Old Dec 16, 2012, 08:39 PM
DFC~ We Do Flyin' Right
bsbauman's Avatar
USA, GA, Atlanta
Joined Nov 2008
10-4
Trying to figure out what, if any differences there are between the 6208 and the 6008 Futaba rx's
bsbauman is offline Find More Posts by bsbauman
Latest blog entry: Burned Retina Shorts
Old Dec 16, 2012, 08:41 PM
It's just a hobby
MLT67's Avatar
USA, GA, Hoschton
Joined Nov 2005
By the way - it's ready to be picked up.
MLT
MLT67 is offline Find More Posts by MLT67
Old Dec 16, 2012, 08:44 PM
bsbauman's Avatar
USA, GA, Atlanta
Joined Nov 2008
You tha man!! Whats your schedule this week? I dont want to get in the way of family obligations...
Old Dec 16, 2012, 09:59 PM
bsbauman's Avatar
USA, GA, Atlanta
Joined Nov 2008
I must admit, my whole desire to do this scheme came from a combination of seeing Mercer's UGA plane and Clint Sweets. Had you all seen Clint's work? http://www.flyinggiants.com/forums/s...ad.php?t=64649
Old Dec 16, 2012, 10:19 PM
bigmoebbq's Avatar
Lawrenceville, GA
Joined Mar 2008
yea my scheme does not even compare to that one. It is amazing!
bigmoebbq is online now Find More Posts by bigmoebbq
Old Dec 19, 2012, 11:08 AM
bsbauman's Avatar
USA, GA, Atlanta
Joined Nov 2008
Chris~ How do you typically go about applying decals? Is there a proper method to ensure everything stays lined up, or do you typically eye-ball it?
Old Dec 19, 2012, 02:37 PM
bigmoebbq's Avatar
Lawrenceville, GA
Joined Mar 2008
Most of mine are different on each side. So I usually eyeball it.
Old Dec 19, 2012, 02:41 PM
It's just a hobby
MLT67's Avatar
USA, GA, Hoschton
Joined Nov 2005
Rookie
Old Dec 21, 2012, 06:58 PM
bsbauman's Avatar
USA, GA, Atlanta
Joined Nov 2008
I have been using your advice, marking reference points, lining up, piece at a time... Very helpful! While I did not execute perfectly, it is coming along well.
I am curious, how do you go about placing a graphic over a hinge line? In the case of the ailerons, does it look best to seal the hinge with the decal, or to cut the decal?
In the case of my rudder decals, I have the hinge and the counterbalance of the rudder to deal with... not sure where to even begin to get this right.
more pics coming...
Old Dec 21, 2012, 07:03 PM
bigmoebbq's Avatar
Lawrenceville, GA
Joined Mar 2008
I lay them over the hinge then just cut down the middle and let it lay where it hits. should be free of the hinge.
Old Dec 21, 2012, 07:05 PM
bsbauman's Avatar
USA, GA, Atlanta
Joined Nov 2008
thanks
Old Dec 21, 2012, 09:03 PM
It's just a hobby
MLT67's Avatar
USA, GA, Hoschton
Joined Nov 2005
Ditto - but also use a ruler to make sure the cut is straight
Old Dec 21, 2012, 09:16 PM
bsbauman's Avatar
USA, GA, Atlanta
Joined Nov 2008
Not perfect, but I did get both sides pretty close to symmetrical. Marking reference points as you suggested is the only way to do this, but it also takes some practice and a more steady hand than a normal covering job. I imagine I will only get better at this... The only change I would make so far would have been to go larger with the piece on the tail, or at least put it higher. Both sides are aligned perfectly with each other on the tail.
I have a few more additions to add, including decals on the hood and canopy. Not sure if I will go with the stripes as suggested in the plan above, if I will use the school seal, or a block lettered "GEORGIA TECH". Also plan to add some graphics on the bottom of the ailerons and on the SFG's. Then find a pilot...
Old Jan 07, 2013, 07:44 AM
bsbauman's Avatar
USA, GA, Atlanta
Joined Nov 2008
Mercer that new ga plane is sick! Show it off
Old Jan 07, 2013, 08:09 AM
bigmoebbq's Avatar
Lawrenceville, GA
Joined Mar 2008
lol Ok here are a few I have or had..
For Sale Parkzone micro mosquito>>>>bnf>>>>lpu>> ED3 Aircraft - Electric - Micro & Indoor Airplanes 7 Dec 15, 2012 12:47 PM
For Sale Servo tester >>>>>>look>>>> ED3 Aircraft - General - Miscellaneous (FS/W) 17 Oct 08, 2012 12:24 PM
For Sale Sullivan floats>>>>>>>>REDUCED lectroglide Aircraft - Electric - Miscellaneous (FS/W) 0 May 23, 2012 03:10 PM
For Sale Servo tester >>>>>>look>>>> ED3 Aircraft - General - Miscellaneous (FS/W) 16 May 07, 2012 07:11 AM
For Sale cermark lil banchee 3d >>>>>>LPU>>> ED3 Aircraft - Electric - Airplanes (FS/W) 1 May 05, 2012 04:26 PM
