Old Dec 18, 2012, 08:33 PM
P. Tritle is offline
Find More Posts by P. Tritle
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Getting Back to the Fuselage
Spent a few minutes this afternoon getting the Anylink set up on the DX-7. Turns out it was a simple plug in affair, with no binding needed for the F-86 Rx. The servo plugs were arranged to get the rudder and elevator on the right stick with the throttle on the left. Then with everything working, the fuselage side was glued in place and the top and bottom center balsa caps were added. The edges were beveled and the top side cap sheeting was added on all of the top and most of the bottom. Will finish it up tomorrow, and at that point, it'll be ready for cover and to get the graphics coming.
PAT
P. Tritle is offline Find More Posts by P. Tritle
Old Dec 18, 2012, 09:40 PM
magmo is offline
Find More Posts by magmo
Joined Jan 2005
Pat,
This plane is awesome looking, I love the way you were able to keep the radio hidden inside of a profile fuselage. It really retains the looks of the American Junior 404 Interceptor. If folks want a lot of history on Jim Walker and the 404 Interceptor along with everything else he made, take look at there web site.
http://www.americanjuniorclassics.com/
You can still get a folding wing Interceptor and 74 Fighter from them.
magmo is offline Find More Posts by magmo
Old Dec 20, 2012, 10:29 AM
E-Challenged is offline
Find More Posts by E-Challenged
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
Hmmm, have you thought of launching with a rubber band just for nostalgia sake? Would need down elevator during launch phase
I'm just wierd enough to want to build the eventual short kit.
E-Challenged is offline Find More Posts by E-Challenged
Old Dec 21, 2012, 01:48 PM
Pierre_de’ Loop is offline
Find More Posts by Pierre_de’ Loop
Pierre_de’ Loop's Avatar
United States, MD, Bethesda
Joined Jun 2004
It’s like a window into my dreams. Brilliant.
Pierre_de’ Loop is offline Find More Posts by Pierre_de’ Loop
Old Dec 23, 2012, 10:07 AM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Finishing Up the Fuselage
Got the last of the edge sheeting in place, then added a spot of filler here and there to level and smooth things up, then applied a couple of coats of Nitrate Dope to seal it up. A couple more coats and she'll be ready for graphics.
Old Dec 23, 2012, 10:09 AM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
A Dry Run Before Covering
Just to be sure no additional trimming would be needed the wings and tail were dry fitted onto the fuselage. So far it all looks good, so nxt step is to get the frames covered.
Old Dec 23, 2012, 10:14 AM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Covering the Frames
Covering the AJ is easy compared to most. The only thing to do is the wing and tail group. The fuselage will be left natural wood to stay in theme with the original.
The wings and tail components were first given one last detail sanding, then covered with cream Microlite, but in retrospect I'm not 100% sure that white might not be a better choice?? Oh well, I guess that'll be for another time.
Meanwhile, at this point the model is ready for graphics, so will go to work getting the information together to get Callie started on the project.
PAT
Old Dec 23, 2012, 10:59 AM
Yankeeone is offline
Find More Posts by Yankeeone
Yankeeone's Avatar
Madisonville, Tn
Joined Nov 2007
Pat,Looks great!! Can't wait to see it with the graphics on. I think I do need to work up a 24" span 74 as a companion to yours. Time will tell.
I also posted up a pic of my completed Pacer on the Stinson site. Take a peak and let me know what you think.
TTFN The Yank
Yankeeone is offline Find More Posts by Yankeeone
Old Dec 24, 2012, 09:44 AM
Joined Oct 2000
As a further tribute to Jim Walker, a faux electric powered Firebaby for U-Control or RC would be neato. The AJ Hornet rubber powered FF enlarged and converted to electric RC has been done successfully. These are scale models of non-scale models and as such, should at make an appearance in the Scale Electric Plane forum.
http://www.americanjuniorclassics.co...t/hornet2x.htm
Old Dec 24, 2012, 06:15 PM
coriolan is offline
Find More Posts by coriolan
"Unnecessary Necessity"
coriolan's Avatar
Canada
Joined Sep 2006
Jim's Walker 404-Interceptor &AJ Hornet
Paul Bradley did them with the old RFFS-100 actuator system:
http://www.parmodels.com/elec_rc.htm
coriolan is offline Find More Posts by coriolan
Old Dec 26, 2012, 12:59 PM
jonquinn is offline
Find More Posts by jonquinn
USA, PA, Westmoreland Co.
Joined Aug 2008
I wrote to them about getting a set of plans drawn by Frank Macy for an electric Fireball RC. Its not in the fireball plans set but the owner said he would get them printed and figure out a price. They also had a very neat looking A-J 744 U/C that had a molded balsa fuselage - it would make a nice looking electric RC too.
jonquinn is offline Find More Posts by jonquinn
Old Jan 11, 2013, 12:01 PM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Back in the Saddle Again.....
Been down for a bit over the holidays, and was late getting the graphics ordered, so had to wait it out. Callie was closed from just before Christmass till just after the new year, but she's back at it and was able to get the graphics done for the AJ. So, today it looks like we'll be applying the decals. In the meantime I got the opening cut into the fuselage for the battery.
PAT
Old Jan 11, 2013, 05:10 PM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Applying the Graphics
Got the Graphics in place this afternoon with only a minimal amount of trimming. Now it's really starting to look like a 404.... And as expected, Callie really did a job on this one.
Old Jan 11, 2013, 05:13 PM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Doing the Major Assembly
And with the graphics in place it was time to put all the big pieces together. The wings and tail section was glued in place, and the hinges set up using hinge tape. Then the Z-Bends were made on the pushrods and the control horns glued in place. And with that done, the only thing left now is to set up the CG and get the radio programmed for the test flights.....
PAT
Old Jan 12, 2013, 08:14 PM
Brian Allen is offline
Find More Posts by Brian Allen
Veni Vidi Volavi
Sterling, VA
Joined Jan 2002
Pat
Very slick looking!! Hope the test flights go well.
Brian Allen
Veni Vidi Volavi
I came I saw I flew
Brian Allen is offline Find More Posts by Brian Allen
Sold 6 ch r/c flight simulator for pc reble1 Aircraft - General - Miscellaneous (FS/W) 6 Oct 17, 2012 06:02 PM
Discussion Discount on rechargeable 3-CH R/C helicopter, up to 30% off Sandy90 Hot Online Deals 0 Sep 28, 2012 11:06 PM
Discussion Big Surprise from 3.5-CH R/C Indoor Helicopter Sandy90 Electric Heli Talk 10 Sep 06, 2012 11:22 AM
Discussion Every man's dream – Rechargeable 3-CH Palm-Size Mini R/C Helicopter Sandy90 Micro Helis 15 Aug 28, 2012 04:13 AM
Discussion 40" Piper Pacer for IPS Power and 3 ch. R/C P. Tritle Scale Kit/Scratch Built 113 Jul 25, 2006 06:18 PM
