Old Jan 09, 2013, 02:05 AM
slebetman is offline
Find More Posts by slebetman
slebetman's Avatar
Malaysia, Selangor, Kajang
Joined Jun 2009
Originally Posted by Stupot46 View Post
Neat.Just put one inside the other and mark over.Locating plastic cups without any "ribbing" could be a problem,I'll have to see what I can find,something I could tinker with in a quiet moment.
Stuart
One alternative I've started playing with is tracing paper. It's actually lighter than the plastic cup. And with the camber is fairly stiff. But it needs some balsa spars to prevent it from bending under load.
slebetman is offline Find More Posts by slebetman
Old Jan 09, 2013, 07:18 AM
Cap_n_Dave is offline
Find More Posts by Cap_n_Dave
Joined Mar 2008
Originally Posted by slebetman View Post
I decided to rebuild the prop and tail block. I realized that the rather loose fit of the prop shaft would make trimming up or down thrust impossible. I'm taking this opportunity to document how the prop is built.
Cool.
A similar approach with a different blade shape ... the Clem prop:
There is an error on that image, the angle of the centerline of the blade should be 23 degrees and not 32 degrees.
Cap_n_Dave is offline Find More Posts by Cap_n_Dave
Old Jan 09, 2013, 08:36 AM
slebetman's Avatar
Joined Jun 2009
Originally Posted by Cap_n_Dave View Post
Cool.
That's interesting because my props are oriented the opposite way: the root at the bottom of the cup and the tip at the top. The bottom of the cup has more camber and most electric slowfly props I've seen have more camber towards the root and are almost flat at the tips.
Mine has a 20 degree tilt so that's similar.
Old Jan 10, 2013, 06:19 AM
Joined Mar 2008
I made a fairly large one for a Baxter XE-5 and a smaller one for a Baxter P-Cat ... I thought they were pretty darned good.
Why don't you give one a try?
Old Jan 12, 2013, 12:40 AM
dayhead is offline
Find More Posts by dayhead
SlingWinger
San Bernardino, California, United States
Perhaps you're familiar with the Swift hang glider design. The name stands for "Swept Wing with Inboard Flap for trim".
If your planform has enough sweep, you can lower the trailing edge in the inboard, or root area of the wing to get a nose-up pitching moment. In many cases this is better than increasing reflex in the outboard, or tip area of the wing. I use this to get better sink rates from my Sling Wings.
dayhead is offline Find More Posts by dayhead
Old Jan 12, 2013, 01:02 AM
derk is offline
Find More Posts by derk
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
i built a small free flight balsa glider that had inboard flap trim. it made for a very nice flight envelope, on launch it would fly fast and a mild pitch up and then transition to a slow stable glide. the only explanation i could come up with was that during high speed flight, the flaps' upper airflow separated until it slowed down enough to reattach. wore out my arm throwing that little thing many times
derk is offline Find More Posts by derk
Old Jan 12, 2013, 02:39 PM
slebetman's Avatar
Joined Jun 2009
Isn't increasing twist better still? Increasing up elevator and deploying flaps both deform the airfoil. Increasing twist increases the difference of incidence between the root and the tips. Which is exactly the same as deploying flaps without making things draggy.
Flaps do have another effect that matters though. They can increase the camber of the root airfoil (or decrease if you deploy them "up"). This is what most RC glider pilots use flaps for - to control the behavior of the airfoil. This is neither better nor worse than increasing up elevator (indeed, deploying flaps often upsets trim and has to be accompanied by changes to the elevator). It's just a different thing to control.
For free flight stuff the same effect can be had by choosing different airfoils for root and wing tips.
Old Jan 20, 2013, 03:27 AM
slebetman's Avatar
Joined Jun 2009
She flies! Very well behaved too. But she needs a fairly large space to fly in. The turning circle is quite large. Could just about fly in our indoor venue but kept hitting the walls. Finally gave up when a crash into a wall cracked a longeron.
Today I fixed her up and decided to try flying outdoors. Was trying to trim her for a tighter turning circle but it was too windy to tell if it worked. But she flew beautifully.
Here's a video of a 30 second flight:
Rubber powered wing (0 min 22 sec)
Old Jan 20, 2013, 06:30 AM
Stuart A is offline
Find More Posts by Stuart A
You know nothing....
Stuart A's Avatar
Joined Sep 2011
Wow,that thing really moves well!Did you recover it ok/in one piece?
Stuart A is offline Find More Posts by Stuart A
Old Jan 20, 2013, 08:25 AM
Joined Mar 2008
Cool. Does she usually fly that fast, or was that an artifact of the wind?
Old Jan 20, 2013, 08:34 AM
slebetman's Avatar
Joined Jun 2009
Yeah. The camera angle is a bit deceptive. It didn't fly off field. In the last few seconds of the footage you can just about see a goal at the end of the field. It landed about 5 meters in front of it.
Old Jan 20, 2013, 08:45 AM
slebetman's Avatar
Joined Jun 2009
That's most probably due to the thickness of the rubber. She flies at roughly the same speed indoors.
I used .085 on that flight. I tried 1/16 (.0625) but it didn't provide enough thrust. I think .070 or .075 would be better. But I don't have rubber at those sizes and I don't (yet) have a rubber stripper.
I've ordered some .075 and I've also bought a rubber stripper. Both are on their way. So later I'll be trying it with lighter rubber and see if it flies any better.
Old Jan 26, 2013, 01:55 PM
slebetman's Avatar
Joined Jun 2009
Finally managed to trim it for indoor flight. Used thinner rubber - .075 vs the previous .085. Now it's flying much slower but still with enough power to climb.
Trimmed it to fly left circles. Since this is a reverse prop it's the same as trimming a regular plane to fly right circles - meaning that it's circling the opposite of the torque.
Part of my problem earlier was that the plane started flying straignt as the rubber wound down. Which is bad for indoor because it kept flying into the walls towards the end of the flight. Trimming it to fly the opposite of the torque eliminates this problem. As a bonus, the torque prevents the plane from banking too far into a spiral.
To trim it for left circles I added a lot of left thrust and some up elevon trim tab on the left wing and a couple of drag rudders on the left wing.
Here's a video of a flight from tonight's session:
Flying wing trimmed for indoor (0 min 50 sec)
Old Jan 26, 2013, 02:51 PM
slebetman's Avatar
Joined Jun 2009
Here are some pictures of the trim tabs I added.
Old Jan 26, 2013, 03:14 PM
slebetman's Avatar
Joined Jun 2009
Here's another rubber powered flying wing project I've posted in the Free Flight forum:
http://www.rcgroups.com/forums/showthread.php?t=1818182
Question Advise on wing twist for rubber powered wing slebetman Nurflügel 4 Dec 13, 2012 08:46 AM
Question Balsa folding wing plane powered by rubber slingshot ? cyclops2 Hand Launch 7 Oct 31, 2012 08:50 AM
Question Top/Bottom or I-Beam spars in rubber powered plane wings??? Pauliwog Free Flight 16 Oct 01, 2012 12:12 PM
Discussion Rubber Powered Flying Wing cherobee 3D Foamies 1 Sep 15, 2012 09:49 PM
