Old Dec 13, 2012, 10:22 AM
slebetman is offline
Find More Posts by slebetman
slebetman's Avatar
Malaysia, Selangor, Kajang
Joined Jun 2009
Build Log
Penut size rubber powered wing
Here's something a bit different. An indoor rubber powered wing.
I often use the online CG calculators as the starting point for designing wings. Here's a CG calculator link for the basic design parameters: http://fwcg.3dzone.dk/?wing_span=14&...ow_mac_lines=0
Based on Norm's advise I decided to start with a 5 degree twist and just build a prototype and see how it flies. I'll adjust the plans later if necessary.
Here's the "final" version of the plans for the prototype. The actual "final" plan will only be finalized once I've got it flying successfully. It's a pusher in case it's not clear from the plans.
note: updated to include the latest plan.
slebetman is offline Find More Posts by slebetman
Old Dec 13, 2012, 11:15 AM
slebetman's Avatar
Joined Jun 2009
Mounted the plan onto a building board. Tacked templates onto sheet balsa with spray mount. And cut out the ribs. That's it for tonight.
I'm using 1mm balsa for everything. That's actually roughly 1/24" but my balsa is fairly heavy. With good, light balsa you can use 1/16 or 1/20.
Old Dec 13, 2012, 02:11 PM
Stuart A is offline
Find More Posts by Stuart A
You know nothing....
Stuart A's Avatar
Joined Sep 2011
Do you think it might be worth trying without dihedral/ wing tips?I've had good results from similar wings with just the twist.
Regards Stuart
Stuart A is offline Find More Posts by Stuart A
Old Dec 13, 2012, 05:45 PM
slebetman's Avatar
Joined Jun 2009
Regards Stuart
In my experience, free flight wings would spiral without dihedral. It would fly straight OK but free flight planes are usually trimmed to do circles. It may be worth a try though because I just realized that putting in the dihedral risks undoing the twist.
I missed a trick there. Should have baked in the dihedral into the templates the same way I did the twist.
I think I'll try without dihedral first. Found this model of a Lippish Storch that has practically zero dihedral and it seems to fly quite well:
There's a video of it on this page (scroll to somewhere in the middle): http://www.ffscale.co.uk/page3ii.htm
Old Dec 13, 2012, 08:12 PM
Cap_n_Dave is offline
Find More Posts by Cap_n_Dave
Joined Mar 2008
The sweep contributes a dihedral effect, reducing the need for geometric dihedral.
Cap_n_Dave is offline Find More Posts by Cap_n_Dave
Old Dec 14, 2012, 01:10 PM
slebetman's Avatar
Joined Jun 2009
Got a lot done today. Wings built and covered. There's an error in the plans. The trailing edge of the ribs don't line up properly. I'll fix it later. For this build I just cut a few of the rib supports to get the trailing edge to line up.
Progress pics:
Old Dec 14, 2012, 02:51 PM
Stuart A is offline
Stuart A's Avatar
Joined Sep 2011
Nice work! Have you decided on rubber/prop dimensions?
Old Dec 14, 2012, 11:32 PM
slebetman's Avatar
Joined Jun 2009
Prop will be 5" with a pitch of about 33 degrees. I'll try a 12" loop of 1/16 rubber first.
Old Dec 15, 2012, 05:49 AM
xlcrlee is offline
Find More Posts by xlcrlee
Joined Apr 2006
thick & thin
The Wright Bros. used data they gathered from their own small wind-tunnel. As a result, they copied and merely greatly enlarged the wing-form shown to work best in their small-sized tunnel. HOWEVER, they were not aware of Reynold's work which was published a half-century earlier.
The small which worked best in their small tunnel were THIN, like a butterfly's. So on their man-carrying craft they had to use TWO thin wings with canterlever support from wires for strength.
It wasn't until Tony Fokker discovered that thick wings not only could contain the canterlever structure ... but actually WORKED much better [L/D] at fullsize speed & size.
Your wings are far too thick for best performance at "rubber-powered Peanut" size ....!!
Look at the wings of similar-sized rubber models with excellent performance:
http://marinaero.blogspot.ch/2008/08...ed-flight.html
http://www.oocities.org/capecanaveral/1245/sportrbr.htm
http://www.sciencetoymaker.org/plane/index.htm
Lee
xlcrlee is offline Find More Posts by xlcrlee
Old Dec 16, 2012, 05:25 PM
BMatthews is offline
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
It may not be optimized but it'll fly well enough to get the idea.
Slebetman, that model of the Storch flies OK due to the wing being mounted up on struts so the 3D Center of Gravity is well below the lift point. That produces a pendulum like stability. The shoulder wing mount of this model will do this to some extent. But you may well find that you end up needing SOME dihedral to be added unless you can fly it in a rather big circle.
A rule of thumb I've read of in the past is that 30 degrees of sweep equates to about the same roll stability as 5 degrees of real dihedral.
BMatthews is offline Find More Posts by BMatthews
Old Dec 18, 2012, 06:12 AM
xlcrlee is offline
Joined Apr 2006
In this size, w.r.t. endurance, penetration and even stability, thick vs thin wings > BIG difference!
Lee
Old Dec 18, 2012, 08:49 AM
Joined Mar 2008
slebetman ... keep at it, am interested to see your results!!
Old Dec 18, 2012, 08:51 AM
Joined Mar 2008
Originally Posted by xlcrlee View Post
I strongly disagree: my 65+ years of model plane design & building tells me distinctly otherwise, esp. in this size, w.r.t. endurance, penetration and even stability > BIG difference!
Lee, perhaps you should read this site about logical fallacies. Appeal to authority = fail.
Old Dec 18, 2012, 11:48 AM
birdofplay is offline
Find More Posts by birdofplay
Retired CAD guy
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
Another fallback would be the Worlds Foremost Authority, aka Prof Irwin Corey.
http://www.irwincorey.org/
At least he was a comedian.
birdofplay is offline Find More Posts by birdofplay
Old Dec 18, 2012, 11:38 PM
nmasters is online now
Find More Posts by nmasters
internet gadfly
nmasters's Avatar
Colorado
Joined Aug 2006
Carlo Godel also called himself "the world's foremost authority" but he always wrote it in crayon. I wouldn't say that stating that thick airfoils won't perform as well as a flat, or slightly curved, plate at the Reynolds numbers of a 1.5 inch chord rubber model is a logical fallacy. It's simply a demonstrated fact that at Re<50,000 a plate will have lower drag than a thick section. Better pitch stability can also be expected because of separation on the lower surface. Using several thin spars instead of one thick one would also help.
--Norm
nmasters is online now Find More Posts by nmasters
Question Advise on wing twist for rubber powered wing slebetman Nurflügel 4 Dec 13, 2012 08:46 AM
Question Balsa folding wing plane powered by rubber slingshot ? cyclops2 Hand Launch 7 Oct 31, 2012 08:50 AM
Question Top/Bottom or I-Beam spars in rubber powered plane wings??? Pauliwog Free Flight 16 Oct 01, 2012 12:12 PM
Discussion Rubber Powered Flying Wing cherobee 3D Foamies 1 Sep 15, 2012 09:49 PM
