Old Mar 03, 2013, 07:37 PM
Bajora is online now
Find More Posts by Bajora
KA6KHM
Bajora's Avatar
Joined Sep 2004
First flights off water this morning. I was a little surprised at how windy it was early. The water had a decided light chop but I had been waiting all week to fly off water ... soooo ... in she went!
The Polaris Ultra was quite quick to get on step but the wingtips kept catching the little waves and making BIG splashes. Twice the wing/waves spun the aircraft enough that I chopped the throttle but she tracked straight on the third run and was airborne. Lotsa fun banking her around so my daughter could shoot some photos and the landing was so easy. Unfortunately, I lost the white, plastic belly guard. Grrrrr! I think it must have gotten jarred loose on the takeoff(s)? I had attached it with quite a few strips of double-sided tape and it had been fine off grass. Hey Scott, any chance you could get Tim to include some spares with the next container? I think it might be a worthwhile spare part to have available. I know I am interested in buying one or two now.
Bajora is online now Find More Posts by Bajora
Old Mar 03, 2013, 08:30 PM
jt182 is offline
Find More Posts by jt182
United States, MA, Oxford
Joined Sep 2009
I subscribed to this thread a month ago when I stumbled across it. It's only a matter of time before I pull the trigger, and get this plane. Have to sell the wife on this one first. built a couple this winter and she bought me a Bucker Jungman for x-mas.
Honey doesn't this plane look great, and it flies off the water, and land, plus it uses the same size batteries that I all ready have.
By the way great pictures!
jt182 is offline Find More Posts by jt182
Old Mar 04, 2013, 05:30 PM
Daedalus66 is offline
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
I used double sided tape and for security put a strip of clear packaging tape across the front. I haven't tried it off water (the liquid variety), just snow, but I expect it will prevent the plastic pulling loose.
Daedalus66 is offline Find More Posts by Daedalus66
Old Mar 04, 2013, 06:27 PM
KA6KHM
Bajora's Avatar
Joined Sep 2004
In hindsight, that sounds like a very good idea. A piece of tape across the front should seal the edge down and prevent water from getting in there and levering it off.
Old Mar 04, 2013, 07:24 PM
crazyj is offline
Find More Posts by crazyj
MultiCopterPilot & Film Maker
crazyj's Avatar
United States, WA, Kent
Joined Nov 2002
Why not glue the bottom plastic piece on? Is there a reason to use tape that I'm not seeing?
crazyj is offline Find More Posts by crazyj
Old Mar 04, 2013, 07:51 PM
Model Aero is online now
Find More Posts by Model Aero
Northwest Ohio
Joined Jan 2002
No reason not to glue it. I just used Scotch Permanent double sided tape on my prototype and it held well on land but appears marginal on water, even though I have a few flights off water with it.
Epoxy or spray adhesive are other options but you need to figure out a way to hold it down during the cure process because tape will remove the paint finish.
Scott
Model Aero is online now Find More Posts by Model Aero
Old Mar 04, 2013, 07:54 PM
Northwest Ohio
Joined Jan 2002
Bajora, I will request some extra plastic belly plates on the next reorder. I am sure Tim at RC Lander can supply them.
Scott
Old Mar 04, 2013, 08:21 PM
bluebird is offline
Find More Posts by bluebird
bluebird's Avatar
charlotte, nc
Joined Sep 2003
Ultra Polaris at SEFF
I'm taking my Ultra to SEFFand I bet Gatorb8 is too. Wouldn't a video of a formation landing be cool?
Joe
bluebird is offline Find More Posts by bluebird
Old Mar 04, 2013, 08:32 PM
KA6KHM
Bajora's Avatar
Joined Sep 2004
Scott
Much thanks Scott. I will place an order whenever you get that second container in. Another item that ran through my mind, and you may not agree with me, but is there any merit in a plastic nose cone to offer a little extra protection and reinforcement to, say, the first couple inches of the nose? If it was made of the same material as the motor nacelle cowl, that would be swell. Another option would be the same material as my sunken belly pan but perhaps that thickness would of material be too much?! Anyhow, just a thought.
Old Mar 05, 2013, 07:59 AM
kingsflyer is offline
Find More Posts by kingsflyer
We shall serve the Lord
kingsflyer's Avatar
United States, TX, Kingsland
Joined Sep 2005
Joe
Pecan Patch and I will have our Polari at SEFF also. Let's set a time and day for our "Squadron" flight. Maybe we can get Bildo to video it for us.
On the topic of a Polaris Ultra Wish List --
Would it be possible to get the motor cowl molded out of a heavier gauge plastic?
Mine disentegrated after a high speed dive . Maybe you could include a few spares in your next order?
Belly Pan Attachment --
I used Scotch Super 77 spray adhesive to attach mine. I masked the outside edges of the pan to prevent any overspray on the outside of the pan. I then sprayed the inside of the pan, let it dry for a minute, then carefully attached it to the hull starting at the step and working my way forward. I've had my Ultra in the water a number of times and the pan is still securely attached.
http://3m.hillas.com/c-992-3m-super-...FY6PPAodIVsAag
McD
kingsflyer is offline Find More Posts by kingsflyer
Old Mar 05, 2013, 12:33 PM
Mike_Then is offline
Find More Posts by Mike_Then
I hate waiting for parts
Mike_Then's Avatar
United States, NC, Garner
Joined Apr 2001
I couldn't stand it anymore.... between Scott's most excellent support by listening to his customers and being VERY active in this thread and Jon's beautiful HD pictures, I just ordered me a Polaris. Can't wait 'till it gets here!!
Now I have to dig back through the thread and see what props people were running on the 3s pack, as I forgot to check to make sure I had one before I ordered. Okay, I see it's an APCe 8x6 or a MA 8x6x3. I'll look in the shop at lunch. Scott, if I don't have a prop would it be possible to throw one in the box before it ships? Paying for it of course. I'll report back in an hour or so.
Mike_Then is offline Find More Posts by Mike_Then
Old Mar 05, 2013, 12:53 PM
Northwest Ohio
Joined Jan 2002
Temptation finally won!!!
I can throw a 3 blader in the box. I'll wait to hear from you.
Scott
Old Mar 05, 2013, 01:57 PM
Mike_Then's Avatar
Joined Apr 2001
Scott
Yes it did! I couldn't stand it any longer!
I checked my box 'o props at lunch and I do have an APCe 8x6. But no 3-blade... the only one was a 10x7x3 which would be a wee bit too big. Would you mind sticking a MA 8x6x3 in the box, please? Can you just charge my card for the prop or do I need to do a separate transaction? Thanks!
Old Mar 05, 2013, 05:31 PM
Northwest Ohio
Joined Jan 2002
Check your PM box.
Scott
Old Mar 05, 2013, 05:37 PM
Mike_Then's Avatar
Joined Apr 2001
Check your PM box.
Scott
Done! Reply sent, and thanks!
Sold Complete Power set up for a Aero Models Aqua Cat or Polaris RTflyboy Aircraft - Electric - Power Systems (FS/W) 1 Dec 08, 2012 06:52 PM
For Sale cassini aero models usa p 51d mustang 120 arf asteroidguy Aircraft - Fuel - Airplanes (FS/W) 2 Mar 17, 2012 06:21 PM
Discussion Model Aero Polaris Seaplane Auction Model Aero Hot Online Deals 1 Mar 11, 2012 12:28 PM
For Sale cassini aero models usa p 51 mustang 120 arf asteroidguy Aircraft - Fuel - Airplanes (FS/W) 0 Feb 22, 2012 01:14 PM
