart is offline Find More Posts by kzart
Old Feb 17, 2013, 05:49 PM
SD One. is offline
USA, TN, Gallatin
Joined Aug 2009
Good luck! I think you are off to a good start. I like the idea of two smaller servos for the aileons and should work well. I've never used such a high KV motor before though.
Build Log Stormbach 442 - "Sbipe" SD One. Foamies (Scratchbuilt) 197 Jul 09, 2015 12:16 AM
