Old Jan 01, 2013, 01:07 PM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
D, just make yourself a gravity feed setup for cutting cores. there's plans on here if you search them out.
Rich
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Jan 01, 2013, 02:26 PM
AirX is offline
Find More Posts by AirX
EDF rules... :)
AirX's Avatar
United States, TX, Katy
Joined Nov 1999
Originally Posted by Boogie_ View Post
Thanks Eric.
RCLander retracts.
According to the specs, they should be more than adequate for this model. Pretty beefy hardware.
Thanks Julian, those do look pretty beefy. I will be getting some to put in the Bobcat.
Eric B.
AirX is offline Find More Posts by AirX
Old Jan 01, 2013, 06:37 PM
pencon is offline
Find More Posts by pencon
Joined Dec 2008
Really interesting build Boogie , did you buy the plans or draw them up yourself?If you drew them up , how did you get the cross sections?
pencon is offline Find More Posts by pencon
Old Jan 02, 2013, 06:53 AM
Boogie_ is offline
Find More Posts by Boogie_
killed another thread
Boogie_'s Avatar
Lake Charles, Louisiana
Joined Jun 2009
The top view plan is a 3-view I got off the web. The side view and cross section templates were drawn up by Eric a couple years ago. I had my local print shop re-size both of them to match each other.
For the airfoil I used Profili to print out templates of the NACA 1410.
Boogie_ is offline Find More Posts by Boogie_
Old Jan 03, 2013, 06:35 PM
Boogie_ is offline
Boogie_'s Avatar
Joined Jun 2009
Got both wing cores cut out and couldn't resist setting them up to the fuse for a couple pics.
I was wrong about the first wing being a test cut. ...it took two.
The first try was a good cut but was just barely thick enough to fit the retracts in there. They fit ok, there was just not enough clearance for me. Any torquing from a bounced landing and I would possibly have dent in the wing skin.
So I wrapped the edges of both templates with 1/16 balsa and hardened them with CA. Then wrapped them with some copper foil tape I had left over from my slot track building days.
Worked like a charm. The wing is ⅛" thicker overall and the retracts fit comfy now.
On the second cut I screwed up my marks on the foam blank for spotting the templates.
Perfect cut, wing sweep all wrong.
Right now I'm debating whether or not to make the wings removable or make it a one piece airplane.
...any thoughts?
Julian
Old Jan 03, 2013, 11:47 PM
Joined Jan 2009
one word......................beauty!!!!!!
Old Jan 05, 2013, 02:06 PM
Waltjg is offline
Find More Posts by Waltjg
Waltjg's Avatar
Crystal River Fl.
Joined Jul 2008
Movin' along there Julian! Looks good man! w.
Waltjg is offline Find More Posts by Waltjg
Old Jan 05, 2013, 06:54 PM
Lmeano_from_MO is offline
Find More Posts by Lmeano_from_MO
Fast Jets for Fast times
Lmeano_from_MO's Avatar
St. Peters MO.
Joined Nov 2007
J,
When its time to glass the fuse plug will you work the matting around the entire plug or will it be in stages? The wing cutting look good.
Lmeano_from_MO is offline Find More Posts by Lmeano_from_MO
Old Jan 05, 2013, 08:20 PM
J Morgan is offline
Find More Posts by J Morgan
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
You can use overlaps but once you start glassing the plug, don't stop until you have the entire layup done. If you let the epoxy cure, new epoxy doesn't like to stick to it. You would have to sand the entire plug if you let it cure.
When I get ready to start a layup, I make a full pot of coffee, open a fresh pack of cigarettes, and turn my phone off!
J
J Morgan is offline Find More Posts by J Morgan
Old Jan 05, 2013, 08:52 PM
Boogie_ is offline
Boogie_'s Avatar
Joined Jun 2009
Thanks guys.
Yep, once you start glassing, don't stop.
Have to back track a little on my plug.
I left out an important step that I've seen John do when shaping the plug. After I had the former stations cut out in the foam I started sanding the entire thing without having a hard template at the nose and tail.
I merrily sanded away too much and it's almost a " too small in circumference at the exhaust end, the nose is ok. That foam really sands easy. It's got a very nice shape to it but is just too small.
Made balsa templates and glued them to both ends and will add some more foam to the tail and sand it all smooth again. No biggie, just delays getting to the final lay up.
Julian
Old Jan 11, 2013, 08:50 PM
Boogie_ is offline
Boogie_'s Avatar
Joined Jun 2009
Not too much progress on the MiG.
We've had Louisiana snow (cold rain) down here for over a week. I've had filler on the fuse, wings and stabs for 3 days and they still weren't dry. Finally had some warm sun so I set them all out side today and they're all ready for sanding.
...forecast to be cold and rainy all next week too.
Julian
Old Jan 12, 2013, 09:43 AM
AirX is offline
EDF rules... :)
AirX's Avatar
Joined Nov 1999
Hi J,
Looking good. I hope to see it at the spring flyin.
I am trying to get the T37 ready for the spring flyin, we will see how far I get by February.
Cheers,
Eric B.
Old Jan 24, 2013, 06:24 PM
St. Martin is offline
Find More Posts by St. Martin
Big gov never Works
St. Martin's Avatar
Skunk Water, Rhode Island
Joined Jul 2002
ahhh...so this is what you have been up to! I was kind of worried, at first. Then I saw your building a Morgan. That white stuff had me shakn'.
Fuzz
St. Martin is offline Find More Posts by St. Martin
Old Jan 24, 2013, 06:55 PM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
Boogie_ Definatly starting to take shape. Knowing the speed in which you build, it won't take you much longer. Once you get it air born, I am curious to see how that NACA 1410 airfoil works out. And if it doesn't, I will have time to select a different one for my build!
Mark
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Jan 24, 2013, 08:13 PM
AirX is offline
EDF rules... :)
AirX's Avatar
Joined Nov 1999
Yup boogies thread went quiet he must be busy...
Eric B.
Discussion Twin 90mm Composite Su-37 clinth01 Electric Ducted Fan Jet Talk 33 Jan 04, 2013 12:28 AM
Sold 90mm Composite BAE Hawk and 90mm Composite L39 kclements Aircraft - Electric - Jets (FS/W) 5 Sep 18, 2012 12:41 PM
Discussion HK Mig-29 composite Hixxer Electric Ducted Fan Jet Talk 6 May 20, 2012 07:15 AM
Sold Matrix 90mm All Composite BNF LPU in GA SEFF badbill Aircraft - Electric - Jets (FS/W) 3 Mar 05, 2012 06:17 PM
Sold NIB Wemotec Mig 15 90mm all-composite ARF FL62 Aircraft - Electric - Jets (FS/W) 1 Mar 05, 2008 07:53 PM
