Old Dec 31, 2012, 12:04 PM
Registered Slopeaphile
awmeade's Avatar
S-u-A, UK.
Joined Jan 2003
Due to shipping constraints, I'd be interested in the glassfibre fuselage pod on its own.
awmeade is offline Find More Posts by awmeade
Old Dec 31, 2012, 01:46 PM
patternpilot1's Avatar
USA, TN, Knoxville
cool... let me get this one finalized and I will work up a price for the pod.. The current wing configuration of a plug in center and glue on the tips, the wing is small. I will post all that specs shortly... well sneaking off to the shop now while all the family is visiting... my quiet time
patternpilot1 is offline Find More Posts by patternpilot1
Old Jan 01, 2013, 09:53 AM
USA, TN, Knoxville
well been working on the horizontal stab mount and trying to see how to make it easier for production run. I will have photos on this later today.
Old Jan 04, 2013, 12:00 PM
USA, TN, Knoxville
got some work done and will get photos and update shortly, I had to travel over the last few days and hope to be home in a few days to gt this done and flown.
Old Jan 07, 2013, 08:04 PM
Every day Im FPV'n
chanyote66's Avatar
United States, TN, Oak Ridge
Joined Dec 2011
nice work... I may be interested but shipping to me may be pricy
Chris
chanyote66 is online now Find More Posts by chanyote66
Old Jan 09, 2013, 07:59 AM
USA, TN, Knoxville
Chris,
Yeah from Knoxville to Oak Ridge..might even have to clear customs and have special permitts...
Hope to have some more done on this soon... have a family issue come up and has been keeping me out of the work shop.
S.
Old Jan 13, 2013, 02:09 PM
USA, TN, Knoxville
okay.... well got some stuff done today, the wings are all ready , this version will have 3/4 oz glass cloth with West epoxy and then primed and painted.. I'm thinking most will go with a monokote wing for additional weight savings... so in to keep the epoxy "soak" down i sealed the wings with min wax sanding sealer, I do this also when sheeting foam wings with either epoxy or the poly based glues. The wings hanging up drying right now.
I did a check of the payload mound and battery mount and all is good there, photo to be added.... As a kit version the builder will have the choice of how to make a mount for all the fun stuff. My mount is made of honeycomb nomex/fiberglass light weight but $$$
I also worked on the tail boom and cut the slot for the stab this prototype will have a glassed foam stab with a live hinge on it from another version we flew. The production version I have not decided on what is to be done, and it may be a option that you the customer can add....
The horizontal stab has been glued in place, now the add the vertical and then glue the boom into the pod....we have already been working on some new ideas for their where maybe the boom will slide into a sleeve/fitting on the pod.
The nose will be hinged on the top to open up and slide the try out for battery and payload change, the camera will either be in the nose or out on the wing, still looking at this.
The goal is 1+ hour of flight time ! and be able to cover a large distance or keep in orbit at a point for extended times.
I hope to get the wings glassed this week, some of the other small stuff.
As always the end user could always make access thru the side of the pod to get to gear, my feeling to this you either have to stand the plane up on the wing or have some sort of stand,with nose access it just flips up onto the wing for easy access..
The wing has been mounted to the podnow, and 1/4x20 nylon bolts will be used into T nuts.
pics added.
Old Jan 13, 2013, 02:11 PM
Every day Im FPV'n
chanyote66's Avatar
Joined Dec 2011
do you get your fiberglass local or order it?
Chris
Old Jan 13, 2013, 02:12 PM
USA, TN, Knoxville
more pics....
Old Jan 13, 2013, 02:53 PM
USA, TN, Knoxville
Chris,
I have alot of the materials for making molds and the lay-ups in house... I do order online from various vendors depending on price and what I need.
S.
Old Jan 13, 2013, 02:56 PM
USA, TN, Knoxville
more photos
Old Jan 13, 2013, 10:32 PM
Every day Im FPV'n
chanyote66's Avatar
Joined Dec 2011
Originally Posted by patternpilot1 View Post
more photos
ha! secrets out... thats XPS in the tail...
For production ones may want to go to EPS (2"x4'x8' at lowes for $25) it has half the density of XPS and is great to hotwire and wrap...
Chris
Old Jan 14, 2013, 07:52 AM
USA, TN, Knoxville
Chris,
No secret... Yep that is home depot pink foam for the stab..It is Magnum Models stab we used for testing, ( foam with a glassed/carbon surface no wood)
The production version will be a bit different to help keep the cost down.
The wing a different foam that is sheeted with 1/32 balsa.
I will be sanding the wing today and getting it ready for the glass.
I did some work late last night and am working on the nose / hinge system and latch system.
s.
Old Jan 15, 2013, 04:46 PM
USA, TN, Knoxville
okay, got the nose hinge system figured out.. Had to do some mod, so most likely will make a new plug and mold for production version to help in the build process.
Wings got a light sanding and now are ready for glass... See if I can get the wife to help with this... The wing will be covered in 3/4 oz glass and epoxy then primed and painted.
The boom is almost ready for install and gluing. then sand and prime all and a quick coat of pain and install of gear... thinking about running the push-rods down the center of the boom.. make it look cleaner..
hope to get into the shop tonight...
s.
Old Jan 17, 2013, 11:59 AM
Joined Jan 2013
Great Build. Would be interested in one of this when completed. Please let me know. Thanks
prinnceb is offline Find More Posts by prinnceb
Discussion Need a Charger for my AirField Sky Trainer Upgraded Version Airplane. gauiguy200 Batteries and Chargers 1 Mar 26, 2012 06:28 PM
MY 2200 watt E-raven flys ! gjestico Electric Heli Talk 41 Dec 22, 2004 11:47 AM
1 Fish, 2 Fish, Red Fish, I crashed my Raven! LuckyArmpit Electric Sailplanes 5 Apr 25, 2004 06:54 PM
Idea My contribution: Axi 2808/20 data and Dymond Raven performance ohms Power Systems 2 Apr 05, 2004 07:10 PM
