Old Mar 03, 2013, 05:28 PM
Vantasstic is offline
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Just for comparison...I did a short, way to windy to fly, flight today with my data logger connected. On 4S, 750kv motors, 10x6x3 props,and an AUW ~1500g-1600g, I pulled an average 14.9A...that's <4A per motor...with a max of 32A...or ~8A per motor. Because of the wind gust my motors were adjusting a lot trying to keep the frame flying as level as possible. On calmer conditions I see a pretty steady 14.5A +/- average draw from the entire power system.
Check out my earlier post on the 9" vs 10" 3-blade comparison: http://www.rcgroups.com/forums/showp...&postcount=202
Vantasstic is offline Find More Posts by Vantasstic
Old Mar 04, 2013, 12:46 AM
Cralis is offline
Find More Posts by Cralis
I love FPV!
Cralis's Avatar
Eastern side of Australia
Joined Jan 2007
Thanks Van!
Cralis is offline Find More Posts by Cralis
Old Mar 04, 2013, 01:36 AM
Cralis is offline
I love FPV!
Cralis's Avatar
Joined Jan 2007
A short flight home... and some grass...
Quick flight Home (1 min 45 sec)
Old Mar 04, 2013, 12:07 PM
DoctorAudio is offline
Find More Posts by DoctorAudio
Some call me the other guy!
DoctorAudio's Avatar
Milwaukie , Oregon
Joined Feb 2003
Okay guys, I am done for a day or two.
I have to mount the quadrino GPS later I am going flying today.
Need to do some large area flight test.
I mounted the 5.8 GHZ VTX and 700 line camera, That can see in the dark about 40 meters out.
I kept messing around with the extra frame pieces, It finally looks like what I was picturing it.
My setup runs a little warm, but never hot!
It has lots of power and is very close to be glass smooth!
Quadrino with the new baro cover on it. (( I LIKE IT.))
DoctorAudio is offline Find More Posts by DoctorAudio
Old Mar 04, 2013, 12:19 PM
kicekilla is offline
Find More Posts by kicekilla
No you cant fly it.
kicekilla's Avatar
United States, FL, Milton
Joined Mar 2011
what is your takeoff weight? looks heavy with all of those standoffs? do you even need the top most plate?
kicekilla is offline Find More Posts by kicekilla
Old Mar 04, 2013, 12:57 PM
markcaso is offline
Find More Posts by markcaso
Angry Bird
markcaso's Avatar
United States, FL, Lakeland
Joined Jan 2013
Hoverthings FC
Does anyone use the ReadytoFlyer 2.5 FC from hoverthings.com?
GOOD or BAD?
markcaso is offline Find More Posts by markcaso
Old Mar 04, 2013, 01:24 PM
Milwaukie , Oregon
Joined Feb 2003
1225 grams AUW.
Which may be 500 grams more than the normal.
I am waiting on some light weight standoffs to show up here in the mail box.
That will take off about 6 oz.
But this is the way I want it.
This is why!
All my buddies tha have this frame, has complained about it being brittle.
Each of them has crashed it and have never broken the arm.
But, have snapped the frames.
Last night, I was hovering at about 30 feet up.
One of the motor wires broke at the bullet and them tumbled to the ground and bounced.
It bounced highenough to endup on it's feet.
I was like damm, it is broke now!
Well, when I found it in the field it only had one broken prop!
I am running a 4S setup and most 4S anything weighs in aorund the same weight.
When I buy a frame , I always buy repair parts for it.
I bought go extra, top and bottom plates and extra arms.
My thought it to take this frame and cut out a thicker one for the top and bottom plates.
Go from 1.6mm to 2.1mm and 3.1mm.
I have also ordered a RC car bus body to be mounted on it.
Wait don't steal my idea!
I bet you may see one or two bodies come out from multicopters in the future.
Bus body and a Datsun 510 wagon body would be the only two I want.
Hehehe!
Old Mar 04, 2013, 09:33 PM
vix is offline
vix
Find More Posts by vix
vix
Joined Apr 2012
I finally completed my Flip Fpv build and had my first fpv flight ever with it today, and I am hooked!
This is my first quad build, but thanks to this thread everything went smoothly (Special thanks to Vantasstic!).
The frame feels really solid, and I was lucky to receive the upgraded landing gear even though they were first announced after i received the package . I routed the motor wires so i can fold the arms in for easy transport, without bending the wires too much.
I bought a v929 beetle micro quad for some quad practice before I had the maiden flight with the Flip. I find the Flip to be quite easy to fly LOS in MultiWii level mode, even in strong wind. Fpv maiden in wind was an adrenaline rush though, but I just could not wait to try it :P Will wait for calm weather before I try GPS hold and RTH.
My build:
Flip Fpv Camo
AIOP V2.0 ALL IN ONE PRO Flight Controller
u-Blox CN-06 GPS Receiver V2.0
HP2212-1000KV from RcTimer (these are amazing!)
20A SimonK ESC
GemFan 9" props (These give very little vibrations compared to the RcTimer carbon props).
