Old Dec 13, 2012, 12:05 PM
Mike Denest is offline
Find More Posts by Mike Denest
Brighto?
Mike Denest's Avatar
United States, DE, Newark
Joined Dec 2003
Some Suggestions Needed
I have a set of scanned drawings I'd like to work with. The drawing set was originally completed on mylar and this set is a copy of those drawings. Unfortunately the original mylars have been lost so I am left with is this. The drawings were scanned as .tif files which I imported into my CAD program (Progecad, an Autocad clone). I have done this before with Autocad with good success. The scanned drawings were possibly reproduced on the ozalid process. I believe that the scan rate may have been too high as the imported .tif is loading the background paper, causing all the black areas that mask the detail I want to trace.
I question is how can I clean up the .tif files without too much work. MS Paint isn't the way to go!
Mike Denest is offline Find More Posts by Mike Denest
Old Dec 13, 2012, 12:55 PM
RCROBBY is offline
Find More Posts by RCROBBY
Laser Cutter Guy
United States, PA, Greensburg
Joined Oct 2009
Have you tried Corel yet?
RCROBBY is offline Find More Posts by RCROBBY
Old Dec 13, 2012, 12:57 PM
Brighto?
Joined Dec 2003
Not yet. I don't have a current copy but if I can get one cheap enough I'll give it a go.
Were you referring to Corel Draw or Paint Shop?
Old Dec 13, 2012, 02:27 PM
RCROBBY is offline
Laser Cutter Guy
Joined Oct 2009
Corel draw, use the trace commands and it play with the detail levels and you should get close. Lots of cleanup work but you will get it.
Help! Need some plane suggestions Fltoig Beginner Training Area (Aircraft-Electric) 16 Oct 20, 2012 11:36 AM
Discussion 104" PBY Catalina. Need some motor/prop suggestions. crimsonride Power Systems 3 Aug 10, 2012 06:35 AM
Discussion I need some suggestions firehawkzach Foamy EDFs 7 Mar 26, 2012 11:41 PM
Zagnutz built, now I need some batteries.. suggestions? G1K Batteries and Chargers 1 Dec 09, 2002 03:20 PM
Need some BL suggestions Battfly Power Systems 2 Dec 02, 2002 09:57 AM
