Old Jan 01, 2013, 07:38 AM
Cralis is offline
Find More Posts by Cralis
I love FPV!
Cralis's Avatar
Eastern side of Australia
Joined Jan 2007
Originally Posted by xhover View Post
But luckily I have already done all the hard work for you all you would need are my settings.
Thanks man! Let me get my stuff ordered and then I will come crying to you for help.
Cralis is offline Find More Posts by Cralis
Old Jan 01, 2013, 08:49 AM
Gadget-Geek is offline
Find More Posts by Gadget-Geek
Build,Fly,Crash,Repeat
Michigan
Joined Nov 2007
Thank you!!
Motors are only 20 each.
Or if you're really cheap, Just Google 20-28m 1050kv and you'll find many Hacker clones (Which is what these are) for $12-$14, $6 bucks per motor = $24 in your pocket.
Gadget-Geek is offline Find More Posts by Gadget-Geek
Old Jan 01, 2013, 08:54 AM
Derek_S is offline
Find More Posts by Derek_S
Videopilot
Derek_S's Avatar
United States, NC, Charlotte
Joined May 2009
Xhover, nice production value on the 1st vid, too!
Tell me, what is the advantage of all NFET escs? I am using some old ones flashed with the latest SimonK, but not sure what upgrading to all NFET will get me?
Derek_S is offline Find More Posts by Derek_S
Old Jan 01, 2013, 08:56 AM
Derek_S is offline
Videopilot
Derek_S's Avatar
Joined May 2009
Also, it looks like witespy has also modified the Multiwii code to have a flip specific one, so if you go with his flip FC ($20 and works great for me!), there may be even less work to do!
Old Jan 01, 2013, 11:03 AM
xhover is offline
Find More Posts by xhover
xhover's Avatar
Joined Mar 2012
Yes you could go the cheap way! But remember you buy cheap you get cheap!
Do it right the first time and save money in the long run.
xhover is offline Find More Posts by xhover
Old Jan 01, 2013, 11:04 AM
xhover is offline
xhover's Avatar
Joined Mar 2012
No problem I would be more then happy to help.
Old Jan 01, 2013, 11:09 AM
xhover is offline
xhover's Avatar
Joined Mar 2012
Thanks Derek !
I have found that with the normal flashed esc's after flying hard for a long period of time they tend to get a little warm and there for causing the quadcopter fly like lol
With the nfet transistors everything stays nice and cool through the whole flight and the quadcopter is much smoother!
Old Jan 01, 2013, 12:51 PM
Vantasstic is offline
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
But you did go cheap. I mean, $20 motors are a whole lot less than $40, $50, $60 ea T-Motors!!! Going back to your video...watched it again. Really smooth, good flying, and a joy to watch. I'm surprised the 5.8GHz worked so well. I keep hearing how they have no penetration capability. The GoPro vid is deceiving though...what was the actual video quality in your goggles? Again...great job on the vids...
Vantasstic is offline Find More Posts by Vantasstic
Old Jan 01, 2013, 01:00 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Cralis...the Multiwii isn't really that hard. You do have to go through some learning curve with the firmware, but it's not all that bad. Check out Multiwii.com and start grazing through the documentation and instrutctions. Download ArduIno and a Multiwii 2.1 sketch and look through the 'config.def' tab. This is about the only place you need to make any adjustments of what gets loaded into your Multiwii board. You also need the Multiwii Configuration program to do the PID tuning. There's lots of vids on YouTube on PID tuning. Consider the following:
P= Increase the P until your frame quickly oscillates then back down ~10%. If you get to low it'll be to drifty and hard to control. To high and it'll oscillate and be impossible to fly.
I= Controls how the frame holds attitude while in gryo (non-autolevel) mode. Tilt the frame forward for forward flight and release the sticks. If it noses up, increase I. If it noses down, decrease I. You want it to hold attitude when you release the sticks.
D= Shock absorbers in your car. If to low it will just keep bouncing back and forth after movements. To high and it'll start to oscillate.
Don't worry, you'll pick it up quickly...and buy plenty of spare props!!!
Old Jan 01, 2013, 01:27 PM
xhover is offline
xhover's Avatar
Joined Mar 2012
BURN!! lol
To be honest the video quality on the goggles was great didn't get any noise or cut outs at all.
thanks vantasstic
Old Jan 01, 2013, 01:34 PM
Derek_S is offline
Videopilot
Derek_S's Avatar
Joined May 2009
But he, to his credit, did buy from a reputable seller that has a lot of multicopter knowledge, and who has contributed a lot to this community, so hopefully we can assume anything listed on witespy's website is of a quality well suited for out purposes!
Old Jan 01, 2013, 02:36 PM
flohio117 is offline
Find More Posts by flohio117
DroneWorksUSA.net
flohio117's Avatar
United States, TN, Clarksville
Joined Dec 2011
BURN!! lol
thanks vantasstic
Whaaat! How no cut outs my 5.8 setup with cp antennas tracker and diversity would have been going crazy in your whole video. I don't see how no cut ours is possible. But I guess that's good for you
flohio117 is offline Find More Posts by flohio117
Old Jan 01, 2013, 03:23 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Just back from a quick flight with the Flip FPV. Yesterday I removed the 10x6x3 props and installed (balanced) 10x4.7 carbon mix Gemfan props. The frame felt smoother, but the proof was going to be in the video. Unfortunetly the video was worse...I picked up all sorts of vibs and jello this time. Drat... The flight performance was better and my amp draw went down to 209mAh/minute. I used my GoPro with the Sunex lens this time...perhaps why jello was more apparent? At one point the camera actually slide out of the wood case I had it in and it ejected in flight...took a few minutes to find the battery cover and battery...but I got it all back and it still worked fine. So my quest to find jello free performance continues...might have to try the 450 arms next.
Old Jan 01, 2013, 03:51 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
BURN!! lol
thanks vantasstic
What size battery are you using (3S, 4S)? I really like today's flight performance on mine...but the jello...argg....
Old Jan 01, 2013, 04:13 PM
xhover is offline
xhover's Avatar
Joined Mar 2012
3s 2200mah
Are you using any padding for the camera?
Discussion Show Us Your Hoverthings FPV Frame scrape Multirotor Talk 2149 Apr 18, 2014 05:06 PM
Discussion Hoverthings quad flipping and crashing randomly? easymoney99 Multirotor Talk 9 Jun 12, 2012 02:17 AM
Sold Hoverthings HT-FPV black Lucasberg Aircraft - Electric - Multirotor (FS/W) 3 May 04, 2012 08:10 AM
Sold Hoverthings FPV Quad Plug-n-play W/ Naza Blucross Aircraft - Electric - Multirotor (FS/W) 1 May 01, 2012 06:26 AM
Discussion Test flight of Hoverthings.com FPV 'Ralphie' frame daign FPV Talk 1 Jan 16, 2012 01:27 PM
