Old Jan 09, 2013, 11:26 PM
gatorb8 is online now
Find More Posts by gatorb8
Registered Offender
gatorb8's Avatar
United States, FL, Gulf Breeze
Joined Apr 2008
Originally Posted by Zoomer-Ron View Post
gatorb8
What kind of connection is that from the CF to SS?
I use an adhesive shrink tube from West Marine made by Ancor
When you heat it up the tube shrinks, adhesive melts and oozes out, let it dry and it's a good connection for pushrods on planes up to about this size
I roughed up the SS & CF to
I also used some McLube sailkote dry lubricant on the CF so it has little slide resistance
gatorb8 is online now Find More Posts by gatorb8
Old Jan 10, 2013, 07:47 AM
kingsflyer is online now
Find More Posts by kingsflyer
We shall serve the Lord
kingsflyer's Avatar
United States, TX, Kingsland
Joined Sep 2005
I use Vaseline on all my pushrods where they enter the pushrod tubes. This helps seal the opening and adds a little lube to the interface. I also put some Vaseline under the servo horn to seal the servo output shaft opening even on those servos inside the hull. I use CorrosionX on all my electronics because it's not a question of "IF" water will get into them, rather it's a question of "when". Remember, Murphy loves to hang around seaplanes.
McD
kingsflyer is online now Find More Posts by kingsflyer
Latest blog entry: LEDs on my T-28
Old Jan 10, 2013, 08:34 AM
Registered Offender
gatorb8's Avatar
Joined Apr 2008
McD
yep CorrosionX will be going on everything today
I had some more water proofing ideas that came to me last night that I'll be trying! You are right, it's only a matter of time!
Old Jan 10, 2013, 09:52 AM
Zoomer-Ron is offline
Find More Posts by Zoomer-Ron
Zoomer-Ron's Avatar
United States, FL, The Villages
Joined Jul 2002
Understand. Have used Anchor splices on boat wiring. For these light airloads it should be adequate. Say, I don't have a Polaris yet, but I have a Dynam PBY. Yesterday at the lake, everyone else had a Polaris, so I'll probably be ordering one (XL).
Zoomer-Ron is offline Find More Posts by Zoomer-Ron
Old Jan 10, 2013, 10:18 AM
Registered Offender
gatorb8's Avatar
Joined Apr 2008
should be, I've used this method an at least 20 planes, no failures yet...............
Old Jan 10, 2013, 10:31 AM
Daedalus66 is online now
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
McD
Good ideas. As for the servos, sealing where the cable comes out is very important. The only problem I've ever had with water in a servo resulted from pooling around the servo cable exit. The water seeped in over a couple of weeks and next time I flew the rudder went hard over and caused a crash. I now do two things: seal the cable with Goop or similar, and make sure the water can't collect around the servo bottom (the problem was that I had sealed down the rear fuselage top, making a pocket for water just where the servo bottom poked through the wing).
Note that the problem was not the electronics as such but the feedback pot, which I had to take apart and clean. I don't think you can treat the pot with CorrosionX, so you just have to keep the servo properly sealed.
Murphy is ubiquitous.
Daedalus66 is online now Find More Posts by Daedalus66
Old Jan 10, 2013, 10:37 AM
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
nice to hear high alpha is better than expected!
What was your AUW with Lipo during that flight?
mine is coming along....
got some SS/CF pushrods made, servos installed, I went with the external elevator servo
You aileron servo arm looks about like mine, but I found after the first flight that I needed a longer arm on the rudder servo to get enough throw. It was originally 12mm from shaft to connector and I would now use about 15mm.
Mine weighs 36oz ready to fly with 3s 2200 30C battery, about 38oz with 4s.
Old Jan 10, 2013, 10:38 AM
Registered Offender
gatorb8's Avatar
Joined Apr 2008
I also like Scott's idea of stuffing some paper towels or tissue around to capture the few stray droplets....
Old Jan 10, 2013, 10:56 AM
Registered Offender
gatorb8's Avatar
Joined Apr 2008
How did you guys check the CG?
Can I just put it on a flat table and adjust the components untill it will tip either way on the step?
Thanks!
Old Jan 10, 2013, 10:58 AM
Registered Offender
gatorb8's Avatar
Joined Apr 2008
Scott,
Do you have the airbrush shade of red and manufacturer? I touched a piece of tape to the fuse and it took a lot of paint off
Old Jan 10, 2013, 11:49 AM
Registered Offender
gatorb8's Avatar
Joined Apr 2008
passed the float test!
I was glad to see good margin from water to aileron pushrod exits!
I also put an air exaust in the cowl
AUW came in at 38 oz with 2200 mah 4S
Old Jan 10, 2013, 01:08 PM
beemerdon is offline
Find More Posts by beemerdon
beemerdon
beemerdon's Avatar
USA, NC, Charlotte
Joined Nov 2009
Looking great, Gator. I landed my kit Polaris in the top of a tree yesterday; no water infiltration problems at all! I think the Outlawas are gonna be spending a lot of time down at the pond during SEFF.
Don
beemerdon is offline Find More Posts by beemerdon
Old Jan 10, 2013, 01:26 PM
Registered Offender
gatorb8's Avatar
Joined Apr 2008
Don
Don't feel bad Don, I've landed my other boat in the trees before.........
Old Jan 10, 2013, 03:01 PM
Model Aero is offline
Find More Posts by Model Aero
Northwest Ohio
Joined Jan 2002
Scott,
All the paint is applied at the factory in China. But I'll be visiting the craft section at Walmart later and I'll see if I can come up with a color match.
Meanwhile, your plane is looking great! Can't wait to hear a flight report with the Micro Dan motor!
Scott
Model Aero is offline Find More Posts by Model Aero
Old Jan 10, 2013, 03:52 PM
Petefoss is online now
Find More Posts by Petefoss
Petefoss's Avatar
Oxford, Michigan, United States
Joined Aug 1999
I've had good luck with scanning and color matching at Home Depot.
Petefoss is online now Find More Posts by Petefoss
Sold Complete Power set up for a Aero Models Aqua Cat or Polaris RTflyboy Aircraft - Electric - Power Systems (FS/W) 1 Dec 08, 2012 06:52 PM
For Sale cassini aero models usa p 51d mustang 120 arf asteroidguy Aircraft - Fuel - Airplanes (FS/W) 2 Mar 17, 2012 06:21 PM
Discussion Model Aero Polaris Seaplane Auction Model Aero Hot Online Deals 1 Mar 11, 2012 12:28 PM
For Sale cassini aero models usa p 51 mustang 120 arf asteroidguy Aircraft - Fuel - Airplanes (FS/W) 0 Feb 22, 2012 01:14 PM
