I picked up a flu bug Friday so I've been saving all my energy for just the essential stuff around the shop. ...one of the joys of being the Boss is going to work when your sick.
I did managed to do a little sanding on the fuse. One more mud and sanding session and I should be ready for the first layer of glass. Jeff, I'm going to cut the glass off the plug and add formers. As of now I'm going with the oval exhaust. But I've got an idea for doing a more scale like splitter. We'll see. This fuse is huge, the exhaust area for the 90mm is way smaller that what I'm gonna have back there at the tail. J |
I was checking out an 8s set up for another project, and one Emile used looked good. Re: HET 700-68-1680 /JetFan 90 -------------------------------------------------------------------------------- Hi Mark, I'm using 1,5 year old Turnigy Nanotech 4s5000 (45c/90c) 2x. This setup pulls about 110amps at 3,25KW. It's hard to say how much thrust it generates. Inflight the Jetfan produces visibly more then shown in the graphs of ejets. I experience similar in my Habu. A HET 700-68-1500 on 8s would be enough for good flight performance but for grass takeoff more power is welcome His L-39 came in at 11lbs. I don't know how the Het/JetFan compare, just an idea of what you could expect with this. Courious as to what total weight cloth per sqyd you will go with? On my F-86F, not knowing any better I went with 3-layers of 3.7oz for a total of 11.1 oz per sqyd. Doing it over again I would only use 2-layers of heavier cloth. cold have save a bunch of weight. My fuse was 63" long and came out to a hair over 30oz. At a guess, you could come out with somewhere in the lower 20oz's with yours. Will be along for the ride!
J,
Looks like it is going to be the same size as the Tiger. When I do my next project I will try splitting it top to bottom instead of down the middle. It has been really difficult placing all the stuff that goes in an EDF on this one. I have been looking over BVM fuse access hatches and really like how it’s done. The Tiger is back on the bench an ready for more assembly. |
Joined Dec 2008
Hey Julian if it was me I'd skip the paint and just cover the 19 with riveted aluminum panels .I just started back on my Mig 21 and its a combo of aluminum tape and .005 aluminum from K&S hobby and some pop can AL .Then again , I cover pretty much everything with aluminum ..
No matter how you finish your project I'm sure it'll look very cool and completely original .
Yeah, me too!!
I thought I was going to have time to work on it at the shop during the short week after Christmas. It's usually dead this time of year but I was hoppin' Wed, Thurs & Fri. Hopefully I can get going on it tomorrow. Bad weather forecast down here all week, that usually slows business down a little. My retracts came in Wed, so now I have all the hardware and materials on hand to finish the MiG. |
Was able to get a wing core cut out today.
This is actually more of a test wing core. It may wind up getting hacked up as I try to get the angled retract geometry worked out. IF the wing is even thick enough out there in the middle where the retract needs to mount. According to my figgerin' it should be. I spent most of the afternoon cycling the gear up and down figuring out where exactly they needed to be mounted and how much I would have to angle the mounts to have the wheel oriented correctly when extended. I know there is a formula to figure this out, but you got to remember I got my edumacation in Louisiana. I do better working it out right in front of me. |
Hi Julian,
The core looks good, much better than my latest wing for the T37. What retracts did you get, I looked back but could not find it in the posts. Happy New Year, Eric B. |
Latest blog entry: T/A 37 Tweet/Dragonfly
Thanks Eric.
RCLander retracts. According to the specs, they should be more than adequate for this model. Pretty beefy hardware. |
| Thread Tools | |
| Discussion Twin 90mm Composite Su-37 | clinth01 | Electric Ducted Fan Jet Talk | 33 | Jan 04, 2013 12:28 AM |
| Sold 90mm Composite BAE Hawk and 90mm Composite L39 | kclements | Aircraft - Electric - Jets (FS/W) | 5 | Sep 18, 2012 12:41 PM |
| Discussion HK Mig-29 composite | Hixxer | Electric Ducted Fan Jet Talk | 6 | May 20, 2012 07:15 AM |
| Sold Matrix 90mm All Composite BNF LPU in GA SEFF | badbill | Aircraft - Electric - Jets (FS/W) | 3 | Mar 05, 2012 06:17 PM |
| Sold NIB Wemotec Mig 15 90mm all-composite ARF | FL62 | Aircraft - Electric - Jets (FS/W) | 1 | Mar 05, 2008 07:53 PM |
