Old Jan 31, 2013, 08:30 AM
man1024 is offline
Find More Posts by man1024
man1024's Avatar
Joined Oct 2011
Originally Posted by melsailsnorth View Post
Having transferred all the same equipment to my Flip FPV, I was out today on a trek just a tad under a mile and as soon as I turned my quad around at that distance, my RSSI went from 40ish to 0 and my Naza went into failsafe RTH and the trip was aborted. Same thing happened last week with my 450, but I was thinking it was some high power lines between me and my quad. now I'm thinking something has to be interfering with my EZ UHF on the quad, as I was flying in a huge barren field with nothing around me... Can anyone see any likely candidates for trouble? I'm attaching a picture, but basically I'm using the Flip frame, Sunnysky Motors, EZ UHF for control with a diversity 8 channel RX and two Sanders style monopole antennas, Naza w/GPS, immersion 5.8 vtx with SPW antenna, 600tvl OSD camera, TBS Core OSD. Everything is getting dialed-in nicely but I'm used to quite a bit more range with my LRS then this...
Try get rid of your second camera (at the top), it's on the way and creates extra interference, just use gopro for FPV.
man1024 is offline Find More Posts by man1024
Old Jan 31, 2013, 08:38 AM
man1024 is offline
man1024's Avatar
Joined Oct 2011
Originally Posted by JPV FPV View Post
Went out today after work with one goal: test newly installed Naza GPS RTH. It worked flawlessly. Had another 2 batteries at the ready even though it was not optimal conditions for fun flying, really gusty. Well, it turned out to be the most death defying, hypothermic flight I've had to date.
You guys should really check this out if you want a laugh
http://youtu.be/vyuu53zbnCw
Which leads me to the obvious question:
How are you guys with OSD determining when its time to come home?
I was using voltage, but when under load the reading isnt accurate. Thought about using mAh consumed but that seems like it would change as the battery life degrades after several flights.
nice vid! it's called experience, I know exactly when time to go home and land, I feel my quad, the way it reacts, also by using OSD timer, I don't actually need any OSD voltage and Mah reading anymore.
Old Jan 31, 2013, 08:45 AM
Matt Gunn is online now
Find More Posts by Matt Gunn
RCGroups Editor
Matt Gunn's Avatar
United States, OH, Parma
Joined Jul 2009
I would recommend against using the gopro as the flight camera. The barrel distortion is severe and makes depth perception quite difficult. i.e. you wont see those tree branches unit its too late! Also, quality is strangly below that of most flight cameras and has poor exposure times.
my opinion.
Matt
Matt Gunn is online now Find More Posts by Matt Gunn
Administrator
Old Jan 31, 2013, 08:54 AM
cactus is offline
Find More Posts by cactus
cactus's Avatar
United States, CO, Durango
Joined Sep 2001
I developed my method over many test flights and charge cycles. I use a Tiny 3 OSD and I calibrated the current sensor first. Then I make a timed flight and make note of the readings in the air. When I land I log the total mah used on the battery and after a few minutes check the resting voltage with one of those little lipo checkers. Later when I get home I charge it up back to full and compare the charger total mah back in vs what my current sensor told me I took out. Adjust OSD formulas until I get within 100mah difference and call it good. My voltage reading during flight and resting are within .2 volts, so I just fly till my OSD says 14.0 - 14.2 volts and land. I keep a running timer on my Tx and it beeps at 7 minutes. For my 4s 2200 45C packs I land within 30 seconds of that timer and it is nearly always 14.1 v. My 4s 3000 20C pack can go for an additional 3 mins.
cactus is offline Find More Posts by cactus
Old Jan 31, 2013, 09:45 AM
glmccready is offline
Find More Posts by glmccready
Gary
glmccready's Avatar
United States, MD, Salisbury
Joined Mar 2011
Mel: very interesting that it was your FPV camera that created the interference, food for thought. I still like my new FPV cam (600TVL SONY SUPER HAD) vs the Gopro. I'd have problems with the sun and shade with the GoPro, especially as the Winter sun became lower in the sky. The Sony is much better at handing the sun and shade of trees, and does it faster.
glmccready is offline Find More Posts by glmccready
Old Jan 31, 2013, 05:31 PM
JPV FPV is offline
Find More Posts by JPV FPV
Joined Dec 2012
I appreciate the advice fellas. I've now set my capacity alarm on the OSD conservatively.
JPV FPV is offline Find More Posts by JPV FPV
Old Jan 31, 2013, 05:44 PM
JPV FPV is offline
Joined Dec 2012
Another FPV cam data point...
