Old Dec 15, 2012, 10:56 AM
ultralajt is offline
Find More Posts by ultralajt
ultralajt's Avatar
Ljubljana Brnik, Slovenia
Joined Sep 2004
Mini-Review
MARABU 3kg@2,65m
I will introduce to you here my design of very lightweight yet large electric plane I design and build last year.
You can download a FREE SAMPLE PLAN (click here) and if you became interested for making this model for yourself or friend, you can buy plans here (click).
Its outer layout is slightly taken from a small Czech build rubber powered free flight model with the same name.
Actually I started a building thread in Parkfly section, as this model is rather ligtweight, has very low wing loading and its minimum speed is somwhere between 17-19 km/h (10-12mph)
As I recieved some critics that this Giant Slow model doesnt belong in the "parkflyer" section, I deleted the building thread there.
Well, now model is flying already more than one year with a great succsess, I decided to share it with you here!
Some specifications:
Wing span: 2,65m (104")
Weight: 3000g (6,6lb)
Some photos of model in action:
ultralajt is offline Find More Posts by ultralajt
Old Dec 15, 2012, 11:09 AM
ultralajt's Avatar
Joined Sep 2004
Some more photos from my flying sessions:
Old Dec 15, 2012, 12:26 PM
ultralajt's Avatar
Joined Sep 2004
And some videos:
Testing before maiden:
Tossing MARABU in the air (0 min 13 sec)
Maiden flight:
Marabu maiden flight (4 min 22 sec)
Aerotowing:
First aerotow in history of Radeče (1 min 48 sec)
Flying in high wind:
MARABU STOL in Wind (1 min 43 sec)
Old Dec 15, 2012, 12:33 PM
ultralajt's Avatar
Joined Sep 2004
There are plans made by me for the Marabu.
Plans consists from 7 sheets of A0 paper format:
Both wings, 1:1 scale:
Fuselage and tail, 1:1 scale:
Regards!
Mitja
Old Dec 15, 2012, 02:10 PM
TP715 is offline
Find More Posts by TP715
United States, CA, Ridgecrest
Joined Dec 2011
Really nice slow flyer! I so enjoy RC planes that fly in a scale like manner instead of zooming around at a scale speed five times the Vne of the full size plane.
What is the wing loading? Somewhere around 30 gm/dm2? That's impressively low for such a large plane.
TP715 is offline Find More Posts by TP715
Old Dec 16, 2012, 04:51 AM
ultralajt's Avatar
Joined Sep 2004
WOW! You are pretty close! Wing area is 94,52dm2, which resulted at 3000g flying weight excatly 31 g/dm2.
Regardless of Marabu low weight, it is pretty tuff. I had an unattempted encounter with a tree and model was repaired in a day.
Low wing loading allow me to even catch a thermall ocasionally and gain altitude power off.
Large control surfaces makes this model very easy to fly. It doesnt posess any of bad habbits, it react well to the control inputs and is very predictable in flight.
As it is very large, fly very smooth and it is a great platform for taking aerial photos or videos:
GoPro2 Video:
MarabuGoPro01 (2 min 32 sec)
My village in winter:
Šentjanž HD (2 min 53 sec)
Thermalling:
http://www.youtube.com/watch?v=5dTjP3B1P8I
I think if I use some sort of gyro stabilization in future (plane or just camera gimbal) the videos will be great!
Mitja
Old Dec 16, 2012, 10:16 AM
Scott C is offline
Find More Posts by Scott C
son of a pilot
Scott C's Avatar
United States, GA, Peachtree City
Joined Aug 2000
Such a great model! Are the wing struts functional?
Scott C is offline Find More Posts by Scott C
Old Dec 16, 2012, 11:14 AM
ultralajt's Avatar
Joined Sep 2004
Yes, wing struts are functional. Thats why the wing could be made so light. Also There are no massive wing joiner tubes at the root, but only two short carbon tubes at the fuselage/wing joint.
Old Dec 16, 2012, 03:34 PM
rebell is offline
Find More Posts by rebell
JustFlying
rebell's Avatar
Joined Dec 2005
What motor, battery and prop are you using?
rebell is offline Find More Posts by rebell
Old Dec 17, 2012, 12:06 AM
ultralajt's Avatar
Joined Sep 2004
Motor: TURNIGY AERODRIVE XP C 3548-800
Battery: RHINO 20C 4S1P 3700mAh
Prop: APC E 13/6.5"
This setup allow very short take of, steep climbing and about 20 minutes of normal flying (some loops, climbs and power off "gliding") with reserve for some repeated landings.
As I saw that aerotowing was almost scale, regarding climbing slope, it is better to pull glider up with more power, so I intend to install another motor, which will give vertical climb performance (3D performance), but I know this power should be handle with care...full power on climbing or towing only.
The motor will be: TURNIGY 4258-800
Old Dec 17, 2012, 08:46 AM
rebell is offline
JustFlying
rebell's Avatar
Joined Dec 2005
Interesting. I never saw a APC 16x3, where did you get it?
Old Dec 17, 2012, 02:38 PM
ultralajt's Avatar
Joined Sep 2004
OOPS, my typing mismatch! Thanks for noticing!
Propeler is APC Electro 13/6,5"
(Corrected now in post above)
The propelers I purchased for the TURNIGY 4258-800 are APC E 14/7" and 13/8".
Will see which will be better.
Regards!
Mitja
Old Dec 29, 2012, 01:54 PM
ultralajt's Avatar
Joined Sep 2004
Video from today`s flying:
Last flight in 2012? (4 min 6 sec)
Build Log Build log PIK-7 Harakka II, 1:4 (2,65m) with free plan tuootal Scale Sailplanes 156 Mar 17, 2015 11:07 AM
Discussion Giezendanner Marabu 1972 (most likely year) kit. bossee Classic Pattern Flying 18 Oct 12, 2013 02:27 AM
Build Log My Giant Parkflyer MARABU ultralajt Parkflyers 39 Dec 16, 2012 09:16 AM
Discussion Would 800W motor with 1150 do for a 2-3kg-ish RCM trainer? minivation Power Systems 5 Aug 27, 2011 12:22 PM
Discussion Marabu 6 Lone Ranger Electric Sailplanes 0 Dec 21, 2008 03:09 PM
