Old Dec 21, 2012, 02:47 PM
theKM is offline
Find More Posts by theKM
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
well, it looks like the DivBee satellite will have a hard case, and the servo output for the larger planes will be a more serious hard mountable pcb style thing...
...but for labels, for any I want to keep around, I just wrap 1" of transparent scotch tape around it and call it good.
theKM is offline Find More Posts by theKM
Latest blog entry: Updated Hatcam - Apr2016
Old Dec 21, 2012, 03:16 PM
rcbirk21 is offline
Find More Posts by rcbirk21
Barefoot Birkinsomething
rcbirk21's Avatar
United States, CA, Hayward
Joined Aug 2004
im sure i missed where this was described...but what is the purpose of the satellite?
rcbirk21 is offline Find More Posts by rcbirk21
Old Dec 21, 2012, 04:00 PM
theKM is offline
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
basically separating the signal management from the servo output.
you've seen my 104 install with the Nanos up in the turtledeck and just the signal wires being connected?... well it sounds like this will be the norm for XPS receiver setups, the signal management will be separated from the servo output, and it will only need a single standard servo extension between the receiver satellite/snorkel/whatever (AKA: "Rx SSW" unit) unit and the servo output unit. So you can put the antenna in the best possible location, and the servo connections in the most convenient location.
The Nano can actually handle all 16 channels of input, so only one Nano will be needed even on the giant stuff if using these servo output/channel-expander boards... and in sexy fashion only one wire up to the Nano. When the DivBee version of the SSW unit arrives, then it will gain its superior range, ability to handle the telemetry stream, a plastic case, etc.
...and, even better... it means that a setup with a Nano as the SSW unit can be swapped out for a DivBee SSW if one needed to upgrade for telemetry or some reason without disturbing the servo output setup. I seriously love this whole pattern, totally superior.
Jim's mentioned that it could possibly even talk Futaba's SBus or Spek's module output... so a Futaba SBus receiver or a Spek module could take on the role of the SSW unit.
Old Dec 21, 2012, 04:02 PM
rcbirk21 is offline
rcbirk21's Avatar
Joined Aug 2004
cool, sounds interesting. cant wait to see these new products hopefully make it to market
Old Dec 23, 2012, 03:20 PM
TTRotary is offline
Find More Posts by TTRotary
Rangers Lead the Way
Joined Mar 2010
Not a product idea (well it actually sort-of is...) add to the website all of the possible configurations and setup instructions discussed in these forums. An expanded user manual if you will. Include stuff like the fact that you can't re-cover the nano in shrink tubing...at least not the portion between the antennae. Also, i would write up a thorough technical discussion of the product to dispel common misconceptions - e.g. nano antenna length.
XPS RX technology sells itself once the tech capabilities are explained.
TTRotary is offline Find More Posts by TTRotary
Old Dec 23, 2012, 06:20 PM
JimDrew is offline
Find More Posts by JimDrew
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
Noted, thanks for your input!
JimDrew is offline Find More Posts by JimDrew
Old Dec 23, 2012, 06:45 PM
RyanNX211 is offline
Find More Posts by RyanNX211
Thermals, Tom
RyanNX211's Avatar
United States, OH, Upper Arlington
Joined Dec 2007
My request is a little different. I had thought about a thread called XPS for Dummies.
Some of us may be modelers but we're really not that astute on things electronic. A manual written like the ones included by mainstream manufacturers might be helpful to those who want the best but might not understand what the heck Jim Drew is talking about.
RyanNX211 is offline Find More Posts by RyanNX211
Old Dec 25, 2012, 10:28 PM
skubacb is offline
Find More Posts by skubacb
skubacb's Avatar
Tucson, AZ
Joined Aug 2006
Ryan,
I agree. Most people don't need or understand the real technical details. What they actually use is a rather simple explanation they might remember. Difficult in most circumstances to even get someone to read the manual.
Take a look at advertisements. That is just about all that most people can understand and retain.
Any deeper explanation would just be for the few tech heads out there that do read manuals. Those people are the ones that explain it to the rest of the group and recommend the gear to the rest. They do need a reasonable explanation of the system.
However, many, many people will still only believe what they read in the advertisements.
skubacb is offline Find More Posts by skubacb
Old Dec 31, 2012, 08:46 PM
Thermals, Tom
RyanNX211's Avatar
Joined Dec 2007
Old Jan 03, 2013, 08:38 PM
TTRotary is offline
Joined Mar 2010
Jim, I have another product idea: a full featured gear door sequencer in the $20-30 range that would do type 1 and 2 sequencing, have gear to gear delay, support servo speed commands from the radio or have it on-board the unit, and support from the radio or include on the board end point adjustments for the doors and even maybe for proportional servos.
The Jomar ($36) doesn't support or perform EPA, and the Assan($18) is wonky to use and does not support or perform on it's own servo speed. And the next price point up (jet something or rather) has crazy pricing. Think you could cook us up something - after Rxs and radio of course.
Old Jan 03, 2013, 09:05 PM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
I could use a Channel expander board to do that... just change the code.
Old Jan 03, 2013, 09:39 PM
TTRotary is offline
Joined Mar 2010
That would be great. I really think there is a market for that in that price range. Another nifty touch would be to include a separate power bus so that the user could run a separate RX battery or Bec for the retracts.
And, while I'm thinking about this, what would be totally bitchin' for the jet guys would be an integratable adjustable electronic air valve bus for tri-gear. Much neater install and more reliable.
Old Jan 04, 2013, 10:38 AM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
The channel expander has separate power inputs. I am a jet guy.
Old Jan 04, 2013, 01:07 PM
TTRotary is offline
Joined Mar 2010
Ah, Ok great. The warbird crowd, which includes me, would also really like you too for this type of product.
What jets do you have? Thinking of getting into turbines soon.
Old Jan 04, 2013, 05:24 PM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
Well, I have the fastest electric jet... actually two of them, one of which should be in the 260MPH range, the other was radar'd at 223.9MPH in a bad pass with dead batteries.. I have a Skymaster F-18, Graupner BAE Hawk, Skymaster F-15, Cermark F-16, Byron F-15, Byron F-86, Tom Cook F-4, Jet Legend T-45, Jet Legend F5, three Savex L-39s (one with Wren44, others with EDF), Habu-32, Habu, a bunch of little 50mm jets, and a dozen or so various turbine and EDF kits in boxes. I also have a few warbirds, and some 3D aircraft. For turbines I have a Graupner G160 and G80, Jetcat SX (160), Wren 44, and Lambert micro-turbine.
Discussion Product request/idea for MX-20 zaguruinzasky FPV Talk 0 Oct 26, 2012 06:37 PM
Discussion A product idea Stumblebee Multirotor Electronics 9 Aug 27, 2012 07:21 PM
Discussion Wanted ideas of a product or a product to sell me camaroz28325 Aerial Photography 5 Jan 26, 2009 11:05 AM
Product idea - ATV/Endpoint adjuster dgoebel Electric Plane Talk 0 Jun 26, 2001 08:38 PM
