Old Dec 13, 2012, 10:10 AM
dmr is offline
dmr
Find More Posts by dmr
dmr
Joined Dec 2012
Help!
Wasp V3 6ch CCPM RTF RC Helicopter
Hi,
I have just purchased a Wasp V3 6ch RC helicopter...
I am trying to use the simulator to get used to the controls first, however I am having a few problems.
I have used the application to setup the transmitter, connected to my laptop. I have opened the default settings for my heli and wrote the settings to it successfully.
I opened the simulator (FMS), chose the model, and controls. I am using the "joystick interface" and calibrated it. All I can do is spin the helicopter around and cannot get off the ground.
The gear is down, the flight mode is on "N", the four sliding things (not sure what they do yet) are all centered, and so is the two levers.
Sorry, I am clueless...
Can anyone help?
Cheers.
dmr is offline Find More Posts by dmr
Old Dec 13, 2012, 10:57 AM
dmr is offline
dmr
dmr
Joined Dec 2012
Okay..
For some reason, it works on everything, but the helicopters.
What am I doing wrong.
Cheers
Old Feb 24, 2013, 03:36 PM
holtneil is offline
Find More Posts by holtneil
Heli nut " the wife said so "
holtneil's Avatar
United Kingdom
Joined Dec 2012
hi mate the 4 slides things are trims the one on the left that moves up and down should be all the way down the other 3 in the mid position, go into setting and calibrate the transmitter , then when you start to fly you can use the trims to set up the heli..... when you put the software into the transmitter did you select hc ccpm- this is the setting for the wasp v3 and this is what it need to be on for that heli, my pc is not working very well at moment so i cant run the simulator so let me know how you get on mate
holtneil is offline Find More Posts by holtneil
Old Feb 24, 2013, 09:44 PM
resago is offline
Find More Posts by resago
Joined Dec 2012
Wasp is pretty easy to fly. Get some training gear if this is your first model.
Then get out side and learn. Follow the training videos.
resago is offline Find More Posts by resago
Help! CNC Upgrade for Wasp V3 CCPM 6ch Heli markf007 Skyartec 7 Mar 10, 2011 03:57 PM
Rave Thoughts of Wasp V3 6ch CCPM after a week celm Skyartec 1 Sep 02, 2010 01:03 AM
For Sale Wasp V3 6ch CCPM with Extras $120 g3nius Aircraft - Electric - Helis (FS/W) 0 Jul 26, 2009 04:44 PM
Sold Skyartec WASP V3 6CH PRO "kinda" RTF with spares 120deg CCPM w/ BROKEN TX HighNear90 Aircraft - Electric - Helis (FS/W) 23 Apr 28, 2008 03:11 PM
