Latest blog entry: Transplanting a Spektrum Dx4E Rf Deck...
I tried another hover today, as I got my new flight battery - BUT ... looks like I may have an issue.
1. Power. I'm not convinced I have enough power to carry the frame and pack. I say this, because I attached my 4000mah 3S Nano-Tech to the frame, and at full stick, it battled to get up. Gets maybe 20cms up, and just wobbles. So - am I under powered for the size of pack? 2. Drift. When I power up, and only put in throttle, with LEVEL set to engaged, should the frame not lift straight up? Instead, it comes back at me, and also, drifts right straight away. I know I am not going high, but surely it should hang about the same area when I just add throttle? I am using this motor, and this ESC. |
Joined Feb 2012
Whats your total weight ? Before you add battery and camera. Mine without battery and without GoPro but including FPV gear weighs 960grams When I add GoPro 3 in its case + 2600mAh 3S Hyperion battery my flying weight is 1.39 KG which feels light to me and I have alot of power seems like and Im using the readytoflyquads standard motors |
). ![]() Which seem pretty light! No idea how I am 100gms lighter. That's with small video tx and board camera. Maybe I should question my scale? Photo is of my little helper, and the quad fully loaded with battery. 1168gms with 4000mah 3S Nano-Tech. And it seems - she don't wanna lift! ![]() Is it maybe a problem that the battery is towards the back (Due to the GPS stand not allowing it to go forward? Or should the controller compensate for this and lift the tail when it notices the weight? |
Durango Colorado
Joined Sep 2001
Maiden
Well, I maidened mine in the basement tonight and it went well. I put my pool noddle feet on for the first flight and I found it very easy to fly even untrimmed and out of balance. It would not stay in one place very long, but I know the CG is off to begin with. I'm using the FLIP MWC $18 flight controller and I am impressed all ready.
I don't have my FPV gear on it yet until I test fly it some more and tune it a bit, but it does not need much adjustment to get it where I like it. |
Latest blog entry: FPV mQX
USA, TX, The Colony
Joined Dec 2005
Once you are there, then you can engage the level switch and start trimming out any drifting by the control stick movements previously discussed. |
I also assume this has nothing to do which, what feels like a lack of power to lift? |
Hi forum , on the video below i did a flight test with 2 of my quadcopters on a 1 mile+ round trip without a FPV ground station , low FPV frequencies or long range TX module , one of the quads is a DJI F450 and the other is a Flip-FPV , it was a bit breezy but the Flip manage that flight better than my F450 but i love both quads anyway .
| Thread Tools | |
| Discussion Show Us Your Hoverthings FPV Frame | scrape | Multirotor Talk | 2064 | May 20, 2013 07:08 PM |
| Discussion Hoverthings quad flipping and crashing randomly? | easymoney99 | Multirotor Talk | 9 | Jun 12, 2012 02:17 AM |
| Sold Hoverthings HT-FPV black | Lucasberg | Aircraft - Electric - Multirotor (FS/W) | 3 | May 04, 2012 08:10 AM |
| Sold Hoverthings FPV Quad Plug-n-play W/ Naza | Blucross | Aircraft - Electric - Multirotor (FS/W) | 1 | May 01, 2012 06:26 AM |
| Discussion Test flight of Hoverthings.com FPV 'Ralphie' frame | daign | Video Piloting (FPV/RPV) | 1 | Jan 16, 2012 01:27 PM |
