Old Jan 22, 2013, 12:49 AM
jetset44 is online now
Find More Posts by jetset44
Park Jet Guru
jetset44's Avatar
Seattle, WA
Joined Jun 2002
Great video, gatorb8! Funny to hear the reactions of the onlookers, especially.
jetset44 is online now Find More Posts by jetset44
Old Jan 22, 2013, 08:52 AM
gatorb8 is online now
Find More Posts by gatorb8
Registered Offender
gatorb8's Avatar
United States, FL, Gulf Breeze
Joined Apr 2008
Originally Posted by Caddguy6 View Post
Well just finished up assembly of the Ultra, an enjoyable build. After fighting with my big fingers I opted to mount the Elev. servo on the outside of the pod, makes for easier adjustment in the field. Added a black anti-glare panel and nose tip in front of the canopy.
Of course it's snowing here and the rest of the week will be in the low to mid 20's with high winds. So she'll be safe and warm for quite a bit longer.
Look like it'll be spring for the maiden.
love the black nose job!
gatorb8 is online now Find More Posts by gatorb8
Old Jan 22, 2013, 09:26 AM
Registered Offender
gatorb8's Avatar
Joined Apr 2008
some battery velcro ideas:
the 4S lipo has to be moved back quite a bit and is hanging a bit into the belly.
I ran the velcro along the starboard vertical wall of the battery channel.
Once the lipo is inserted and slid into place, I slide a piece of balsa into the port side of the channel to lock the velcro, I made the balsa lock low enough to run the wires so they don't interfear with the cockpit. To remove, remove the balsa lock and slide a paint scraper to unhook velcro, pull out
Old Jan 22, 2013, 11:33 AM
Model Aero is offline
Find More Posts by Model Aero
Northwest Ohio
Joined Jan 2002
+1 on the black nose. It looks great!
Scott
Model Aero is offline Find More Posts by Model Aero
Old Jan 22, 2013, 11:50 AM
Caddguy6 is offline
Find More Posts by Caddguy6
Caddguy6's Avatar
Philadelphia, PA
Joined Jan 2002
Thanks for the likes on the black nose. It's kinda in keeping with my original artwork for the NorthStar I had planned on building many many years ago. I'm really glad allot of people liked the Coast Guard color scheme and for you Scott to go with it for the Ultra.
Caddguy6 is offline Find More Posts by Caddguy6
Old Jan 22, 2013, 02:07 PM
_OZ_ is offline
Find More Posts by _OZ_
It's gone...
_OZ_'s Avatar
Germany, NRW, Heinsberg
Joined Aug 2004
Is that canopy large enough to fit a GoPro under?
_OZ_ is offline Find More Posts by _OZ_
Old Jan 22, 2013, 03:54 PM
Northwest Ohio
Joined Jan 2002
A GoPro Hero2 is 1.6" x 2.4" x 1.2". It would be very close to fitting under the canopy without modification. If anything you could remove the pilot's headrest and position the camera further back where there's more room.
Scott
Old Jan 22, 2013, 04:11 PM
_OZ_ is offline
It's gone...
_OZ_'s Avatar
Joined Aug 2004
That might be better. CG wise too.
Old Jan 22, 2013, 06:41 PM
Registered Offender
gatorb8's Avatar
Joined Apr 2008
Just another day in Paradise!
Polaris Ultra on Shoreline (11 min 55 sec)
Old Jan 22, 2013, 10:17 PM
Park Jet Guru
jetset44's Avatar
Seattle, WA
Joined Jun 2002
I am so envious, gatorb8--that place is like the OPPOSITE of Seattle right now. Great flying, and beautiful flying spot! Thanks for sharing the video.
Steve
Old Jan 22, 2013, 10:47 PM
Daedalus66 is offline
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Very nice!
So you flew over 10 minutes. What battery and how much did it take at recharge?
Daedalus66 is offline Find More Posts by Daedalus66
Old Jan 23, 2013, 02:11 AM
Registered Offender
gatorb8's Avatar
Joined Apr 2008
Originally Posted by Daedalus66 View Post
Very nice!
motor is microdan 2510-1300 with MAS 8x6 3 blade prop
I was a bit surprised by the numbers
That flight was a 2200 mah 4S
timer set for 8 min, timer on at throttle above 8%
recharge put 1600 mah back in
so the approximate 12 min video must have had throttle below 8% for 4 minutes
so looks like I could set the timer for 11.1 minutes minus a few minutes for a guardband
on a later flight using 2200 3S
timer set for 6 min with same conditions
recharge put 950 mah back in
so for 2200 3S I could set the timer for 13.9 minutes minus a few minutes for guardband
edit: after looking at a 3S video, I ended flight before timer went off so throw the 3S data out
I'm having motor cutoff problems when using 1800 mah 4S and not sure why
when I monitor lipo voltage it seems above 14v but motor screeches and halts, good thing is it starts up immediately, will investigate further
edit: after recharge and datalog of 1800 4S determined they have all gone bad, they were a few years old
Old Jan 23, 2013, 06:13 AM
Lockey is offline
Find More Posts by Lockey
Tony Audsley Retired Locksmith
Lockey's Avatar
Australia, WA, Perth
Joined Sep 2011
Nice video gatorb8, thanks for sharing
Lockey
Lockey is offline Find More Posts by Lockey
Old Jan 23, 2013, 01:05 PM
Registered Offender
gatorb8's Avatar
Joined Apr 2008
Flew 4 packs of 2200 mah 3S off water today.
Flight timer at 7minutes >8% Throttle
4 packs took back 4153mah so average 1038 mah
7/1038=x/2200 x=14.8 minutes
Think I will bump the 2200 mah 3S timer to 10 minutes
below are some pics of Scott's suggested papertowel stuffings
I created a barrier around the servos to keep from pooling water in the servo hole
The way I fly, they will be needed sooner or later!
uploading some more video now....
Old Jan 23, 2013, 02:13 PM
Registered Offender
gatorb8's Avatar
Joined Apr 2008
I found a shoreline facing north so the sun was behind me!
Wind was under 10 mph from east.
So much shoreline, so little time!
Polaris Ultra Sabine Bay (7 min 38 sec)
Sold Complete Power set up for a Aero Models Aqua Cat or Polaris RTflyboy Aircraft - Electric - Power Systems (FS/W) 1 Dec 08, 2012 05:52 PM
For Sale cassini aero models usa p 51d mustang 120 arf asteroidguy Aircraft - Fuel - Airplanes (FS/W) 2 Mar 17, 2012 05:21 PM
Discussion Model Aero Polaris Seaplane Auction Model Aero Hot Online Deals 1 Mar 11, 2012 11:28 AM
For Sale cassini aero models usa p 51 mustang 120 arf asteroidguy Aircraft - Fuel - Airplanes (FS/W) 0 Feb 22, 2012 12:14 PM
