Old Mar 04, 2013, 04:24 PM
flybaby55 is offline
Find More Posts by flybaby55
cleveland ohio
Joined Mar 2008
Thanks builderdude,but since there is no access after it's built i have had good luck with eflite stuff. I was thinking hs55's hitec os55 rec. because i have those in stock. The only thing i need to get is motor and esc,batt. Hope they are not to big and heavy,but will see when kit shows up
Thanks John.
flybaby55 is offline Find More Posts by flybaby55
Old Mar 05, 2013, 08:29 AM
P. Tritle is offline
Find More Posts by P. Tritle
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Originally Posted by flybaby55 View Post
Kit and decals on the way,i got servos and rec. Any one know which park 180 i need there seems to be several choices.
Thanks John.
John, Go with the lowest KV available.
P. Tritle is offline Find More Posts by P. Tritle
Old Mar 05, 2013, 04:55 PM
builderdude is offline
Find More Posts by builderdude
builderdude's Avatar
United States, TX
Joined Jun 2011
I will be putting ailerons on my AJ Interceptor, but I will start a new build thread for it.
builderdude is offline Find More Posts by builderdude
Old Mar 06, 2013, 05:08 PM
cleveland ohio
Joined Mar 2008
Good luck putting ailerons on that wing.
Old Mar 06, 2013, 07:25 PM
United States, TX
Joined Jun 2011
No problem. No problem at all.
Old Mar 07, 2013, 04:25 PM
cleveland ohio
Joined Mar 2008
Well at a standstill,lost the set screw for the park 180 mount,what an idiot!!!! Posted some want adds maybe someone can help me out. John the village idiot!!!!!
Old Mar 07, 2013, 07:37 PM
United States, TX
Joined Jun 2011
John, I am certain if you contact E-flite, they will send you a couple of replacements for a few bucks. As tiny as those things are, it happens. You are not an idiot. You're probably like me...big huge paws.
Old Mar 07, 2013, 08:09 PM
coriolan is online now
Find More Posts by coriolan
"Unnecessary Necessity"
coriolan's Avatar
Canada
Joined Sep 2006
http://www.e-fliterc.com/Products/De...rodID=EFLM1121
The set screw is most likely 3mm metric but you can re-tap the mount to accept a 4-40 set screw available at the Home Depot.
coriolan is online now Find More Posts by coriolan
Old Mar 08, 2013, 03:00 AM
cleveland ohio
Joined Mar 2008
Thanks guys,after thinking about it i can just drill it and put a little epoxy and a screw or piece of carbon rod. Not used to working with motors this small,smallest i ever messed with is park 450,plus don't have the dexterity i used too. John.
Old Mar 08, 2013, 08:42 AM
cleveland ohio
Joined Mar 2008
Making some progress,not going to be as lite as pat's but have to use what i have on hand.
Old Mar 08, 2013, 10:18 AM
United States, TX
Joined Jun 2011
Looks good.
I am actually going to do my own build thread on a separate thread than this one. I won't be starting for another few weeks yet on mine. I'm still working on another project.
Just a note. I have yet to make one of my planes as light as Pat's. I always miss the mark, but I still try. You have to keep in mind that Pat has built thousands of planes and has designed hundreds. So he has a real wealth of experience.
Old Mar 10, 2013, 11:44 PM
shinck is online now
Find More Posts by shinck
Utah, USA
Joined Jun 2007
Pat,
What prop are you using on the Park 180?
Just ordered the kit and graphics. Radio items I don't have are ordered tomorrow.
By the way, I checked the wing loading and you were pessimistic. At 3.3 oz I got a WL of 3.8 oz/sq.ft., not 4.2
I have 2 of the original catapult launch w/ metal centers.
And another history item: my father worked in a hobby shop with Bob Smurthwaite, who developed this design. That was in the 1940's.
AMA biography https://www.modelaircraft.org/files/...aiteJamesR.pdf
Scott
shinck is online now Find More Posts by shinck
Old Mar 11, 2013, 01:20 PM
United States, TX
Joined Jun 2011
Scott, I was talking with Pat over the weekend. I think he told me he used a 7x3 prop. I'm pretty sure that's what he said. He also said that motor was ALMOST too powerful for this plane.
Sounds almost like it might be 3D capable with the Park 180.
Old Mar 11, 2013, 01:32 PM
Utah, USA
Joined Jun 2007
Thanks.
I got onto eCalc and, using the info given by Pat, calculated that the Park 180 would put out about 20w with a 6x3 slow fly prop (max prop size on 2S recommended by E-Flite). I tried a 7x3 in the calculation, but got a warning that it pulled too much current for the motor.
At 20w, and a flying weight of 3.3 oz, the power loading is 97 watts per pound, which is pretty spritely. That would make a lot of 10 second climbs with glides, or flying around your head at low throttle for a loooong time.
My graphics will be sent tomorrow. The kit will be longer; waiting for another shipment of parts, so I think this is popular.
Scott
Old Mar 11, 2013, 01:41 PM
E-Challenged is offline
Find More Posts by E-Challenged
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
Wow, with the graphics, it really looks the part.
E-Challenged is offline Find More Posts by E-Challenged
Sold 6 ch r/c flight simulator for pc reble1 Aircraft - General - Miscellaneous (FS/W) 6 Oct 17, 2012 07:02 PM
Discussion Discount on rechargeable 3-CH R/C helicopter, up to 30% off Sandy90 Hot Online Deals 0 Sep 29, 2012 12:06 AM
Discussion Big Surprise from 3.5-CH R/C Indoor Helicopter Sandy90 Electric Heli Talk 10 Sep 06, 2012 12:22 PM
Discussion Every man's dream Rechargeable 3-CH Palm-Size Mini R/C Helicopter Sandy90 Micro Helis 15 Aug 28, 2012 05:13 AM
Discussion 40" Piper Pacer for IPS Power and 3 ch. R/C P. Tritle Scale Kit/Scratch Built 113 Jul 25, 2006 07:18 PM
