Northwest Ohio
Joined Jan 2002
Model Aero Polaris Ultra ARF
Model Aero is very excited to offer our newest product, the Polaris Ultra. Based on Laddie Mikulasko’s legendary North Star design, this is an ARF version of the popular Polaris seaplane scaled to 115% of Steve Shumate’s original design. It’s molded of high quality EPO foam and due to the high level of pre-fabrication can be built in a fraction of the time of the original Polaris kit. As with all Polaris models, it can fly off water, grass, or snow!
The Polaris Ultra retains all of the flying qualities of the original Polaris, yet has a character all her own. I hope you enjoy flying her as much as we’ve enjoyed the development process. Thanks, Scott DeTray Model Aero Polaris Ultra |
Northwest Ohio
Joined Jan 2002
Specifications:
Wingspan: 34” Length: 46” AUW: 36-38 oz. Wing area: 471 sq in Wing loading: 11.6 oz/sq ft Power Requirements: Motor: 2810-9 or equivalent KV: 1350 ESC: 40 to 50 amp, switch mode BEC recommended Prop: APC 8 x 6 or Master Airscrew 8 x 6 three blade on 3S, APC 8 x 4 on 4S Battery: 3S or 4S 2200 to 2500 Power output: 280 to 450 watts Servos: 9 to 13 gram servo with torque rating of 16 to 25 oz/in Features of the Polaris Ultra: -Molded EPO foam-Pre painted -Decal set -Full airfoil on wing, stab -Motor and elevator servo wires built in -Magnetic canopy hatch for battery access -Vacuum formed plastic skid plate for the bottom -Inner plywood structure for strength -Two round CF wing spars -Pilot figure included -Complete hardware package
Northwest Ohio
Joined Jan 2002
If balanced correctly, there's no noticeable tendency to drop the nose in turns, a trait that some complained about with the flat foam Polaris. Scott www.ModelAero.com |
I'm a bit puzzled by posts that seem to suggest that up elevator should not be needed in turns. All models (and full size aircraft) that are trimmed to fly level need some up elevator in turns, as when the plane is banked more lift is needed to produce the turn while maintaining level flight. Shallow turns only need a small amount of up, steeper turns need more. This is standard piloting technique that we teach in flight school. By the way, models that don't need up in turns climb when flying straight (which is not desirable).
The real issue then is whether too much up is needed to prevent height loss in turns. A Polaris (or other model) with the center of gravity too far forward will need quite a lot of up in turns and may get the pilot into trouble (I've seen it happen). The same model will be much more comfortable to fly with the CG in the right place. But the idea that NO up should be needed is unrealistic. PS My Ultra is on the way. Can't wait! |
Latest blog entry: Polaris Aileron Pushrods
| Thread Tools | |
| Sold Complete Power set up for a Aero Models Aqua Cat or Polaris | RTflyboy | Aircraft - Electric - Power Systems (FS/W) | 1 | Dec 08, 2012 05:52 PM |
| For Sale cassini aero models usa p 51d mustang 120 arf | asteroidguy | Aircraft - Fuel - Airplanes (FS/W) | 2 | Mar 17, 2012 05:21 PM |
| Discussion Model Aero Polaris Seaplane Auction | Model Aero | Hot Online Deals | 1 | Mar 11, 2012 11:28 AM |
| For Sale cassini aero models usa p 51 mustang 120 arf | asteroidguy | Aircraft - Fuel - Airplanes (FS/W) | 0 | Feb 22, 2012 12:14 PM |
