Old Dec 16, 2012, 08:45 PM
LA Ming is offline
Find More Posts by LA Ming
LA Ming's Avatar
Poteau, OK
Joined Nov 2008
Pacifier Source: Found
Hi All!
Those in need of baby pacifiers to use as bladders for their vintage combat planes: Check out the baby section at your local Wal Mart. "Gerber" has one that is VERY usable. It is non-orthodonic (those mal-formed things that were foisted on the baby world for decades), very thick, and overall excellent quality. Comes in a 2 pack for less than $3.
Finding these Gerber pacifiers means my Super Satan can go back into the air if'n I want to!
LA Ming is offline Find More Posts by LA Ming
Old Dec 16, 2012, 10:03 PM
Gnu4FF is offline
Find More Posts by Gnu4FF
United States, TX, Spring
Joined Jul 2010
Thanks! I'll definitely check this out.
Gnu4FF is offline Find More Posts by Gnu4FF
Old Dec 17, 2012, 12:24 AM
tigreflyer is offline
Find More Posts by tigreflyer
Joined Apr 2012
It's been 37 years since I used pacifiers, but if I remember some pacifiers just won't work. The old 2 piece Binkys was my favorite. I used them in aluminum snack pack cans. I can't remember the fuel volume. How much fuel did we put in pacifiers?
tigreflyer is offline Find More Posts by tigreflyer
Old Dec 17, 2012, 01:08 AM
Gnu4FF is offline
Joined Jul 2010
They're a little lower in pressure than surgical tubing bladders, I think.
Old Dec 17, 2012, 06:39 AM
LA Ming is offline
LA Ming's Avatar
Poteau, OK
Joined Nov 2008
These are two piece like the old Binky's... but the rubber bulb is heavier and will have more pressure than a Binky. I think I recall using these some 12 years ago when I was last flying my vintage pacifier airplanes and they worked great. Was glad to see they're still available.
Old Dec 18, 2012, 08:49 PM
aspeed is offline
Find More Posts by aspeed
Canada, ON, Cottam
Joined Jan 2012
I still have about a dozen left over from about 30 years ago, they are a bit darker but look ok still. I never even used them. I think the new thing now is the Little Red Cap. It is a small kitten sized condom like balloon for capping caulking tubes. I just used one for that, and the caulking was still great after three or four months, not even a little bit dry. It is more for 1/2A sized planes and is much lower pressure than pacifiers or bladders. Lee Valley Tools is the only place I know that carries them. $5 for 20 or so.
aspeed is offline Find More Posts by aspeed
Old Dec 18, 2012, 10:11 PM
LA Ming is offline
LA Ming's Avatar
Poteau, OK
Joined Nov 2008
Being lower pressure, those would likely be great for a 35 Stunt on pressure w/stock NVA.
Old Dec 18, 2012, 10:37 PM
Joined Apr 2012
How much fuel can one of these hold?
Old Dec 19, 2012, 12:02 AM
aspeed is offline
Canada, ON, Cottam
Joined Jan 2012
I just tried one and got 3 oz of water in. There looked like a bit more room. About 2" dia.
Old Dec 19, 2012, 02:58 PM
Bob Mears is offline
Find More Posts by Bob Mears
F2D Pilot/Mechanic
Bob Mears's Avatar
United States, TX, Lubbock
Joined Dec 2011
3oz. is all I put in a F2D. Does it blow up long or round?
Bob Mears is offline Find More Posts by Bob Mears
Old Dec 19, 2012, 03:03 PM
F2D Pilot/Mechanic
Bob Mears's Avatar
Joined Dec 2011
If I recall right, they would only hold about 3 oz. And Pop filled them up with an old fuel bulb. I couldnt fill one up as a kid. I dont know when the syringes came into play, but that a LOT easier than a fuel bulb!
Old Dec 19, 2012, 03:38 PM
F2D Pilot/Mechanic
Bob Mears's Avatar
Joined Dec 2011
Here's their web site http://www.littleredcap.com/Location...ACE%20Link.htm
Local ACE dont have them and wont order them. Went to ebay (man mall) found 35 for 9.97 + 4.95 shipping. Will be giving them a shot. Thanks for the great idea!
Old Dec 19, 2012, 07:55 PM
Joined Apr 2012
I filled a Binky's with a brake fluid pump-it pumped 1 ounce per push and lasted 5 or 6 gallons before it gave up.
Old Dec 20, 2012, 12:59 AM
Gnu4FF is offline
Joined Jul 2010
The lifespan of this type of fuel system does in part depend on the nitro percent being used. At 40% they weaken fairly soon, probably won't last a day. I dropped a third max with a lean run finding this out.
Old Dec 20, 2012, 09:01 AM
aspeed is offline
Canada, ON, Cottam
Joined Jan 2012
The red cap is pretty thin and isn't good for much more than a week, I think I read somewhere. It is the shape of an egg in the one I tried. There is a little nipple on the end that looks like it could go a bit bigger, but I didn't want my face full to try another ounce. I hate when a Hardware store lists things in their catalogue and doesn't have any in stock. It is worse when they won't even order it for you, and then charge $5 to ship it. It did say you could ship it to your local store on the link.
Found a good source for micro size wire. Jim McPherson Scratchbuilt Indoor and Micro Models 23 Oct 01, 2003 02:25 PM
I found a source for free pink foam fuses Barrett Electric Plane Talk 1 Dec 01, 2001 07:17 AM
Good source found for Hacker B20 Pinions. Jim McPherson Electric Heli Talk 0 Jun 20, 2001 07:02 PM
