Old Feb 15, 2013, 04:24 PM
Steve34 is offline
Find More Posts by Steve34
Joined Feb 2012
Originally Posted by vic20owner View Post
So you got the vibes worked out? You are brave placing gear on the top plate... it's there to protect the gear under it
I don't have gear on top of the top plate I just have wires that stick up through the top plate . Theres not a whole lot that can be done to make the Quadrino Zoom board I have fit much better to avoid the situation .
Steve34 is offline Find More Posts by Steve34
Old Feb 15, 2013, 04:59 PM
Vantasstic is offline
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Originally Posted by Steve34 View Post
Problems are solved , ripped it apart again with an eye to reduce vibrations, zip tied and nylon taped everything down and I pulled all the wires that I had running through the middle of my Quadrino board , that how I had it in the VC450 but maybe on this frame I have vibs traveling along the wires to the board, so not anymore, oh and new carbon fiber props at 9inch. Im happy to be back at 9 inch so flight times should be better and happier batteries.
What CF props are you using? RCTimer's? I've been thinking of giving some a try.
Vantasstic is offline Find More Posts by Vantasstic
Old Feb 15, 2013, 05:34 PM
vic20owner is offline
Find More Posts by vic20owner
LOAD "FLIP-FPV",8,1
vic20owner's Avatar
Joined Sep 2006
I just built up a FLIP FPV with a clean/dirty section (basically just an extra plate), and did 1080p clean with no jello, no foam under camera, etc.
Going to cut a special plate for those who want to try this.
vic20owner is offline Find More Posts by vic20owner
Old Feb 15, 2013, 05:42 PM
SDSURFnGLIDE is offline
Find More Posts by SDSURFnGLIDE
Multi rotors=No Paycheck left
SDSURFnGLIDE's Avatar
United States, CA, San Diego
Joined Apr 2011
Are you using any sort of isolation bobbins like they use on the qav frames?
SDSURFnGLIDE is offline Find More Posts by SDSURFnGLIDE
Old Feb 15, 2013, 05:44 PM
LOAD "FLIP-FPV",8,1
vic20owner's Avatar
Joined Sep 2006
Yes, 4 of them.
Old Feb 15, 2013, 05:46 PM
Joined Apr 2011
Yes, 4 of them.
Ok...i was thinking of doing this on my ht-fpv frame...nice to know it might work
Old Feb 15, 2013, 05:48 PM
LOAD "FLIP-FPV",8,1
vic20owner's Avatar
Joined Sep 2006
yes 4 of them
Old Feb 15, 2013, 06:02 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
yes 4 of them
Interesting. So it looks like just another 'normal' plate and the isolators.
Old Feb 15, 2013, 06:22 PM
jlremr is offline
Find More Posts by jlremr
Johninarky
Rogers,Arkansas
Joined Jul 2005
Any one out there using a FunFly Controller "Naze 32" on their FLIP FPV?
It seems to have a lot of good features and a good price.
John
jlremr is offline Find More Posts by jlremr
Old Feb 15, 2013, 06:29 PM
melsailsnorth is offline
Find More Posts by melsailsnorth
Fight for the Right to FPV!!!
melsailsnorth's Avatar
United States, CA, Chico
Joined Dec 2010
yes 4 of them
Hi Tom,
I have mine setup the same with the bobbins but I changed the upper plate to the same as the bottom two because the area that holds the GOPRO otherwise did not have enough support and was starting to vibrate. Works great now, but I was a bit concerned about the total weight increase. Sure love the video I get now though!!! Huge difference from before and I can just "hard mount" my go pro without any foam or anything. According to the weight Vantasstic gave me of his stock flip, the conversion added around 350 gms overall.. The extra plate was $20 along with around $10 for the bobbins.
Mel
melsailsnorth is offline Find More Posts by melsailsnorth
Old Feb 15, 2013, 06:45 PM
Keddy is offline
Find More Posts by Keddy
Canada, ON, St. Catharines
Joined Jul 2012
Why is everyone having such a hard time with vibrations? at soon as I balanced my props perfectly, the vibrations went away.
These solutions just add more weight.
Keddy is offline Find More Posts by Keddy
Old Feb 15, 2013, 06:57 PM
Joined Dec 2010
True enough!! I hate the added weight, but even with perfectly balanced motors and props, I was still seeing jello with my gopro2. I loved my video with my QAV500 so much (but didn't like how easy it was to damage the aluminum arms) that I just figured it was the best route to that kind of quality. Indeed, if I could achieve the same results with the stock setup, I'd much rather do it that way though.
Old Feb 15, 2013, 07:21 PM
Keddy is offline
Joined Jul 2012
I could never get the vibes to go away with cheap props. Switched to Graupner and never had an issue. Easy to balance, very stiff, and very predictive flying.
Old Feb 15, 2013, 07:50 PM
kicekilla is offline
Find More Posts by kicekilla
No you cant fly it.
kicekilla's Avatar
United States, FL, Milton
Joined Mar 2011
When I ordered my flip frame I requested another non fanged plate and did this. I haven't had much time to fly it yet, but ill post a pic of my copter later tonight.
What would the special plate consist of? What's different? Thicker?? : ) that's the only problem I had with it... I had to use more than 4 bobbins or it would flex too much.
kicekilla is offline Find More Posts by kicekilla
Old Feb 15, 2013, 08:21 PM
LOAD "FLIP-FPV",8,1
vic20owner's Avatar
Joined Sep 2006
You are right of course ... that is why I designed the frame initially without them. But many people don't want to hassle with testing and tuning, they just want to fly and get 1080p out of the box... and I can totally understand that.
The reason I didn't go with the clean/dirty section in the flip fpv was to keep simple and to keep price down.
Tom
Discussion Show Us Your Hoverthings FPV Frame scrape Multirotor Talk 2149 Apr 18, 2014 05:06 PM
Discussion Hoverthings quad flipping and crashing randomly? easymoney99 Multirotor Talk 9 Jun 12, 2012 02:17 AM
Sold Hoverthings HT-FPV black Lucasberg Aircraft - Electric - Multirotor (FS/W) 3 May 04, 2012 08:10 AM
Sold Hoverthings FPV Quad Plug-n-play W/ Naza Blucross Aircraft - Electric - Multirotor (FS/W) 1 May 01, 2012 06:26 AM
Discussion Test flight of Hoverthings.com FPV 'Ralphie' frame daign FPV Talk 1 Jan 16, 2012 01:27 PM
