Your gains seem a bit high to me. You might try lowering them but increasing attitude if it feels sluggish. Also, what happens when you punch out in manual mode? This is a good indicator which gain is doing it. |
In theory, 4S is more efficient than 3S. We actually fly more by power (Watts) than amps. Simple math is IxE=P (amps x voltate=power). Let's say you need 300W to fly how you like. WIth a 12v system you divide P/E=A (300W/12V=25A). Now take that to a 4S system @ 16v...300W/16=18.75A...a 6.25A reduction which equals longer flying time. Now consider larger, heavier batteries will require more power to lift the extra weight and you could end up with no significant gain or flying time. I posted some of my 4S, 750kv, 9x5x3 time/power data earlier in this thread....without FPV gear installed. Now that I've added extra weight I will need to test again with different props to see which gives the performance and flight time I'd like. My goal is to achieve ~12 minutes full FPV flight time with the idea of flying only ~10 minutes with a few minutes of reserve. More testing to do to get an idea what my system is able to provide. |
Latest blog entry: Transplanting a Spektrum Dx4E Rf Deck...
It would not be hard to add a torsion bar or dampener plate to the arms if it turns out that they are resonating at a particular frequency. I have been playing with this lately actually. |
Joined Dec 2012
Thanks for the reply. I did mess with lowering the gains, all the way down to around 100%, couldn't escape the wobble. I'll try your suggestion on the manual mode punch out today and see what happens. Like I said, I'm a rookie at tuning, so I appreciate all the help I can get. And for the record, I LOVE both my HT quads! I'm sure I will get this figured out. |
I tried different props with my NTM 750 motors today. I had been flying the Flip with 9x5 3-blade props. It did well, but felt a little sluggish on throttle response. My first flight today was with 10x6 3-blade props. Wow, nice difference. It felt more reactive to stick and throttle movements, but what about amp draw?
I flew both 10" and 9" props on 4S and recorded with my Eagletree data recorder...so my results are a good comparison of actual performance. I was actually a little surprised by the results: 4S w/10x6x3 props: Max Amp: 40A total, full power climb Avg Cruise Amps:~13.5A total Flying Time: 8 minutes mAh Consumed: 1771mAh out of a 2650mAh pack Amps/minute: 221.3mAh per minute Max calculated flying time: 11.9 minutes to full depletion. 4S w/9x5x3 props: Max Amp: 27.7A total, full power climb Avg Cruise Amps:~14.5A total Flying Time: 7.1 minutes mAh Consumed: 1669mAh out of a 2650mAh pack Amps/minute: 235.1mAh per minute Max calculated flying time: 11.3 minutes to full depletion. So...with the 10" props I can actually get slightly longer flying time with better response. FWIW, I flew the 10" props a little more aggressively than with the 9" props. My last flight of the day with 10" props garnered ~214mAh/minute consumption...so even a little more flying time than the first run. On the down side, the 10" props are in view on both sides of the GoPro view. No biggy though. I prefer flying my Sunex lens on my multi's so that'd keep the props out of view. I need to do more tuning on the frame...or perhaps just install my Naza until my APM2.5 arrives and gets tested. Working on a quick video now...hopefully will have it posted later tonight. |
Thanks, that is very helpful data. It would be interesting also to maybe fly with 2 batteries in parallel, doubling capacity but seeing how much the returns diminished on this setup.
I flew about 4 packs today and have decided I really need to move up to 4s on mine. Although I didnt see a significant improvement in flight time, It sure is more responsive and even smoother whan on 4s. Plus if I used something a little lighter than my 4000 4s I think I might even see a little better flight times. Just wished I had a ~3000mah 4s battery to try it with. Van, what brand props are you using? I am using Zinger wooden props as that is all I have right now. Not sure they are the most efficient, but I like them ok. |
A little fun with today's 'prop testing' video. I had some vibration and PID tuning issues today that need to be worked out. Since this was more for flight duration testing with different props I wasn't to concerned about it. Enjoy the Flip'n video...
I finally built my FLIP this evening, and took pics along the way. I'm expecting some running gear soon
Latest blog entry: Aerial Mapping UAV
cool video van
| Thread Tools | |
| Discussion Show Us Your Hoverthings FPV Frame | scrape | Multirotor Talk | 2081 | Jun 15, 2013 01:11 AM |
| Discussion Hoverthings quad flipping and crashing randomly? | easymoney99 | Multirotor Talk | 9 | Jun 12, 2012 02:17 AM |
| Sold Hoverthings HT-FPV black | Lucasberg | Aircraft - Electric - Multirotor (FS/W) | 3 | May 04, 2012 08:10 AM |
| Sold Hoverthings FPV Quad Plug-n-play W/ Naza | Blucross | Aircraft - Electric - Multirotor (FS/W) | 1 | May 01, 2012 06:26 AM |
| Discussion Test flight of Hoverthings.com FPV 'Ralphie' frame | daign | Video Piloting (FPV/RPV) | 1 | Jan 16, 2012 01:27 PM |