I'm using this camera for FPV:
http://www.securitycamera2000.com/pr...-Lens-OSD.html
I was expecting superb performance into the sun, which it has. What I wasn't expecting was the incredible job it does in low light. I will warn you, the bracket is crappy plastic. I made my own out of metal. Very pleased.
Old Feb 01, 2013, 07:44 PM
melsailsnorth is offline
Find More Posts by melsailsnorth
Fight for the Right to FPV!!!
melsailsnorth's Avatar
United States, CA, Chico
Joined Dec 2010
Hey JP, awesome job on the video!! Looked like a blast! Were you flying Manual for most of that? I just ask because it seems difficult to get that kinda speed going while in stabilize mode. I've been practicing line of sight flying in manual and getting set to try flying it with the goggles in that mode which I will try this weekend. I'm hoping I don't end-up putting the strength of this frame to the test, lol....
melsailsnorth is offline Find More Posts by melsailsnorth
Old Feb 01, 2013, 07:48 PM
RCGroups Editor
Matt Gunn's Avatar
Joined Jul 2009
stick time under the goggles is the only way to get good with a quad. I can attest to that. Ive flown fixed wing fpv for a few years and the quad was quite humbling. But now Im getting more comfortable and can zip around stuff down low.
My first instinct was to climb to clear obstacles LOL. Took me a few sessions to get over that.
Administrator
Old Feb 01, 2013, 08:55 PM
Joined Dec 2010
I'm with you on that!! I've got really comfortable with fixed-wing FPV and I think it made for an easy transition flying fpv with a quad in stabilized mode but flying manual under the goggles looks like it's going to be a humbling experience to say the least. With he quality of some of the videos I see you guys putting-out, though, I think it's definitely worth the stick time!!
Old Feb 01, 2013, 11:10 PM
flohio117 is offline
Find More Posts by flohio117
DroneWorksUSA.net
flohio117's Avatar
United States, TN, Clarksville
Joined Dec 2011
Omfg I'm having the worst luck building this frame. I have everything together minus the props and I just found out a solder on my esc isn't good and that esc won't come on. I can't unscrew the bottom plate bolts because there easily stripped out. So now I have a frame together and can't get my board out. This is just not my day.
flohio117 is offline Find More Posts by flohio117
Old Feb 01, 2013, 11:47 PM
JPV FPV is offline
Joined Dec 2012
Thank you. Aurora is still recovering. She's exhibiting some weird yaw behavior after getting her wet. For the high speed run I was in attitude mode. I think I top out at 39-40 mph on a calm day. I just had a big breeze at my back at that particular moment. I'm practicing more and more in manual, but still not comfortable flying low without that safety net...yet.
I know what you mean. When flying LOS you can see the subtle changes in pitch that are sometimes tough to see during FPV, especially at altitude. I've been practicing flips, rolls, and dive bombs a lot lately. Just go really high at first and get lower as you gain confidence. When I get disoriented or panic I just click back over to attitude and she corrects herself quickly. (as seen in the video) The Flip FPV rolls and flips perfectly on each axis with zero coupling. Good luck!
Old Feb 02, 2013, 10:39 AM
cactus is offline
cactus's Avatar
Joined Sep 2001
Sounds like you need to tap out the stripped screws and fix that solder joint. Next time use a quality hex driver and go slow. And use the blue (removable) thread fastener formula.
This hobby can be frustrating at times but it is so worth it if you stick with it. Sometimes you need to put things down and do something else for a few days, then come back with a fresh perspective.
Old Feb 02, 2013, 12:23 PM
RCGroups Editor
Matt Gunn's Avatar
Joined Jul 2009
easiest way to get the screw out is to take a dremel with a thin cutoff wheel and make a notch in the head of the screw, that way you can turn it with a flathead screwdriver
Administrator
Old Feb 02, 2013, 01:09 PM
Joined Dec 2010
Man, why didn't I think of that. This man's been at this a while, lol.... good advice all around! I agree, though. I stripped a couple of mine with a cheap hex driver. Worth it (in the end) to pick-up a quality tool with a snug fit (advice I just took )
Discussion Show Us Your Hoverthings FPV Frame scrape Multirotor Talk 2149 Apr 18, 2014 05:06 PM
Discussion Hoverthings quad flipping and crashing randomly? easymoney99 Multirotor Talk 9 Jun 12, 2012 02:17 AM
Sold Hoverthings HT-FPV black Lucasberg Aircraft - Electric - Multirotor (FS/W) 3 May 04, 2012 08:10 AM
Sold Hoverthings FPV Quad Plug-n-play W/ Naza Blucross Aircraft - Electric - Multirotor (FS/W) 1 May 01, 2012 06:26 AM
Discussion Test flight of Hoverthings.com FPV 'Ralphie' frame daign FPV Talk 1 Jan 16, 2012 01:27 PM