Fat Shark 250mw 5.8Ghz vtx
GoPro Hero 2
Weight with Turnigy nano-tech 4000mah 3S 40~80C, GoPro and some leds is 1392g.
Future upgrades are:
Immerson 600mW vtx (or maybe I should go for a 1.3ghz setup?)
FrSky 2.4ghz tx/rx combo for my T9x
Simple OSD system
New fpv camera
Patch antenna
I will mostly fly at places with a few trees to block the vtx signal, and I find the video feed to break up some with the stock fat shark 250mw vtx.
The range is decent though with the SpiroNet CP antennas. Do you think i should go for the Immerson 600mw vtx and my integrated Fat Shark Predator 2 vrx, or rather switch to 1.3ghz?
vix is offline Find More Posts by vix
Old Mar 04, 2013, 09:54 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Congrats on the build. I like how you did your 'folding' arms. I was trying to fold them both inwards...it works much better how did it. Good going and enjoy.
As for video, the 1.3Ghz will give you more penetration with less power than 5.8G. The antennas for 1.3Ghz are bigger though. If your 5.8G system is working fine for you then why start up a whole different freq system and have more equipment to haul around. My experience with the Fatshark 100mW 5.8G system left me pretty sour on it. I actually ended up buying a 600mW 5.8G VTx, but sold the whole FS system before I tried the more powerful VTx. I just wasn't FS satisfied...person preference. Since my FPV system is 1.3G based I decided to stick with 1.3G. I do keep thinking of trying 5.8G again for a small FPV hex, but...probably will stick with 1.3G for standardization.
Old Mar 05, 2013, 10:43 AM
cactus is offline
Find More Posts by cactus
cactus's Avatar
United States, CO, Durango
Joined Sep 2001
Not what I wanted to hear as I just dropped $39 bucks to get 6 of the 10x5 carbons from RC timer to try on mine.
Can you provide some closeups of how you mounted your FPV camera? Did you hard mount it to the bottom plate, or did you isolate it from vibration?
cactus is offline Find More Posts by cactus
Old Mar 05, 2013, 10:46 AM
cactus is offline
cactus's Avatar
Joined Sep 2001
Speaking of props and camera mounting and vibrations.......
I'm going to use my old Android phone with a vibration application on it to test the following props on 4S with my 775 kv Carbon Bird motors and see which ones work the best:
- GWS 9x5x3
- GWS 10x5x3
- RC Timer Carbon 10x5
Old Mar 05, 2013, 05:44 PM
vix is offline
vix
vix
Joined Apr 2012
The current mount looks quite ugly, but is only temporary to find a placement I'm happy with. The camera is mounted on a 90 degree plastic angle on top of an eraser I cut at a slight angle to tilt it a bit downwards. I tried to order some MoonGel vibration dampening pads from Amazon, but the shipping to Norway was ridiculous so i went for these two from hobbyking instead:
For the GoPro: http://hobbyking.com/hobbyking/store...dProduct=26457
For the fpv camera:http://hobbyking.com/hobbyking/store...dProduct=15214
They are super cheap and i get no vibrations or jello effect with them using Gemfan props. The RcTimer carbon props on the other hand gave very bad vibrations, made the picture blurry and the Flight Controller went crazy in level mode, even though I took extra care to balance them perfectly. Maybe they were not tracking true...
Old Mar 08, 2013, 12:15 AM
k2spy04 is offline
Find More Posts by k2spy04
k2spy04's Avatar
United States, CO
Joined Jan 2013
Question about 4S..... I am thinking I might need to step up from 3S to 4S. Other than purchasing the new battery do I need to rewire anything? I am running my FPV equipment off of a separate 3S battery.
k2spy04 is offline Find More Posts by k2spy04
Old Mar 08, 2013, 03:16 AM
Milwaukie , Oregon
Joined Feb 2003
Most motors will run higher voltage.
Some of the lower priced ESC's will crap out early if run on higher voltage.
So heck those two factor and then buy many good batts.
Old Mar 08, 2013, 06:45 AM
k2spy04 is offline
k2spy04's Avatar
United States, CO
Joined Jan 2013
Im using NTM 1200kv motors and 30A Hobby King Blue Series ESC's flashed with SimonK. I dont know about buying "many" batts cause I'm noticing the price difference.
Discussion Show Us Your Hoverthings FPV Frame scrape Multirotor Talk 2149 Apr 18, 2014 05:06 PM
Discussion Hoverthings quad flipping and crashing randomly? easymoney99 Multirotor Talk 9 Jun 12, 2012 02:17 AM
Sold Hoverthings HT-FPV black Lucasberg Aircraft - Electric - Multirotor (FS/W) 3 May 04, 2012 08:10 AM
Sold Hoverthings FPV Quad Plug-n-play W/ Naza Blucross Aircraft - Electric - Multirotor (FS/W) 1 May 01, 2012 06:26 AM
Discussion Test flight of Hoverthings.com FPV 'Ralphie' frame daign FPV Talk 1 Jan 16, 2012 01:27 PM
