Old Dec 15, 2003, 12:52 AM
xmech is offline
Find More Posts by xmech
xmech's Avatar
Hernando,Mississippi, United States
Joined Apr 2003
BAW 38ep Caravan Build Thread
Got home from work tonight and there it was. The new BAW Caravan 38ep kit delivered personally to my house, by Chris.I won't get started on it till tomarrow, but have next three days off. Nice instruction manual,good hardware, and it looks like it should go together pretty quick. I plan on going with the FedEx scheme.Equip will be: GWS 350C, 3 blade 9x7 prop, 2 pico servos,GWS 300esc, Futuba 6ch receiver and 2s 1200Etech battery pack.Here's a few pics of how it comes.
xmech is offline Find More Posts by xmech
Old Dec 15, 2003, 12:56 AM
xmech is offline
xmech's Avatar
Joined Apr 2003
Manual/parts nice aluminum gear.http://www.bovineaeroworks.com/
Old Dec 15, 2003, 01:02 AM
xmech is offline
xmech's Avatar
Joined Apr 2003
Tricycle gear with nose wheel steering, and plenty of room in that fuselage and pod for a camera or air drop.
Old Dec 15, 2003, 09:28 AM
chiozza is offline
Find More Posts by chiozza
Joined Nov 2001
Glad you like so far Xmech: Let me know if you have any questions.
chiozza is offline Find More Posts by chiozza
Old Dec 15, 2003, 03:27 PM
xmech is offline
xmech's Avatar
Joined Apr 2003
Fuselage sides glued and control rod tubes in place.Rubber cemented rudder and horizontal stab templates onto supplied foam sheet.Be sure and use new knife blade and straight edge when cutting out stab.So far going smoothly.The elevator will be hinged with tape with a 1/8 inch gap between surfaces, no need to bevel cut, and tape seals air gap.
Old Dec 16, 2003, 08:24 PM
xmech is offline
xmech's Avatar
Joined Apr 2003
Tail group and gear attached.350C motor installed.Logos downloaded from the BAW site and printed onto the Testors decal paper.Then coated with gloss clear fixative and allowed to dry overnight.Works out pretty well.Still have to paint in windows and detail.
Old Dec 17, 2003, 12:08 AM
xmech is offline
xmech's Avatar
Joined Apr 2003
Servos installed with servo tape.Battery will be attached to underside of fuselage with velcro strap and covered by cargo pod.The pod is attached with two rare earth magnets.I know the blind nuts are on the wrong side of the supports, but the nylon wing bolts are not long enough to put them on the other side.They should hold up fine, since the wing struts are functional and this is not a high speed aerobat.I hope! LOL
Also found out my decals are not sticking very well to the foam,have to think of a better way.
Old Dec 17, 2003, 12:09 AM
xmech is offline
xmech's Avatar
Joined Apr 2003
Magnets epoxied to pod.
Old Dec 17, 2003, 12:12 AM
xmech is offline
xmech's Avatar
Joined Apr 2003
Pod painted and ready to attach to bottom of fuselage.It's going to be a fat little guy.LOL
Old Dec 17, 2003, 10:41 AM
chiozza is offline
Joined Nov 2001
Looking good Xmech! Are the aircraft numbers painted on? I have done the blind nuts on 6 of the prototypes the same way you did and have not had one fail yet.
Old Dec 17, 2003, 12:03 PM
xmech is offline
xmech's Avatar
Joined Apr 2003
The "N" numbers are decals also.If they don't stay on I may need to put a clear coat of acrylic over the top of them.Did you have any trouble with the decals sticking?I'm installing the wing strut anchors now, and painting the prop silver.
Old Dec 17, 2003, 12:11 PM
chiozza is offline
Joined Nov 2001
Did you "sand" the plane down with a paper towel? That will remove the angel hair and allow the decals to stick better. If that does not work spray the decals with foam safe adhesive. $3 bucks at Walmart, the can is Purple and is 3m brand. I tried painting the prop as well. It looked good but the paint will flake off after running the motor. Try a testors marker stick. Did you paint the tail as well?
Old Dec 17, 2003, 12:19 PM
xmech is offline
xmech's Avatar
Joined Apr 2003
Didn't sand on fuselage much, the large decals seem to be sticking fine, just had trouble with the "World on time" one; long and narrow.Figured paint may peel on prop, don't tell my wife I'm using her kitchen table to support prop while drying.
Old Dec 17, 2003, 01:08 PM
chiozza is offline
Joined Nov 2001
I would love to see how she flys with the 350. I have only used the 300. Should be interesting.
Old Dec 17, 2003, 03:27 PM
xmech is offline
xmech's Avatar
Joined Apr 2003
Ready for test flight. CG came out right at 1.5" from leading edge with 2s Etech 1200 battery. AUW is 13.8 oz.Will try to get a flight in if wind calms down.
I got some Fan Fold what to build thread part II started by emoone!!! Don Sims Foamies (Kits) 188 Jan 23, 2010 09:28 PM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 11:41 PM
My Bobolink Build Thread (very Colibri like) Jim Poor Hand Launch 65 Dec 10, 2003 05:48 PM
Laird Super Solution Build Thread! boomerace Parkflyers 178 Oct 29, 2003 08:20 PM
Switchback re-build thread (or What the $#*& was that!) Biggles604 Parkflyers 17 Jun 23, 2003 10:34 PM
