Old Dec 16, 2012, 07:16 AM
shaurinsoni is offline
Find More Posts by shaurinsoni
Joined Feb 2012
DJI NAZA M Thread - Sudden Climb rate without throttle up
Hello Friends,
I have faces so many problems in NAZA, but they are all solve very well by my own.
At this time i am facing some problem in motor power, i dont know why but motors are out of order, they are up-down at 50% throttle. Not stay at same level of height.
If any one of us have faced this problem earlier, request you to pull me up.
Thank you very much for all you reading...!!!
Shaurin
shaurinsoni is offline Find More Posts by shaurinsoni
Old Dec 16, 2012, 07:43 AM
okamuwf is offline
Find More Posts by okamuwf
William Okamura
Brazil
Joined Aug 2006
are you flying in sunny environment? the barometric sensor is sensitive to light of sun
okamuwf is offline Find More Posts by okamuwf
Old Dec 16, 2012, 08:47 AM
Joined Feb 2012
No. i have tried three times...in different wind & light...
Old Mar 11, 2013, 08:55 AM
amba is offline
Find More Posts by amba
amba's Avatar
Joined Feb 2011
Any insights!?
This is happening to me too.
At first I thought sun light on baro, but then I tested it at night... the exact same behavior
amba is offline Find More Posts by amba
Old Mar 11, 2013, 09:18 AM
Mike_Then is offline
Find More Posts by Mike_Then
I hate waiting for parts
Mike_Then's Avatar
United States, NC, Garner
Joined Apr 2001
To both shaurinsoni and amba, try these basic steps -
  1. As mentioned, the barometer, which is how the Naza detects altitude, is extremely sensitive to sunlight. Put a piece of black tape over the left side of the Naza and try again.
  2. 2. Have you done IMU calibration in the Assistant?
  3. Have you done the compass calibration for the GPS?
FYI, these questions have been answered multiple times on the forums. Did you try using the search function?
Mike_Then is offline Find More Posts by Mike_Then
Latest blog entry: Moving on from the F-14
Old Mar 24, 2013, 11:48 AM
amba is offline
amba's Avatar
Joined Feb 2011
I have checked all items on your list, including using search, extensively.
It has been verified that the unit had just gone bad. Will be sent for repair.
Thanks for the help.
Old Jun 30, 2014, 04:18 PM
simon13110 is offline
Find More Posts by simon13110
Joined Jun 2014
i had same problem with f450 first test flights went very well but then the next time i was out flying in gps mode with full gps lock and feild callibration it decided to to roll hard to the right any stick input i put in had no effect. did not have time to take out of gps mode happened so quick luckly it only suffered broken arm. searched the net to find cause like everyone else ended up transfering to new alien frame with new dji motors and props and a fully blacked out naza light and new fpv dominators was flying as often as i could built up loads of hours and then it happened all over again flying fpv high altitude no gimble so i could see the roll through the goggles had enough time to engage ioc with no effect switched to attitude mode no effect engage failsafe no effect engaged my frsky djt failsafe no effect buy this time i am loosing reception on goggles its gone and its not coming back that was 20:30 on 29/06/2014 maybee got enough parts to build anotherone apart from gopro and fpv tx but i took up this hobby to chillout and for a time i did but i dont feel chilled now. hope you get to the bottom of it and dont loose your quad like me
cheers simon
simon13110 is offline Find More Posts by simon13110
Discussion DJI Naza vs DJI WK-M - What do you get for the extra $860?? brianshell Multirotor Talk 96 Jul 19, 2013 08:15 AM
Discussion DJI Naza - wraps up to FULL throttle when arming!! brianshell Multirotor Talk 21 May 31, 2012 08:29 PM
Help! A little help please, Video inside - XAircraft X650 Shake At Throttle Up - DJI Naza Denominator Multirotor Talk 11 May 31, 2012 09:07 AM
Help! DJI Naza wind issue!!!! (help needed with throttle up issue in wind) Arxangel Multirotor Talk 11 Mar 07, 2012 01:47 AM
