Old Dec 13, 2012, 07:40 AM
United States, NY, Kingston
Joined Feb 2006
Doing as I command
Working on servo designs for dropping into my wing. As you may or may not know I have opted to go to two servos from a central servo to operate ailerons. My questions. If I mount the servo's facing each other, meaning top facing to top, will they work correctly without having to do servo switching? It seems to make sens to me that as they both will rotate clockwise one will push up on the servo and one will push down on the servo. Sound correct??
Bariboy is offline Find More Posts by Bariboy
Old Dec 13, 2012, 08:06 AM
Hamburger Eatin' Fool
TomCrump's Avatar
Traverse City, Michigan
Joined Dec 2005
Every time that I do this, I have to stop and figure it out. LOL
I believe that you are correct in your assumption.
Being a little slow, I lay out the servos and play with them, hooked up to an RX. By doing this, I can confirm that my head was on straight, when I planned the servo layout.
TomCrump is offline Find More Posts by TomCrump
Old Dec 13, 2012, 08:21 AM
AKA "Fingers"
kenh3497's Avatar
United States, IA, Rockwell
Joined Jul 2011
If the servos are laying on their sides, make sure the out put shafts are either point away from each other or towards each other. DO NOT have have them both facing right or left. If they are "standing up" with the servo exposed outside the wing, the push rods should have the same orientation as the first description.
Back in "the old days" we used to get one servo in the radio gear that was a "reverse rotation" servo. It came in handy on occasion. You could make your own by switching the wires on the motor in the servo. Of course way back then we never used a servo on each aileron.
Ken
kenh3497 is offline Find More Posts by kenh3497
Old Dec 13, 2012, 09:30 AM
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
A picture is worth........, having a look at
eflightray is offline Find More Posts by eflightray
Old Dec 13, 2012, 10:24 AM
Joined Jan 2009
It usually works out exactly right if you implement perfect symmetry -- just as you guessed. Both servos will rotate in the same direction with the same command. But on one servo, that will move the arm forward, and on its twin, it will move the arm backward.
rafe_b is offline Find More Posts by rafe_b
Old Dec 13, 2012, 10:44 AM
Joined Nov 2004
http://www.headsuprc.com/servlet/the...everser/Detail
mnowell129 is offline Find More Posts by mnowell129
Old Dec 13, 2012, 11:28 AM
Joined Feb 2006
Too funny, I work on people all day long and spend all day working "opposite" right is their left etc. I have both servo tops facing each other - facing into the wing root. Should be good to go Thanks guys.
Old Dec 13, 2012, 04:30 PM
Staffs, UK
Joined Nov 2003
Of course we are assuming that you have two identical servos....not all servos move the same way so if you ever use two different makes on aileron it might really confuse you .
Steve
slipstick is offline Find More Posts by slipstick
Old Dec 13, 2012, 05:57 PM
Joined Feb 2006
yes, two right handed henway servo's
Old Dec 15, 2012, 05:25 PM
Endlesslag's Avatar
USA, VA, Spotsylvania
Joined Jan 2011
hmmmm...tempted to ask the question
Endlesslag is online now Find More Posts by Endlesslag
Old Dec 15, 2012, 06:01 PM
Joined Feb 2006
give in to the temptation......
Old Dec 15, 2012, 06:16 PM
Endlesslag's Avatar
Joined Jan 2011
Fine...
What's a henway
Old Dec 15, 2012, 06:19 PM
TomCrump's Avatar
Joined Dec 2005
Originally Posted by Endlesslag View Post
Fine...
What's a henway
Two or three pounds.
Old Dec 15, 2012, 07:02 PM
AKA "Fingers"
kenh3497's Avatar
Joined Jul 2011
Fine...
What's a henway
Unless it's a Kapon then 5 or 6 pounds
Ken
Old Dec 15, 2012, 07:44 PM
Joined Feb 2006
"These are not the droids you are looking for....." What powers I have
Discussion Why Obama is even doing as well as he is .... Boogie_ Life, The Universe, and Politics 37 Oct 30, 2012 01:05 PM
Discussion High voltage servos, such as Hitec's do they work with 4.8V-6V voltage? liukku Radios 9 Mar 26, 2012 12:35 PM
Discussion Do as I say ... not as I do ... logan5 Life, The Universe, and Politics 15 Oct 17, 2011 10:45 AM
AMA Rules vs. AMA Practice: Do as we say, not as we do surfimp Electric Plane Talk 30 Dec 16, 2003 12:58 AM
