Old Dec 14, 2012, 05:37 PM
Rich Uravitch is offline
Find More Posts by Rich Uravitch
Rich Uravitch's Avatar
Florida
Joined Sep 2001
S-3 Viking redux
Got a little sidetracked with the 90mm S-3 build but it's back on track and just about ready for paint. Did manage to build another 70mm version (60" span) in the meantime though. Here are some shots. Centennial of Naval Aviation (CONA) scheme. "Flight" shots courtesy of PhotoShop!!
Rich
Rich Uravitch is offline Find More Posts by Rich Uravitch
Old Dec 14, 2012, 05:44 PM
turbonut is offline
Find More Posts by turbonut
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
now that looks cool!
Old Dec 14, 2012, 06:37 PM
Kevin Cox is offline
Find More Posts by Kevin Cox
EDF Jet Jam 2016, June 16-19
Kevin Cox's Avatar
St. Louis Intl, Missouri, United States
Joined Jan 1997
Nice!
Kevin Cox is offline Find More Posts by Kevin Cox
Old Dec 15, 2012, 10:44 AM
PANTHERFLYR is offline
Find More Posts by PANTHERFLYR
Retired C-5 Flight Engineer
PANTHERFLYR's Avatar
United States, CA, Fairfield
Joined May 2005
Awesome Rich! Nick
PANTHERFLYR is offline Find More Posts by PANTHERFLYR
Old Dec 15, 2012, 11:28 AM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
man, that's sweet. there's just not enough of these out there. I'd love a huge one for Dynamax power and a smaller version like either of these for every day flying.
Rich
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Jan 02, 2013, 05:39 PM
BadLemon is offline
Find More Posts by BadLemon
Just having fun before I die!
BadLemon's Avatar
DeKalb,IL
Joined Dec 2008
Rich
Your S3 Viking is very nice what are the spec's for your 90mm? I'm guessing the wings span is around 85"
BadLemon is offline Find More Posts by BadLemon
Old Jan 04, 2013, 02:44 AM
sloperjoe is offline
Find More Posts by sloperjoe
sloperjoe's Avatar
United States, WA, Vancouver
Joined Mar 2012
I like it!
are those swing forward retracts? nice idea
Joe
sloperjoe is offline Find More Posts by sloperjoe
Old Jan 04, 2013, 06:57 PM
Florida
Joined Sep 2001
BadLemon.....just short of 87" with the ESM pods in place.
Joe.....good observation. I designed the models to accept off the shelf, 90 degree retracts to avoid expensive rotating units. The geometry works out great and the forward retraction allows the retracted gear to be mostly hidden by the nacelle. The full scale S-3 gear retracts aft, which I didn't want to do on the model because of the aft CG shift when the gear was retracted.
Rich
Old Jan 05, 2013, 02:07 AM
sloperjoe's Avatar
Joined Mar 2012
thanks for the pic, I was wondering how you did that, now that is "thinking out of the box", very nice!
Joe
Old Jan 09, 2013, 06:52 PM
BadLemon is offline
BadLemon's Avatar
DeKalb,IL
Joined Dec 2008
Rich
Rich
Good size wing the Viking is going to be a very big EDF Jet! Do you have a release date set for the S-3 are you going to release the 70mm first then the 90mm some time later?
I see your using the E-Flite electric retracts are they the 25-.46 or the 60-120? I installed a set of 25-46's in a 52" OV-10 Bronco you designed. They work great and have held up well. I put a 105deg retract unit in the nose that retracts forward like scale and the mains to the rear. This keeps the CG correct in both up and down positions so no trim changes need to be made.
Old Mar 11, 2013, 02:02 PM
Florida
Joined Sep 2001
90mm version came out at 16lbs, ready to fly
Rich
Old Mar 11, 2013, 02:11 PM
mike2663 is online now
Find More Posts by mike2663
Hey Guys, Watch This.......
mike2663's Avatar
USA, TX, El Paso
Joined Dec 2003
Rich will there a short kit?
mike2663 is online now Find More Posts by mike2663
Old Mar 11, 2013, 02:19 PM
BadLemon is offline
BadLemon's Avatar
DeKalb,IL
Joined Dec 2008
Looks great Rich so when is the maiden? Good Luck!
Old Mar 11, 2013, 02:25 PM
eatond is online now
Find More Posts by eatond
EDF Jet Jam 2017, June 15-18th
eatond's Avatar
United States, MO, St Charles
Joined Nov 2002
Hi Rich,
the S3 looks great. Any chance you might make the EDF Jet Jam in September? It be great to see your S3's do their thing.
Dan Eaton
eatond is online now Find More Posts by eatond
Old Mar 11, 2013, 06:18 PM
Florida
Joined Sep 2001
Thanks, guys. I plan to fly the large one later this week. Taxied it yesterday to check acceleration and it seems like there's more than enough available. Will let you all know, thanks again!
Rich
Video 70mm S-3 Viking video Rich Uravitch Electric Plane Talk 10 Dec 03, 2012 06:58 PM
Discussion S-3 Viking progress Rich Uravitch Scratchbuilt EDFs 14 Aug 13, 2012 06:06 PM
Found Retracts/ Spring loaded fixed gear for Wattage S-3 Viking kmdunnster Aircraft - General - Miscellaneous (FS/W) 5 Jun 26, 2012 10:25 PM
Found S-3 Viking EDF kmdunnster Aircraft - Electric - Jets (FS/W) 6 May 21, 2012 01:07 AM
Sold Wattage S-3 viking wing gromitvt10 Aircraft - Electric - Airplanes (FS/W) 1 Mar 17, 2012 10:27 AM
